3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a racing lawn mower (Updated!)
Step 2Frame reinforcement
Frame reinforcement
The next step is to beef up the frame or make alterations that will work with your components.Its important to realize that these mowers will be racing on what tends to be really rough dirt track. They have no suspension, thus the frame takes a severe beating. Reinforcement is critical to avoid having the frame flex and ultimately crack from fatigue. The rear of the frame was cut about 6" from the rear. Throughout the build, I used 1x1 square tubing which is easy to weld and work with. This is what I used to create the square frames in which the mounting brackets were welded into to hold the rear axle bearings. I chose to use a 1/1/4" rear axle because that size is highly common and thus easier to get parts like wheels and sprockets for.
These square frames were welded into the frame, then the end I cut off was welded to the back. The minimum height requirements for my class is 4" from the frame to the ground. So its important to know what size wheels you plan to use and where to mount the axles in order to meet that requirement. The lower you can go, the better handling the mower will be. Mine site just at 4" off the ground.
Next, I welded two lengths of square tubing along the top of the axle brackets to the front tubular frame. I did this because the transmission will go underneath. A piece of diamond plate will cover it, and above will be the seat. This will give me easy access to servicing the chain and transmission and also protect me from flying debris or potential chain failures.
I am using a right angle gearbox for this build. Why? Because the other choice is to use a 3-5 speed gearbox used as standard equipment on mowers. These work fine, but it also means you'll have to change the grease in them and perhaps invest in hardened gears since the originals will strip out much easier. With a right angle gear box, or RAGB, there's only two moving parts. Plus, they are made for higher speed applications and therefor perfectly suited for this application. More simplicity means more reliability.
Additionally, I am using a centrifugal clutch. This is a higher quality, higher HP rated unit that is heavier duty than typical go-cart clutches. The springs can be adjusted for higher or lower engagement.
18 comments
Feb 23, 2011. 2:56 PMbillybob6 says:
whats the eaisiest way to reinforce the frame because i cant weld
Mar 7, 2011. 8:32 PMgschmidt-2 says:
also, the best way to learn to weld is to practice on scrap metal. under the mower don't have to look pretty as long as it holds. just remember, DON'T weld it all the way, stitch weld it so you don't warp the frame. i live in N.E. and we build mowers that can go 100 mph+
Oct 1, 2011. 8:59 PMOleNavy says:
Sorry Pal, ain't no mower gone 100 mph yet.
May 8, 2012. 7:01 PMthe doctor who says:
(removed by author or community request)
May 9, 2012. 6:33 AMOleNavy says:
And your comment is backed by what????
Jan 19, 2012. 10:16 AMgrampamurdoc says:
http://video.google.com/videoplay?docid=-668943712906921468#
Jan 21, 2012. 9:10 AMOleNavy says:
I see nothing to indicate this "mower" reached 100 MPH and sustained that speed. Bobby Cleveland driver and racer, sponsored by and employed by Gold Eagle went to the Bonneville Salt Flats (twice) and still was unable to reach 100, but he was close. The video can be seen on the USLMRA website. My brother, Chuck Miller, was there as part of his pit crew for the attempt. Bobby's speed was documented by the Salt Flat organization. So a claim is only a claim unless you have bonafide documentation to back it up. Video of a machine running illegally on a public road doesn't cover it.
May 10, 2012. 8:59 PMWesley666 says:
I just realized though, you probably have to use a stock engine that has been upgraded, not transplanting a monster of an engine into them, correct?
May 10, 2012. 8:58 PMWesley666 says:
No one has gotten a lawnmower to do 160km/h? Seriously? I just picked up a 110hp sled engine from a 2004 Arctic Cat Sno Pro and was planning on putting it in a lawnmower to motor around on. If you can get a sports bike to hit 200km/h with less then that I think I can get a lawnmower to do 160km/h. Clearly, no one has really put in a good effort to get a lawnmower to go balls out. I think I could get a lawnmower up to 200km/h easy with 110hp.
Mar 7, 2011. 8:25 PMgschmidt-2 says:
i have found the best way to reinforce the frame is to use 3/4 square stock along the top corner of the frame. this will make the frame very strong but not add to much weight
Aug 22, 2011. 12:13 AMMcClellan41 says:
ya hi i was wonderin what size sprocket i should use on the input to the ragb..i have 17t on my clutch and the ragb is a 1:1 ratio???
thanks
Apr 9, 2011. 11:38 PMpaullove says:
the centrifugal clutch
where do I get 1 that is strong enough?
Oct 20, 2010. 9:29 PMbessner50 says:
im makin one for goin muddin with my buddies and i need to get power how would you do that?
Feb 13, 2011. 6:22 PMgordzooks says:
For what you put onto one of these, you could probably pick up a used 4-wheeler that would be better suited to the application. Of course, then you miss out of the fun of building it.
Feb 17, 2011. 8:17 PMgordzooks says:
Don't get me wrong, I like the idea of lawn mower racing. It's just the idea of the off-road mowers that strikes me as more work than it's worth for the results. For the money you could pick up a used Samurai or Jimmy and torch the top off.
Oct 15, 2009. 6:01 PMbrodewald10 says:
Where did you get your centrifugal clutch?
Sep 28, 2009. 12:07 PMmaer35 says:
where did you get the right angle gearbox
Mar 31, 2009. 8:08 AMfast-dude says:
how long is the 1x1" square tubing on top of the axle hangers that go most of the way down the frame?
Mar 29, 2009. 5:41 PMfast-dude says:
im thinking of building my frame by hand but i kinda need to know a rough estimate of the lengh and width of the one in the pics? can anyone help me with that?
Mar 16, 2009. 3:15 PMbeenie says:
Where did you get your RAGB from? and how much did it set you back?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:mowerracer
