3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a racing lawn mower (Updated!)
Step 3Steering system
Steering system
  • last photo ←
The next step is one of the most important of the build. Many people go out on the track with the stock steering setup. That's a big mistake for a number of reasons. For one, the stock components aren't made for going 50MPH, as is none of the other stock components. Secondly, there's more to steering besides making the wheels turn. You also need to have the proper caster, pitch, and turning radius so that the chassis will handle corners better.
Most mowers come with a gear driven steering setup. These are worthless and tend to pop out of place. So you'll need to make a "direct steering" system. In other words, a solid connection between the steering wheel and the front wheels.
For this build, I bought a pre-built front axle from a guy in Texas. He has a small business called " Acme mowersports" and can be found at www.acmemowersports.com. His front axles are a good deal because even if you were to build your own, the cost would be only slightly less. With the Acme axle, the proper caster and degree of inclination are already built-in, which will save you lots of time. These come with the radius arms as well as connections for the steering axle, which on mine runs down the center of the front of the mower over the top of the engine.
Next up is the installation of the steering shaft running along the front of the frame. This mower has an unusual setup where the steering linkage runs over the top of the engine. An a arm runs from the steering wheel pitman arm to a shaft running down the front of the frame to the radius arms of the front axle spindles. First, I got some 1/1/4" steel pipe and cut some lengths about 2" long. On each end, I placed a bearing in which the steering shaft fits through.
The top of the front steering shaft has a removable lever to attach the piece of linkage coming from the steering wheel. This enables you to remove it if needed. If you look at the pic entitled "pitman arm detail", this is the steering wheel shaft with the pitman arm welded on. As you can see, the arm on the end is rounded and has three holes. There's a reason for this, which is to prevent the heim joints, which are the screw-on ball bearing pieces on the ends of the rods from binding. The reason for the three holes is to give you adjustments to the steering sensitivity. Further out gives you more slack. Further in tighter. It is also important that the arm running across the top of the engine area has threads on either end. This way the heim joints can be screwed in or out to adjust the amount of right and left turn in the wheels.
In The pic entitled: "Steering arm", you can see how this system works together. Lastly, the "turn right" pic shows the underside linkage and radius arms. If you see the "t" shaped piece, that's where the radius arms connect. The "T" is welded to the bottom of the front steering shaft.
Another step is to determine the angle of the wheels. Generally, it is better to have the left wheel turn in more than the right. I usually have the left wheel turn in @ 10:00 and the right at 2:00.
Lastly, you will need to install what are known as "stops", which are basically welded on rods or bolts to prevent the wheels from turning too far. If they turn too far, the steering wheel will turn completely over, thus reversing your steering! Not good! For this build,. all I did was weld two 5/16" pieces of steel rod to the front of the axle, right where the spindles swing in and out. The spindle arms simply hit the stops. I held the wheels in place at the correct position and placed the stops at exactly where the spindle arms hit, then welded them into place.
Once you have the steering done, then you've just completed one of the hardest steps!
18 comments
Jan 28, 2011. 5:37 AMjeff091796 says:
would the front axle work on a sears lt 11/36, this is a huge riding mower, my steering linkage from the gear to the spindle broke, and they don't make it anymore, thanks jeff
Aug 8, 2010. 1:20 PMKen Chevy says:
  Hi, In Step 3 you say:
  "Generally, it is better to have the left wheel turn in more than the left."
  Should the last word be 'right'?
  Nice Instructable.
  Ken Chevy
080810 1320
Aug 9, 2010. 8:29 AMKen Chevy says:
  I guess I missed something or don't understand something about instructables.  I have never made an instructable, but are you saying a person can NOT go in and correct errors?
   I would have thought the owner of the instructable could correct errors?
  A person should always correct errors if possible so people reading the instructable  doesn't get frustrated because they can't figure something out because something was entered wrong.  You correct your mistakes so people understand what you have written.
  Like I said above, you have a nice instructable, well written.
  Regards,
Ken
080910 0829
Feb 23, 2010. 1:05 PMmiketryiu says:
 wow wheels... how to you have wheels new?
Sep 7, 2009. 6:25 AMhockeyteen6 says:
I have a true test riding lawn mower and I need to know how to transfer the power from the cutter to the wheels. thank you.
Sep 12, 2009. 9:07 AMhockeyteen6 says:
thank you
Apr 20, 2009. 7:08 PMMikeJohnson says:
i got a racing lawnmower and i need a different steering system as the one that i designed isn't to hot. i ve been thinkin of ur set-up and think im goin try it. do u now if it will work all right on a heavier mower? im also wondering about the pitman arm coming from the wheel, can u tell me everything u did for it? angle? ofset?......... Thanks Mike
Mar 31, 2009. 8:03 AMfast-dude says:
so did it come with everything you needed to have it go over the engine?
Mar 30, 2009. 11:31 AMfast-dude says:
what hook up for the steering did you choose?
Jan 7, 2009. 4:39 PMrailroader010171 says:
the front axle....is that the center steer from the website you have listed? how much?
Oct 25, 2008. 12:22 PMMerkatroyd says:
What size wheels did you use? Where did you get them?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:mowerracer
