3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a racing lawn mower (Updated!)
Step 7"Puke tank", seat, and engine mounting.
Our next step is to make what is known in the racing world as the "Puke tank". No- it isn't for seasickness, but rather for the engine. Since the engine will be running at sometimes 50% faster than it was originally designed for, the crank case will sometimes spit oil from the crank case breather. Since you don't want that stuff all over the track or you for that matter, you make sometimes called a puke tank. Mine is made out of ABS plastic pipe, brass hose fittings, and PVC for the breather on the right side (in white). This is mounted to the back of the mower under the seat, connected with a hose to the engine valve cover.
Next, I decided to machine slots into the engine mounting pan. I made keyhole shaped slots that enable the engine to be slid forwards and back so that the chain can be fitted and tensioned properly. This is the longest chain on the build, thus a spring-loaded tensioner was fabricated in addition. Since the chain here is hanging horizontally, you want to have constant, gentle pressure applies to keep it from falling off. The tensioner is simple, using a channeled nylon idle pulley typically used on mower decks. Like the skateboard wheel, nylon holds up just fin on chain. The pulley is mounted to a arm that is bolted to the underside of the simulated mower deck via a nylock nut and bolt. A spring is attached to it as well as a bolt welded to the underside of the engine pan. As you can see, the chain fits nicely from the centrifugal clutch to the RAGB.
Now the seat. This step is actually kind of important. You'll find that staying on these mowers on a bumpy dirt track with sharp corners is difficult.The inertia will threaten to throw you off. But at the same time, if you do fly off, you want to clear the "scene of the accident" and not get run over by your own mower. So it needs to be low. The solution is to have a low seat with low sides that keeps your rear attached to the seat. It'll actually give you more control. One last word- it helps to have padding. A steel seat with no padding can be... painful. My Wife covered mine with upholstery from an old chair.
22 comments
Jun 19, 2011. 7:14 PMjmichels1 says:
Hey,Mowerracer what would u think I shold do with a Kowasaki liquid-cooled V-Twin with about 17.5 hp, and how could i modify that.
Sep 8, 2009. 1:33 PMstalefish skater says:
why do i need a chain when i could use a driveshaft?
Dec 28, 2010. 3:08 PMJOHNTHEREDNECK says:
its a choice you could stick with stock or mod it up
Nov 1, 2009. 7:16 AMBosun Rick says:
As to the issue of belt/chain tensioners, did you consider using a belt tensioner from a car engine? they can be mounted with a minimum of effort, and if you pick one that allows it, the roller might be replaced with the skateboard wheel. Your opinion/comment?
Jun 4, 2010. 4:56 AMJOHNTHEREDNECK says:
yester day i found out that the stock pcv relasa pressure as the piston coms down and shuts to let pressure build up when the piston is going to TDC if i take this off and modify it so thatn it lets out all the pressure in the crank caes on the down stroke wouldnt it give me more power due to less air friction
Jun 5, 2010. 4:17 AMJOHNTHEREDNECK says:
ok thanks thats what i was thinking but i wasnt sure if it would have ill afect on the motor in the long run thanks.
Mar 4, 2010. 8:03 AMWicked dow says:
This is the nicest racing mower ive ever seen
Jul 3, 2009. 8:18 PMmrh1023 says:
what do u hook the puke tank up to on the motor where
Apr 30, 2009. 2:30 PMskatermatt11 says:
hi, great stuff what youv done, i was wondering what diameter the RAGB output shafts were and where i can find a centifugal clutch, i have a 20hp twin cylinder briggs and straton. thanks
Apr 29, 2009. 9:59 AMFail-man says:
Hi once again sorry to bother you all the time but you have all the knowledge. I assume you use go-cart parts but can you use cross and 4wheeling parts as well or is it best to use go-cart parts thanks your awesome Thanks a dude from sweden
Apr 29, 2009. 7:07 AMFail-man says:
thank you very much sir your a realy god "explainator" that help alot. The thing im must focus on most is the FRAME BRAKES MOTOR(SPEED) STEERING????? And ive located a old HUSQVARNA thats abaout 3-4 years old can you yuse that or will it be to fragile thaks sir sorry if i repeted my Questions last time ive writed to you your awesome thaks for the help see you later alligator Much thanks A dude from sweden
Apr 28, 2009. 12:46 PMFail-man says:
Hi sorry im late to ask the questions ive had to go for a while so my question(s) are 1:with is the best mark Westwood Lazer Honda Wheel Horse/Toro John Deere Mountfield Lawnflite Murray Countax Rally AYP Ariens Simplicity. With is the best mark for Lawn Mower Racing 2: can you ride the mower without change it to much (im not lazy i just wonder sir) 3: Can you putt a (for exampel) Kitaco 150cc cross motor in it? Or will it brake by the power and the chassi can you adjust it as you want or is that illegal and can it be as fast as you want sorry im not very familiar with the rules thanks sir your awesome!!!!!!!!.......... O Sir Siiiiiir i forgot one thing do you HAVE to change it much so it will not braket or is that a must. Thanks sir Your Awesome A dude from sweden
Apr 28, 2009. 9:18 AMFail-man says:
Thank you very much that helped allot thanks your awesome man your the best thanks again for the help................ But can I ask you an other question??????
Apr 27, 2009. 11:57 AMFail-man says:
Hi mowerracer your super i love your ideas and work but i have i question what is a crank case sorry im new and i love motor sports especially lawn mower racing thank you. A dude from sweden
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:mowerracer
