3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a racing lawn mower (Updated!)
Step 9Paint and finishing it up.
Now for the funnest part of the build: Painting. Now all of that hard work gets to get shown off. But before painting, you need to do some prep. The chassis is likely oily and dusty from welding. All of the welds are also likely not "clean" meaning they're splattered. You can quickly clean up the frame with sandpaper flap discs attached to a grinder. Clean all of the rust, splatter, and rough edges to a smooth surface.
I used a oxide primer primer, which is a good foundation for the paint. I used plain ole' black spray paint. I chose spray paint because the frame is very likely going to get pitted with rocks and future mechanical modifications. So it can easily be touched up. Plus its cheap. The fiberglass hood was painted with orange engine paint, which I find dried quick and smooth.
Now the entire mower is put back together. Wheels, engine, brakes, electrical, etc. The mower went back together surprisingly quick. Less than two hours was all it took.
With the mower put back together, all that's left is to bleed the brakes, install the battery, fill the engine with oil, and then give her a test run.
Wanna' see it run? Watch the video.
Anyhow, it was lots of fun making this mower and so far I've been in 3 races this season. Feel free to ask questions if you want to make your own. if you want to see me in action, visit my racing club's web site, http://www.pvmowerracing.com
55 comments
1-40 of 55next »
Oct 21, 2011. 2:03 PMrabrantes says:
Also where did you locate your fuel tank and how big is it?
Oct 21, 2010. 10:44 AMrabrantes says:
I really like the design of the frame you built and I am interested in building one during this winter. Could you tell me a couple basic measurements of the frame? How long and wide it is? How far from the front of the frame to where it becomes two frail rails? And the distance from the bottom of the bottom frame rail to the top of the top frail rail by the rear axle. I would appreciate it, thanks!
Mar 19, 2009. 5:40 PMchivesg5 says:
I am using a ragb and balts what size poles should I use how fast would it go and from the ragb to the axle iam doing by chane what size sprocte shoul i use
Aug 8, 2010. 1:16 PMKen Chevy says:
  Engine/clutch 14tooth -> 14tooth on RAGB=Same ratio.
  RAGB has 2:1 ratio. Now engine turns twice for axle turning once. RAGB has a 12tooth and rear axle has a 40tooth.
   40tooth / 12tooth = 3.33 ratio x 2 (from 2:1 ratio in RAGB) = 6.66:1 over all ratio.
  Tires are 11 inches in diameter.
  With that ratio your speed will be:
5000RPM=24.56MPH and
6000RPM=29.48MPH.
  Changing ANY of the numbers changes the MPH. If you change to a 36tooth rear sprocket then the ratio becomes 36/12=3:1x2(RAGB)=6:1 total.
Then the speeds become:
5000RPM=27.27MPH and
6000RPM=32.72RPM.
  These are TRUE numbers, IF the clutch is locked up and not slipping. Using belts, there may be belt slippage, making your speed a little slower.
  With a 40/12 ratio, changing rear tire from 11 inch to 12 inch diameter changes speed at 6000 from 29.48MPH to 32.16MPH.
  It would be easy to put all of that into a spreadsheet to show speeds for every 1000RPM and what happens when changing sprocket ratios or tire sizes.
 I made a formula over 35 years ago to figure numbers like that out, the formula is:
RPM÷RearRatio÷TransRatio×TireDiameter÷336.13524=MPH
Nice Instructable.
  Ken Chevy
080810 1316
Mar 7, 2011. 8:50 PMgschmidt-2 says:
OK, after looking at your build i see that you are using a chain instead of a belt. also you are using a cintrifical clutch. whats the deal??? the way we race is with a belt, double pulley clutch. the only chain we use is between the trans and rear axle. i was wondering what rules you are using?
Mar 8, 2011. 11:21 AMgschmidt-2 says:
OK, that makes sense. we only have one guy with an f/x mower. what state are you in? I'm stuck in N.E. and if your not a farmer or rancher there's nothing to do during the summer but race. right now I'm finishing up a mower that i hope will go 100mph.
Aug 18, 2011. 5:32 PMOleNavy says:
You should check out Bobby Clevelands last run at the Bonneville Salt Flats. He didn't hit 100 MPH, which was the goal, but he got awfully close to it. He said it was a scary ride. The was a video on the USLMRA website. Bobby works for Gold Eagle and takes their truck to a lot of the USLMRA sanctioned races including the national championship race at Delaware, Ohio, sponsored in part by my brother, Chuck Miller. Chuck owns Miller Lawn & Power in Marion, Ohio and the USLMRA Hall of Fame is currently located in his showroom on East Center Street.
Dec 28, 2010. 2:59 PMJOHNTHEREDNECK says:
would this ratio apply to mine im running 4500 rpm with8to1 i dont know the tranny ratio yet
Dec 28, 2010. 9:28 PMKen Chevy says:
You say you have a box that is 8 to 1.   It has two shafts coming out of it.
If you hook the engine driveshaft up to one of the shafts, the other shaft will either turn 8 times faster or 8 times slower than the engine is turning.
You will probably be using it to gear the engine speed DOWN, so divide the RPM number by the larger number, that will tell you how fast the output shaft will be turning then.
Input RPM = 4,500 / 8 = 562.5  RPM output speed.
Ken
122810 2127
Dec 29, 2010. 10:56 AMJOHNTHEREDNECK says:
sorry i wasnt really clear ive got pulleys that are 8 to 1 then they go into the transmission which is either going to be a 5 spd spicer or a 6 spd peerless from a poulan . im hoping on getting 45 to 55 out of it.
Dec 29, 2010. 2:38 PMKen Chevy says:
I can't read minds (yet - LOL) and can't see the parts you have in front of you.
So, you have to give me numbers.
Make a mark on the input shaft of the transmission and another mark on the output shaft.  Then put the transmission in 1st gear and count how many times the input shaft goes around to the output shafts ONE time.  If the 5 speed goes around 10 times to one time for the output shaft in 1st gear, then that is 10/1, and 7 times in 2nd gear it would be 7/1 etc.
You HAVE to have the numbers to figure out the ratios.
So you will HAVE to get both transmissions, mark the shafts and count the turns to get the ratio for each gear...OR that info (transmission ratios) may be available from a dealer.
But you MUST have:
Engine RPM
Pulley ratios
Transmission ratios
Rearend ratio
and, last but not least the Tire Diameter.
Once you have those numbers, then input them into the formula I furnished:
EngineRPM÷RearRatio÷TransRatio×TireDiameter÷336.13524=MPH
If, for example, you have 4,500 Engine RPM/8=562.5 engine RPM
562.5/6
Rearend ratio of 6/1
Transmission ratio of 5/1
and a Tire Diameter of 12 inches
then we would do 4500/8=562.5
562.5/6=93.75
93.75/5=18.75
18.75*12=225
225/336.13524=.6694 MPH
Less than ONE MPH @ 4,500 RPM engine speed.
So, get rid of the 8/1 and make them 1/1 pulleys.
Then the MPH would be 5.355 MPH
Change the rearend ratio from 6/1 to 2/1 and then you have 16.065 MPH @ 4,500 RPM engine speed.
Then change the transmission ratio to 1.5/1 and your MPH would be:
53.5499 MPH @ 4,500 RPM's of engine speed with a 12 inch tire.
4,500 RPM engine speed (w/1/1 pulleys) + rearend ratio of 2/1 and transmission ratio of 1.5/1 with a 12 inch tire = 53 MPH
Put different numbers into the formula, John.  It will work every time.  It is simple, 2+2=4 every time.
I used to use that formula a lot when I was drag racing years ago.
You can use a regular calculator, use the one in your computer works fine, and just do them one step at a time.    Try it, figure out some ratios, John.
And, like mowerracer said, 45 to 55 MPH is pretty improbable without having an engine putting out a LOT of horsepower!
And it would take so long to get up to speed too, because of lack of HP.
You might try it with a 3.5 rear ratio to start with and that will be about 30 MPH and see what that is like.
Ken
122910 1438
Jan 15, 2011. 10:06 PMJOHNTHEREDNECK says:
finally got the ratio from the tranny 6 turns of the shaft = one revolution of the tire the tire is a 12.5 . so i think i got the math rite but im not so good a math either motor 4000 8to 1 means 32000 on the input shaft of the tranny = 5333 of the tire in 5th gear rite ? for every 1 turn of the motor im getting 8 out of the in put shaft on the transmission .
Jan 16, 2011. 1:01 PMJOHNTHEREDNECK says:
thanks for the equation !
Jan 1, 2011. 7:28 PMJOHNTHEREDNECK says:
thanks just trying to get an idea of the speeds im attaining ill be putting a 18hp briggs twin on it once i race the twelve horse for awhile
Jan 15, 2011. 10:10 PMJOHNTHEREDNECK says:
im following the guide lines from NELMRA im going to run in the prepared class when ever i finish this project.
Aug 24, 2010. 11:48 AMmud-dawg96 says:
there is a speed calculator for go karts, or anything really, if you go to http://www.diygokarts.com/
Aug 9, 2010. 8:20 AMKen Chevy says:
  No problem.  I put the math there so anyone, including you, can follow the steps and figure out your ratio's and MPH@RPM.
  If you change your axle sprocket to a 24 tooth, which would make it  2:1, then you could obtain 50MPH at 6,111RPM if you had enough power.
  It looks like it would be fun.
Ken
080910 0820
Jan 6, 2009. 7:38 PMmossimo3 says:
Is it at all possible to make the mower run fast by still using only stock parts? At this point I'm not looking to make it an extreme racing mower, just something fun to ride around in that goes somewhat fast. Also: Would a 1/4 inch steel plate be sufficient in preventing harm if the flywheel explodes?
Aug 8, 2010. 10:00 AMac-dc says:
No way it's getting through 1/4" steel, BUT the mounting of that steel to support members, bolts or welding/etc is the weak point. Bits of metal may still fly out somewhere around the plate at high velocity.
Jul 4, 2009. 5:45 PMtraxxasman says:
About how much did u spend building this not including the mower, im a freshman and am on a tight budget?
Apr 20, 2009. 5:24 PMderekonderdonk says:
What is your tire and rim size? Complete sizes. _X_X_. Thanks.
Apr 24, 2009. 12:43 PMjoecrap says:
Was it these rims: "6 X 6" diameter VanK Wheel - Powdercoated Black Finish/2.5" Backspace"?
Apr 20, 2009. 1:34 PMpnelson_89 says:
i have a toro 910 idk what year? would that be a good lil runner sence its so small?
Apr 20, 2009. 1:41 PMfossheim13 says:
do yuo know abaot som other easy tings i kan do to make it go faster
Mar 31, 2009. 7:56 AMfast-dude says:
how fast does yours go?
Apr 20, 2009. 1:33 PMpnelson_89 says:
Apr 1, 2009. 11:34 AMchivesg5 says:
i do not no i no it is 11hp
Apr 20, 2009. 1:40 PMfossheim13 says:
Mar 31, 2009. 5:23 PMchivesg5 says:
you took the gavaner off that way did it not blowup
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:mowerracer
