loading
Step 3: Cutting your paper
I used TechShop's epilogue laser cutter to cut my paper. I was making 2000 blocks. If you are only making one, or a few, using scissor may work for you.
To cut with scissors, simply follow the outline of the piece.
To cut with a laser cutter, make an outline path in illustrator. Stack the paper in the bed of the laser cutter. I did stacks of 10 to move quickly, but prevent fire. Too many pieces of paper will make it very easy for the stack to catch on fire, because it will contain many pockets of air.
<p>it's suky</p>
<p>the minecraft tools</p>
<p>did u make the tools or did u buy them</p>
cool!!!!
you minecraft ppl need to make a minecraft creeper costume and couch!!!
we had a creeper costume at the gallery opening we had
how i do the tools? like the pickaxe or the shovel?<br><br>
poster board and a print out of the tool
Actually, it was laser cut plywood so it would have some durability <br> <br>I then also laser cut paper with the graphics printed on it, and then glued them together
Nice! I can see these being used to model before building them in-game.<br><br>One thing I have to point out: that would be &quot;Voila!&quot;, not &quot;Viola!&quot;. A &quot;viola&quot; is a musical instrument, &quot;voila&quot; is a french word meaning &quot;there it is&quot; (the expression you're probably trying to use).<br><br>...Sorry, but I get all OCD over spelling and grammar...
lefts just blame that on my spell checker....
I have a suggestion for attaching the paper to the cubes. Instead of using spray adhesive, perhaps mod podge or white glue might work better by deco-pauging the paper to the cube.
Thanks for the suggestion!<br>I actually did this on the generation 1 cube. (the generation 1 cubes were made of styrofoam instead of wood). The issue with white glue is that is got the paper all soggy. The modge podge also got it soggy. We had the best results with a product called Yes paste. It had the consistency of what would go in a glue stick but it was in a jar. The reason we changed to spray adhesive was time. It would take about 90 seconds to use any non spray adhesive. It would take about 10 seconds with the spray adhesive and you could spray multiple paper pattern at ounce. When you are making over 1000 cubes, anything that saves time is the best choice!
I see. I was mainly thinking of using modge podge or such to add a bit of protection to the paper on the cube. Perhaps they could be varnished to make them more durable?
A very sound idea. I tested it and found that i offered a bit of protection, but not enough for the amount of time it took to apply it to the cube. maybe dipping the cubes perhaps?
How did you make each of the tools? or rather to what scale?
the tools were laser cut printed paper affixed to laser cut wood. They were about 3&quot; long.
i've noticed that the minecraft cubes u made r tiny (small enough to fit on ur laptop) hav u ever made a giant one?
The first iteration was to make giant minecraft (1-meter, actual size) minecraft cubes but we found that they were giant and unwieldy. We wanted an experience of mining, and if we scaled down the cubes to 1/16th the size of a meter cube (1/16th = 1 pixel on a 1 meter minecraft cube) we could have a much more fun and interactive experience. That being said, Discussions are happening about making an iteration of this project with approximately 1ft cubes...
yea i guess after u made a bunch of them u would wonder where to put them and stuff, but it still would be cool
We are in agreement then! Life sized cubes would be very cool!
it would also b cool if u made a mountain or something out of life sized cubes. then when ppl pass it they're like &quot;hey whats that? a mountain?&quot; and u reply &quot;yea i made it&quot; :P
wow! great job!
Thank you!
I think you mean 2.5', not &quot;. &quot; signifies feet, not inches. Other than that, cool 'ible.
No, &quot; means inches and ' means feet
Oops! Sorry for the confusion (I think it may have sprung from my old D and D books, in which &quot; are feet and ' are yards).
Thanks for the Cool'ible. I think you may be mistaken on the inches/feet thing though...
These look fantastic! Maybe with some little magnets embedded in the sides, one could make a set of blocks that would stick together and be rearrangeable.
The idea has been considered. The issue would be the amount of time to inlay the magnets...and the cost. Rare earth magnets do get to be a little expensive when you have to provide 6 (for each face) for 1500 blocks....but since these are technically the general 2 cubes, magnets are being considered for generation 3.
About This Instructable
36,952views
144favorites
License:
More by code_neon:How to fix that mess, or how to organize an extension cord DIY "for the fun of it" Death Ray (part 1) Cutting plastic the hard way
Add instructable to:
