3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a survival paracord belt using only two cords!
I saw at an online army store a really awesome paracord belt.  It packed in 125-200 feet of paracord.  Well mine doesn't pack as much paracord, but it looks almost the same!
This version is a very smooth one.  It goes through the belt loops very easly if you tighten the paracord a lot.  This belt unravels to about 50 feet of paracord.  You could easily weave this into a hammock if you wanted too.
There is not many steps because I crammed all of the braiding instructions on one step.
Step 1
All you need is:
-(two) 50 feet of paracord (two different colors)
-(two) D-rings
-Webbing (Check the picture notes)
19 comments
Dec 5, 2011. 4:23 PMdrumsetmonkey says:
Ha I made a belt 100% from paracord. Pain in the butt. Because it pushes up its just annoying.
Oct 21, 2011. 2:54 PMpunkhead58 says:
Weaving the cordage around the belt is a great idea. That way, you can use the paracord without your pants falling down.
Jul 1, 2011. 11:14 AMusseryscoutleader says:
Great Idea! I just finished a similar version based on your plan. I bought an OD Green belt with 2 D-rings already attached. Marked with tape where I needed to stop braiding. It made a flat belt and added 3/8" of width to the original belt, which still fits in my scout pants. The fastening part of the belt could not be braided because the D-rings wouldn't handle the extra width. Not a problem, I'll just shorten the extra webbing to fit. I feed the tightening loop backwards thru the D-rings and the flap is concealed to the inside of the belt instead of being on the outside. Try it!
I also like it because I have 88' of uncut single color of cord, and I still have a belt. It looks nice and it does feed thru the loops easily as descriped. I found this method to roughly equal 2' of cord per 1" of braid.
Very nicely done! My next belt will be two colors!
Jun 28, 2011. 9:58 PMdave72 says:
this isnt workin for me. yinz need to have directions or some better pictures
Jun 3, 2011. 10:51 AMmysss says:
I think this idea is really nifty because if I undo my slatts rescue belt, I don't have a belt anymore, but if you undo your belt, you do! It should be noted that a lighter works WAY better than matches for melting the ends simply because it's far easier to avoid being burned. Also, if you melt the ends of the cord TO the rest, you're very likely going to need to cut it when you untie the belt. One more reason for always having a knife with you, I guess. It might even work better to use hemostats (like $4 on amazon :D) or needlenose pliers to pull the ends into the core of the knot (as illustrated in other solomon bar/cobra weave instructables). Then all you have to do is pull the ends out, plus it might look just a little bit better with no ends showing.
Jun 1, 2011. 7:18 AMCount Almasy says:
Just what I was looking for, going to try it this weekend. Thanks for the post.
May 17, 2011. 6:47 PMrgreene3 says:
You can increase available paracord length by using 15-20 lengths of cord as the core instead of the webbing.
Mar 26, 2011. 2:55 PMjbabcock1 says:
is it really necessary to double the webbing could you just loop it though the D rings and just have a few inchs say 5 or 6 of it doubled ?
Feb 20, 2011. 9:57 AMChanio says:
Perfect!
Your project gives form to what I was envisioning...
I am planning to do the same but to wrap my bicycle's top tube.
The idea is to change just a little of your project to achieve this:
Instead of using two cords, I'll just use one that would fold in two!
This way, when required, I could unweave it all and have a single cord!
Instead of using the webbing, obviously, I'll be using the bicycle's top tube...
I'll try to publish my finished project when done.
Thank you, again!
Nov 4, 2010. 12:55 PMlebeef143 says:
Can i Make the belt wider anyway? maybe not as tight? Will it still work if i do that?
Jun 20, 2010. 11:58 AMAlecGoodwin says:
Do you need 2 fifty feet cords or 2 twenty-five foot cords?
May 2, 2010. 8:49 PMjeffconnelly says:
 How would this be woven into a hammock? Or am I misunderstanding?
Apr 13, 2010. 7:22 PMMeegles says:
Go building king go!  Your hard work shows!  AWESOMENESSISSITY!
Apr 9, 2010. 3:42 PMFantasticFour says:
Good pictures, keep posting!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
60
Author:building king
Hmm... I am thinking about posting an instructable every week. Please tell my why I should in the comments. You are also welcome to give me any ideas for my next instructable.
