3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a ring from cast off copper pipe
How to make a stylish ring from piece from 3/4" copper pipe.
Made with inexpensive plumbing tools, polished with available materials.
Step 1Aquiring materials
Aquiring materials
You need only a few things to make this ring:
  • Copper pipe. 3/4" pipe makes approximately a size 9 or 9.5 ring.
  • Something to cut copper pipe. I use a pipe cutting tool, but a hacksaw would probably work.
  • Something to remove sharp edges. Sandpaper, a file, or a dremel should work.
  • Something to polish the ring. You could try several grades of very fine steel wool, or fine sandpaper, followed by a polishing cloth, or a dremel.
53 comments
1-40 of 53next »
Dec 4, 2010. 7:03 PMzombiekiller42 says:
Is there a cheat sheat for the ring to pipe size? I wear a 13 in rings thats like
22.26mm\0.876in I think. I ask because I don't feel like going to lowes and shoving my fingers into pipes again.
Dec 4, 2010. 8:05 PMzombiekiller42 says:
Sorry its not sheat its sheet
Sep 7, 2010. 8:29 PMdac01220 says:
I think that one may also try copper fittings for an in-between size, they are slightly bigger then the too small, but still slightly smaller than the too big.
Apr 29, 2009. 2:05 PMdustfingersilvertounge says:
CHEAP
Mar 9, 2010. 7:20 PMAlgag says:
 off topic...but slightly obsessed with the ink series?
Dec 22, 2009. 8:49 PMgilleseg says:
I just purchased a 3/4 inch copper coupling for this project.  My fingers are rather large and this fit me the best.  If you are looking for a somewhat larger size that the 1/4 inch you might try the coupling... Also I am going to try some simple engraving with my diamond tip dremel attachment.  I may do simple lines or circles or something.  Cheers and thanks for the instructable, its great!
Oct 5, 2009. 6:50 PMZeppelinfreak says:
Wouldnt the ring make a big green patina ring around your finger?
Dec 19, 2009. 4:08 PMabvnatter says:
Yes it does.  if you coat it clear nail polish it should keep the copper from oxydizing on your finger.
Nov 14, 2008. 8:56 AMfreerunnin1 says:
haha ur finger will go green, i did this before and that happened to me...
Jan 30, 2009. 6:01 PMguitarman63mm says:
If you lacquer it, it will keep the metal from oxidizing.
Aug 1, 2009. 8:06 PMberky93 says:
does regular polyurethane work I know its usually meant for wood... I've also heard clear nail polish works.
Aug 1, 2009. 9:09 PMguitarman63mm says:
Poly is a bit messier and in my experience, more finicky than lacquer, being a plastic. Clear nail polish is essentially the same thing as lacquer. Nail polish remover = acetone = lacquer thinner. If you try poly, good luck; you'll need it.
Aug 1, 2009. 11:06 PMberky93 says:
well I was only asking about polyurethane because I have that on hand, but I just realized that I dont have any pipes the correct size so I have to go to the hardware store anyway.
Sep 20, 2009. 8:20 AMDrCoolSanta says:
I tried nailpolish, sticky and it remains sticky forever and becomes irritating on your fingers. My ring is clear in the morning and by the night it becomes greenish, the finger too looks kinda wierd but i don't care.
Mar 30, 2009. 1:07 PMSG1Oniell says:
lol, didn't think that through eh? using your left hand to take a picture of your right hand with a right handed digital camera.
Mar 6, 2009. 1:32 AMOrionBlade says:
I used to use ball peen hammers of various sizes to stretch rings I made. clamp one hammer, ball side up, in a vise, and put the ring on the ball, then put another hammer on top, ball side down. You wind up with a C shaped cross section that you can then flatten back out by inserting a rod and hammering the ring between the rod and hammer. This works great, but remember to anneal after every pass. To shrink, get a jeweler's doming block - hammer into the dome, flip, hammer again, then flatten with the same technique. This will shrink the circumference slightly. Good for getting half sizes to a size or so. to go real wacky with size, slit the tube, overlap, and use an oxyacetylene or oxypropane (or even oxy mapp) torch to weld the copper back together - leaves a huge bump from the weld bead, but you can just file or grind that down. I'll post an instructable about how to do a welded ring soon, maybe even a forge welded steel ring too! good work on the cut and polish - wonderfully simple and quite pretty.
Jan 31, 2009. 12:31 PMDr Science11 says:
I did this at science olympiad today (school science thing) with a leftover bit of pipe. I used a grinding wheel to shine/even it out, and used a dremel to round out the edges. I placed the ring on a dowel rod and pressed it to the grinding wheel, so that the ring spun around the dowel and against the wheel. question about tinning it with solder to resize it smaller, how exactly would you do that? It's too big for my ring finger at the moment, and although i have an iron and such i wouldn't know how to do that without making a mess. Thanks for the tips!
Oct 13, 2008. 4:20 PMdavidcarr3 says:
A 22mm olive fits my fingers perfect and is already convientiently shaped. just throwing it out there....
Sep 18, 2008. 7:24 AMTroutful says:
Thanks for the great instructional. I tried this last night, and had a ring in about 20 minutes. I applied some additional techniques that my dad, a master plumber, taught me over the years. I thought I'd share them. 1. If the pipe you are cutting from already has a burr or lip on the inside edge from a previous cut, it's easier to remove this before cutting the length for the ring. It's also easier to clean it first this way. Think of the rest of the pipe as a clamp to hold your ring-to-be in place. 2. An excellent tool for polishing is a fine steel wool. I used aluminum sandpaper (don't know the grip, just this strip that my dad uses for plumbing) followed by steel wool. The steel wool not only polishes the surfaces, but does a good job of putting a final touch on smoothing edges. I have thin fingers like the author, and the ring it on my middle finger. I am replacing my lost wedding band, so the final product will have to fit my ring finger one way or another. My first try would be heavier grade tubing. I wore it to bed to test out the green factor, and yes, I do have a green mark from about 6 hours of wearing it. Silver solder on the inside might help this, as someone else suggested. I may be able to tolerate the green finger, but what I don't like is the smell of it. I'm used to wearing a rose gold ring (gold & copper that looks like copper) that didn't have any odor to it. So in order to wear a copper ring, I would have to try out that oxygen-free copper someone mentioned. Thanks again for the great idea!
Mar 25, 2008. 4:04 PMmkamchin says:
is there any way that you could change the size of the ring with out buyig a different sized tube
Jun 1, 2008. 8:42 PMtheRIAA says:
i made one in jewelry class. If the ring is SLIGHTLY too small you can use a ring stretcher (like a stepped cone that you pound a rod into to spread out), and annealing doesn't hurt (red hot, left to cool) it's also very easy to make the ring smaller, just slice off a chunk, squeeze it closed, slice off both ends with one cut to even out the ends, solder, file off excess solder, pound round on a ring mandrel (skinny cone), and polish... I guess it's easier if the jewelery department at your school rocks
Apr 8, 2008. 5:04 AMkillerjackalope says:
You could probably stretch it out a bit since copper is quite malleable but finding something that wont warp the circle would be hard, I suppose you could do it in a few steps witha conical stretching device of some kind... Or heat it enough to make very malleable and use a bar of the right diameter with a taper to get the copper in, however you'd have to get the ring back off again before it gets cool or you may wreck it.
Jan 28, 2008. 9:11 PMWTSerpent says:
I made a copper ring about a month ago, and was surprised to find this. i had done almost exactly what these instructions say. however, i happen to have a ring anvil and a ball-peen hammer lying around. between steps 3 and 4, i lightly hammered the ring to produce an almost golf ball-like texture. to polish it, i used emery cloth. a little while after i made the ring, i was reaching into a cupboard and bumped my hand, and the edge of the ring scraped my skin. though it was a minor wound, it was painful for a while afterward. to avoid this problem, anyone making a ring could file out the inner edge, and/or use nail polish. i have made several more rings since, and both methods seem to work. i was thinking about using brass instead of copper, it doesn't seem to turn your finger green.
Jan 28, 2008. 2:42 PMkimro says:
yea it will turn your finger green I made a ring a cupple days ago from some copper wire ( using the a Simple wire ring Instructable in the related menu right below this) and mine was vary green by the end of the day (but I'm about as white as they come)
Nov 11, 2007. 3:26 PMsmokehill says:
One warning about a copper ring -- if you have a job or hobby where you may get something heavy dropped on your hand, a soft-metal ring may not be something you should wear (actually, for auto mechanics & others, rings are something that ought to be in your pocket during the workday anyhow). Aside from that little caveat, you might want to check out some of the different "flavors" of copper pipe available. Even though the cheapie joints like Home Depot usually only carry one Harry-Homeowner size of copper pipe, a regular plumbing store will stock several different grades ... I think the grades are K, L & M thickness. The thicker-walled pipes (which is what plumbers use on their own houses, heh heh), will have a smaller inside diameter, I believe, which will yield slighly different "ring sizes." Also, by using the repair couplings or copper joints (not just the tubing itself), you will get larger diameter "tubing," in effect. This should give you a better selection of "sizes" to work with. NIce instructable. With some imagination & basic tools, you could do some interesting decoration, perhaps, too. Drilling in just a wee bit, and either gluing in contrasting metal "dots" (brass?) or filling the cavity with silver solder? Scalloping the edges? soldering on small metal decorations? Engraving with a Dremel, or stamping in letters or numbers like machinists use (cheap sets in Harbor Freight). Nice ... and lots of ways to take it further.
Nov 11, 2007. 3:29 PMsmokehill says:
Another further thought for different sizing -- If you brazed or soldered on some sort of metal decoration, that would neatly hide a cut in the ring where you made it smaller ... and would give you a lot of brazing area to hold it together, not just the "ends" where the cut was made.
Nov 12, 2007. 5:44 PMsmokehill says:
Scalloping may be the toughest decoration unless you can rig up some sort of a jig to get even spacing & even depth. After seeing some custom knife decoration, I decided to play with my Dremel & some files to see if I could do the same to some of mine. Pretty feeble, uneven results, actually. Scalloping is one of those things that has to be really regular to look good, and tiny little mistakes get magnified. If I ever get the urge again I'll try to figure out some simple jig to keep it from looking like it was done by a drunken gorilla with a chainsaw. I've known a few people over the years who have lost fingers because of rings; they were serious accidents (motor dropping onto the hand), but the smashed ring actually did more damage than the motor because it cut off blood flow until the medics could cut it off. I don't work around anything quite that dangerous anymore, but I don't wear my softer alloys (24K, 22K) or rings with thin shanks while working with equipment. Changing motor mounts seems to be one of the most ring-dangerous projects, so I won't wear any jewelry at all for that.
Sep 22, 2007. 9:58 PMteresajoy says:
Don't try to fit the copper pipes at the store, and get your finger stuck in them. This could make a for long conversation with the paramedics on the way to the hospital.
Jul 29, 2007. 12:45 PMNaruto_Uzumaki says:
If we cut a slit we can bend it to the size that we like. Can that work?
Jul 28, 2007. 12:21 PMMurdok says:
You could just line the inside with electrical tape (or something like it) so it won't change your skin color. It might also make it fit better.
May 24, 2007. 4:33 AMironsmiter says:
and now, for the peanut gallery.... Body Chemistry has a LOT to do with weather the rate of copper oxidizing will exceed the rate of natural exfoliation... a coating of nail polish every few weeks should work ok, to keep the ring copper colored, and your finger skin colored. Another option is to get out the propane torch, and tin the ring with silver solder. the real stuff... NOT electronic solder. the plumbing flux will work well enough... you MAY lose a 1/2 ring size that way... you'll have to test it. It's ex-plumbing... use the tool designed for it... grab the pipe flare tool that is used to create the flanges, and stretch away :-) if you have a very large drift, you could also use it to expand/flare the ring. just drive it on through... the work hardening will be of benefit in holding the round shape, in the otherwise soft copper. If you want it shrunk or expanded cheap, safe, and easy.... talk to the local jeweler... often they'll do it for free, or a minor charge(takes about 2 min tops for 3-4 sizes change). For your "next" instructable, with the mini-project copper bracelet..... If you can, do it with Oxygen Free copper. the commercial copper/magnet 'lets are done with that...part of why THEY don't turn green on people :-) they darken to a rich shade of brown over time... if using castoff electrical wire... give it a good coat of varnish. should help.
1-40 of 53next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:sysiphus
