3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a round thing without a lathe (plus model making tips)
You want to make a model of something that you've seen in a film, but it's round and has lovely compound curves and you don't have a lathe. Don't worry, this instructable will show you how you can use a simple profile and some car resin filler to get a lovely round shape with out using any machines at all.
For me I used it to make this alethiometer from the book Northern Lights (aka the Golden Compass in the US) and shortly to be released as this Christmas's big hit, the Golden Compass. Which looking at the trailers is a mixture of Riven (the game for those that know), Steam Punk and a bit of Round the World in 80 Days thrown in for good measure.
Full instructions on how to use this instructable to make a Golden Compass can be found on my website dadcando here, including free printable templates for all the graphics and an accurate profile template guide.
But then you can make loads of round things using this method... I'm sure you'll think of them. Post pictures here if you do, we'd love to see them.
Step 1Make the basic shape
In this case I wanted a flat disc a little bit like a large ice hocky puck or in fact a pocket watch, to match the shape of the device drawn on the front of the book. I made my basic shape out of cardboard, but really you can make it out of anything.
Model Maker's TIP #1
If you model is of something that has weight, i.e. it is made out of metal, plan to fill it with some ballast. This will make the final model much more realistic and fool people into thinking that it has been made out of metal, or has more of a quality feel to it. But be careful not to stick anything over the centre hole area, you are going to need to be able to poke something through the card right there in the next step.
In this case I cut two discs and then used up right spacers to make sure they were at a constant space apart and then wrapped a piece of card round the assembly to give me the disc shape.
97 comments
1-40 of 97next »
Jul 2, 2011. 3:57 AMthrobscottle says:
This rocks! I shall try the technique to make pulleys!
Dec 26, 2010. 6:21 AMverdastel says:
A state of art indeed!
Mar 18, 2010. 7:00 PMunderkill says:
 Absolutely brilliant tutorial.
Mar 15, 2010. 9:00 AMjamwaffles says:
This is genius man!
Mar 17, 2010. 11:48 AMjamwaffles says:
well its been passed on in style. Also, i'm guessing this would work using a lost-foam (instead of lost-wax) technique?
cheers
Mar 15, 2010. 2:44 PMdoxsys says:
A laser cutter would be the perfect tool for cutting the profile to spec, if you have access to one.
Mar 14, 2010. 5:07 PMBlakeney says:
You are absolutely brilliant! I've been wishing forever that I had a lathe for small jewelry projects but don't have the money to buy one or the time for the learning process right now - will have to give this a try. I remember your Harry Pottter wand tutorial on dadcando - another amazing use of humble resources!
Mar 14, 2010. 2:15 PMiminthebathroom says:
Awesome - This is one of those instructables you go back to a year later when the need arises.  Its like the maker version of learning how to tie a tie.  Simple, yet elegant technique that breaks down a daunting task for the first timer.  Thanks!
Feb 4, 2010. 9:00 AMPatent Dragon says:
This could be JUST the technique I need for a similar prop device I have in mind. I'm sure that, once I read through the instructions several times, AND check out all the comments, I should have all I need to know. I discovered this instructable quite by chance, and I'm so glad I did!
Mar 14, 2010. 9:10 AMkaptaink_cg says:
Pretty clever!
Mar 14, 2010. 12:20 PMBroom says:
You're brilliant, your work is beautiful. Kudos! And thanks!
Feb 17, 2009. 4:00 PMmg0930mg says:
I found an error in step 10, the stuff is not free....
Feb 18, 2009. 12:03 PMmg0930mg says:
Cool, any new projects coming soon. Also do you know how much that would be in american dollars.
Feb 18, 2009. 5:47 PMmg0930mg says:
I may pay it if I get money soon.... sigh, although I do need to make some stuff to sell... ANYWAY, enough babbbling. My favorite projects, have to be movie props, or book props, or anything cool like that .I like a lot of your projects, almost all of them.
Jan 23, 2009. 10:57 AMcowscankill says:
Haha! I found another error! Step 8, I can almost each it xD
Jan 23, 2009. 10:58 AMcowscankill says:
And step 10, prpping you work piece.
Jan 3, 2009. 1:10 PMmweston says:
After step 7 you could get a machine screw and nut then place the screw through the center hole and tighten it with the nut. Put the remaining screw in a drill and use it as if it were a lathe to sand down the sides and top - I did this all the time when I made circular wood... thingys Cool project otherwise, the bondo mold was pretty creative!
Jan 3, 2009. 12:15 PMAnarchistAsian says:
woahhh, my sister would like this too... curse you for making stuff my sister likes
Apr 23, 2008. 6:17 PMRaisedByRobots says:
I'm impressed by your ability to make such a uniformly smooth object out of this stuff. After an hour of sanding, mine went from looking like a stone birthday cake to a crude pitted wheel made by some prehistoric tribe. I guess I need Sanding 101 or Bondo 101 class. It would be interesting to see a video of how you did the bondo step. You made it look easy, but I'm finding it isn't.
Apr 26, 2008. 2:14 PMRaisedByRobots says:
Here is a video of the thing in action. Like all magical devices, it is frequently reluctant to work until the energies are right. :)
Well, I finally did it. I could not resist trying to make it "work" (fingers making quoting gesture). So, here it is. I had to enlarge the pattern to allow for the workings inside (composed mostly of a pc fan and a meter needle from an old analog meter). I could not achieve the beautiful perfection of your finished piece. I struggled quite a bit with that. Maybe I could come up with some sort of old beat up tarnished look for it to make the blemishes just look like wear and tear. To your instructions I would add that the detergent bottle plastic for the profile is more of a necessity than nicety. I didn't get a clean edge as you mentioned until I used that. I also used a mask while sanding the bondo, which is good because I found that my entire work room is coated with a fine particulate dust of the stuff everywhere! So, if I were to do it again, I'd try to cover everything up with some cloth or something first. When I get a little more time and motivation, I am going to redo the faceplate and figure out how to make the crown glass part come out right. I just need to purchase some ink jet transparancies I think.
Apr 27, 2008. 8:18 AMRaisedByRobots says:
Yes, making things from junk is a great idea. The thick plastic of the detergent bottle worked great and was flexible and soft. Acrylic is too hard to cut I think, for me it shatters. The computer fan inside the contraption is powered by a little 9 volt rectangular battery. Turns out I only need one moving hand for it to work "correctly", so I might revamp it to work the way it's supposed to. I was at a loss as to how to solve the problem of the opening in the back/bottom for putting the parts in and changing the batteries. So I just put a thin wooden sheet in the back that I could lift in and out, but it doesn't look so nice as yours does. Ooh a contest, love those. Thanks, I'll keep an eye out on your site.
Apr 21, 2008. 2:24 PMRaisedByRobots says:
I'm trying to find the filler you mention: two part auto body repair filler (resin car bodywork filler). Does it have a brand name?
Apr 23, 2008. 3:59 PMRaisedByRobots says:
Thanks, I found some bondo auto filler two part stuff at the auto shop for $11.00. My god, how do you cope with the vapours? I wore a new two cartridge organic vapor mask and I could still smell the ghastly heady smell of the bondo through it, while working outdoors. Phew!!
Apr 18, 2008. 7:38 AMbenide says:
Great instructable! Thanks, I think I'll use your tips this weekend. BTW, I've found that I can get a really smooth sanding job by using a piece torn from a paper bag. It like the equivalent of P1200 -1400, and very cheap and easy to obtain.
Jan 27, 2008. 8:19 PMGorillazMiko says:
I forgot, what was the program you used again to make the awesome pictures? And how do you take such great photos, they're awesome!
1-40 of 97next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
333
Author:KaptinScarlet(dadcando)
Eldest of five, son of two doctors, 10 years in Graphic Design and marketing, then retrained as a Biomedical Materials Engineer, don't ask me why, I think it was because I had always wanted to design ...
more »
