3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a runaway cookie box
Eat too many cookies? These are some guidelines for how you can add a few security features to an ordinary box of cookies - or at least have a fun toy.
The runaway cookie box will roll away when objects approach it and sound an alarm when it is picked up.
What you need for the craft side of things:
-empty cookie box
-wheels (4)
-Legos (axles, gears, basic)
-hot glue
-electrical tape
-popsicle sticks, colorful straws, googly eyes, or whatever you want to give your box some character
What you need for the computing side of things:
-Arduino
-hacked servo
-tilt sensor
-distance sensor
-speaker
-resistors (2x100K&, 1x100&)
-breadboard
-wire
-wire strippers
-soldering iron
-solder
[This project was done for Olin College's Computing & Craft class, taught by Dr. Amon Millner.]
Step 1The Circuitry
The Circuitry
During this step, you'll set up all the circuitry required for the project.
First, connect the Arduino's 5V power and ground pins to the bus strips of the breadboard.
Second, connect the tilt sensor to the breadboard. Connect the wires on one side to the power strip and the wires on the other side to a 100K& resistor going to ground as well as to digital ins on the Arduino (in this case I used 3 and 4).
Third, connect the three distance sensor wires: red to power, black to ground, and yellow to an analog in on the Arduino (in this case, I used A0).
Fourth, connect one of the speaker's wires to ground and the other to a 100& resistor connected to a PWM digital in on the Arduino (in this case, I used 5).
Last, connect one of the hacked servo's wires to ground and the other to another digital in (in this case I used 9).
3 comments
Mar 2, 2011. 11:31 AMamonmillner says:
Nice work Schmegano! I was wondering where my girl scout cookies went.
I like how you've introduced one way to make this project and offered suggestions for possible directions others might take. I'd like to offer another possible direction - make your own tilt sensor.
You crafted your tilt sensor using the colorful straws, a balled up piece of foil, and paper clips (poking two paperclips through each end of the straw so that when the straw is tilted, the foil ball inside lands between the paperclips and completes the switch). Others could try different ways of making a tilt sensor - such as hanging a magnet near a reed switch and making the string swing the magnet away from the switch when tilted.
Mar 1, 2011. 8:52 PMkelseymh says:
Great project, and a nice writeup, too!
In the last step, you can make the YouTube URL an active hyperlink by using the "Link" icon in the editor (it's the globe with a little chain).
Also, you should be able to embed the video directly in the step, provided you click the little "Use old embed codes" box and don't check the "enhanced security" box on the YouTube page.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:schmegano
