It uses a Shopping cart as a rugged, mobile platform. A Car-audio amplifier works great with a Car-battery, and some decent ordinary Speakers seal the deal. A built-in battery charger ensures that you never forget to respect your fragile battery, and a Mixing board (that can handle 12V DC) allows you to add a microphone or two, taking the concept to the next level.
To do movies, get a second shopping cart, a second GOOD battery (and charger), an inverter (keep AC power wires away from Sound wires) and a place to set your laptop, DVD player, projector, and portable screen. If that battery doesn't have enough juice to run the projector through the whole movie, at least the soundsystem will keep the party going. (maybe jumper cables from the soundsystem's battery...)
Remove these ads by
Signing UpStep 1Diagram of parts (not including cart)
If you don't have a Mixing board, you only get the one input of the amplifier - and you can't use it for a microphone (because a microphone needs to be pre-amplified by a mixing board). If you decide to add a Mixing board, you will need one which can be powered by 12 volts DC. Vestax and Gemini make mixing boards which say 15 or 18 volts DC but they will work fine on 12 volts. You will have to get the plus and minus wires correct on the first try though, or you will blow it up. More on that later.
Enter "The Hobo Hifi"
All our photos are on our facebook page, http://www.facebook.com/Hobo.HiFi
We have blown nearly 10 speakers making ours, its one of those, its not loud enough, get a bigger amp, oh our speakers are blowing, buy better speakers, oh its not loud enough, buy a bigger amp..............
we have kept it pretty budget, are are slowing creating a hobo franchise, with the Hobo Hifi, the Hobo BBQ, the Hobo Brew. ( music food ( spit roast ) beer ( home brew kegs ) ) and about to make Hobo Tendo so we have have summer mario kart tournaments in the park.... that will just be another battery inverter snes and a tv, that should keep us entertained while we plan the 12v Projector for movie nights.
yay for portable tunes!
See my efforts here: http://www.wheelbarrowsoundsystem.co.uk/ for making a portable sound system.
If you want to make a system that can be run at high spl (loud enough to party to) you need to achieve efficiency.
Do not use AB class traditional car amplifiers. seek out more efficient class D amplifiers.
working from a low voltage, high current source (e.g a battery) it is worthwhile seeking an amplifier that is capable driving low impedance loads - down to as low as 2 ohms.
I'd recommend using a greater number of smaller drivers to increase the radiating area - for example:
using 4 x 8" drivers on bass will give you a larger radiating area over a single 15" driver will give you 13% greater radiating area. it will also be possible to wire the drivers in parallel to present your amplifier with a low impedance load to make the best advantage of the high current source that is a battery supply.
when using multiple drivers in the mid range and above ensure the radiating centres (the middle of the drivers are within 1/4 of the wavelength of the crossover to any HF (tweeter etc) device.
Cost - £Lots, 0/10
Theoretical electrical - 5/10
Actual operating time - 8hrs 8/10
Funkiness 10/10
Time to assemble - 2 years 1/10
Time to assemble by a random Instructables reader - INFINATE 0/10
Time to acquire materials - none 8/10
Roundness of speakers - (ERM mine are round) 10/10 If you are referring to 'the sound' then that is a very subjective thing. to my ears its good. The frequency response is not perfectly flat, but then that was not really my objective.
Correctness of phasing over the audible range - I'm not sure you know what you are talking about here. If you are asking if the speakers are in phase with each other at the cross over points, then yes. (or as close as they realistically can be without some DSP). the speakers in the different bands have their own individual transfer functions, as long as the outputs are in phase at the cross over points - bass - mid and mid - high then all will be cool.
Beer carrying capacity - 1 pint - 4/10
And for bonus points: running-from-the-cops-over-terrain contest! - 4/10. it may be a wheelbarrow, but its not fast!
really like what you have done with your system. Mine will never be finished.. I've always got new ideas and things I want to improve/change.
If you'd like to be kept abreast of the developments join the wheelbarrow sound system facebook group! - http://www.facebook.com/group.php?gid=10337113819
I am planning an event over here in the UK that will be the wheelbarrow sound system VS (an as yet unnamed opponent)
