How to Make a Simple Batch Game (trivia!)
Published
Introduction: How to Make a Simple Batch Game (trivia!)
HI
Today i'm gonna show you how to make a trivia game with Batch. Since batch is kind of limited, some awesome features that you may be thinking of may not come true. That's just how it goes. Hopefully my steps, to you, are simple and easy to understand.
Step 1: Making the Main Page
Ok, like all games, they have a main page(menu). Use all your text pictures-making skills and make it nice and beautiful. Ok, for those who have not much skill in this batch script, input this code:
Firstly, start with a @echo off (duh)
@echo off
Then, add a title
@echo off
title The Trivia Game
Now, add the main title(that will be shown on the screen) and a label
@echo off
title The Trivia game
:Main
echo.
echo.
echo                          ------------------------------
echo                              Trivia Game
echo                         --------------------------------
echo.
echo.
Your script should now look like this^
Now, add the selection part. This is slightly trickier
@echo off
:Main
echo.
echo.
echo                    Trivia Game
echo.
echo.
echo                    Type A and press ENTER to play
echo                    Type B and press ENTER to see instructions
set /p input=COMMAND?
if %input%==a goto PLAY
if %input%==b goto instructions
You will use the selection code you used here for all the questions.
Ok, thats basically it for this step.
Step 2: Making a Score System
@echo off
:Main
echo.
echo.
echo                                    Trivia Game
echo.
echo.
This should be your script so far.
Ok, lets get into some explanation.
1. What is set /p?
Ok, in simpler terms, is kind of like setting up a question.
2. If? What is 'if'?
'If' checks a condition. So 'if' the input is a, it will transport you to the label 'a'. Getting it so far?
3. What's with the percentage marks?
If a word is surrounded with these percentage marks, then that means it is a variable.
Now, this step I am going to explain how to make a score system. A bit tricky to the novice scripter.
Firstly, we shall use a 'set a/'
set a/
Then we shall type in a bit more to the 'set /a', as shown below. The score we will set is how many questions done. This will be abbreiviated to 'qdone'
set a/ qdone=0
Pretty simple. Next, I will show you how to add points to the 'qdone'. We shall use two labels. The first label is the question.
:Q1
echo                         ----------------------------------------
echo                                   What is a boat?
echo                             [a-A water vehichle]                [b-A land vehicle]
echo                             [c-A truck]                        [d-An animal]
set p/ input=ANSWER?
if %input%==a goto score1
if %input%==b goto wrong
if %input%==c goto wrong
if %input%==d goto wrong
goto error
:score 1
set a/ qdone=%qdone%+1
echo Congratz, you have completed %qdone% question(s)!
echo Press any button to go to the next question!
pause>nul
goto Q2
Ok, thats basically it. Let's get into explanation.
1.How does the set a/ qdone=%qdone%+1 work?
Well, its like resetting the variable, except adding 1 more point.
2. What is the bold for, on the goto error?
Well, i'd just like to point it out.If the command that was entered is invalid, it will go to the error label (that you will make)
Step 3: Finalizing
@echo off
:Main
echo.
echo.
echo Trivia Game
echo.
echo.
if %input%==a goto Q1
goto error
Ok, back to the main menu. We will now add the extra labels that are required (error, instructions, wrong)
@echo off
:Main
echo.
echo.
echo Trivia Game
echo.
echo.
goto error
:error
echo Dingbat! Thats an invalid command.
pause
goto Main
:instructions
echo Type instructions here
pause
goto Main
:wrong
echo Sorry, but...
echo YOU LOSE!!
pause
goto Main
:Q1
goto error
:score 1
pause>nul
goto Q2
:Q2
(Put question here)
Okay, thats basically it. Now, this step is UBER IMPORTANT
save it as a BAT file, so say your game is called trivia save it as trivia.bat
That's basically it! Add more questions, and a winning screen, and your done!
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
    22 Discussions
    Hey! I have biiig problem with the point system, I am using Windows 10 pro, and the command set not Works like yours. (When i will do command set a/ qdone=0 the placeholder in echo is %a/ qdone% and the if i will do set a/ qdone=%qdone%+1 it will display "0+1", well help me!!!
    Why does this not work?
    @echo off
    echo what is your name?
    set /p name=
    echo Hello %name%
    goto level1
    :level1
    echo elsa a boy
    echo A) True
    echo B) False
    if %select% == goto wrong
    if %select% == goto bye bye
    :worong
    you were wrong! sorry!
    pause
    exit
    :bye bye
    echo goodbye you were right!
    pause
    exit
    The reason why it wont work is because 1. wrong is misspelled 12th line on the code (technically 13 because of your comment but since were talking about the code 12th line.) And also
    this code is wrong it should be
    if %select% == A goto wrong
    if %select% == B goto bye bye
    And to avoid people cheating I would put this command in after it 'Goto Cheater' this is to prevent people from typing random things and they get it right. I hope I helped you.
    You can actually do
    :FamilyGuyQuestion1
    cls
    Title Family Guy
    echo.
    echo Who is the main character in Family Guy?
    echo.
    echo Peter
    echo.
    echo Glenn
    echo.
    echo Joe
    echo.
    set /p familyguy1=Enter:
    if %familyguy1% equ Peter goto CorrectFG1
    if %familyguy1% equ Glenn goto IncorrectFG1
    if %familyguy1% equ Joe goto IncorrectFG1
    goto FamilyGuyQuestion1
    Something Like this instead of using numbers for answers, works for menus too
    well i made my own one.. but its sure a good one..
    @echo off
    title Cooler Reyes Mini Game
    echo Welcome :D
    pause
    echo Would you like me to start the game? (y/n)
    set /p c=
    if %c%==y goto menu32
    if %c%==n exit
    :menu32
    cls
    echo Hi! im Dexter, how about you?
    set /p name=
    cls
    echo Nice to meet you %name%!
    pause
    cls
    echo What minigame do you want to play %name%?
    echo Math or Bignumber?
    set /p select=
    if %select%==Math goto mathquiz
    if %select%==Bignumber goto number
    :mathquiz
    cls
    echo You have chosen math %name%!
    pause
    echo Now you'll suffer!
    pause
    cls
    echo ok, first one :D
    pause
    echo 365+546?
    echo 1. 779
    echo 2. 911
    echo 3. 690
    set /p choice1=
    if %choice1%==1 goto lose1
    if %choice1%==2 echo You got me!
    if %choice1%==3 goto lose1
    pause
    cls
    echo now, more difficult XD
    pause
    echo 650+765?
    echo 1. 1334
    echo 2. 1565
    echo 3. 1415
    set /p choice2=
    if %choice2%==1 goto lose2
    if %choice2%==2 goto lose2
    if %choice2%==3 echo wooooow!
    pause
    cls
    echo your really good at this %name%!
    pause
    echo but not this time!
    pause
    echo 924+876?
    echo 1. 2000
    echo 2. 1900
    echo 3. 1800
    set /p choice3=
    if %choice3%==1 echo You won the game!! congrats %name% :D
    if %choice3%==2 goto lose3
    if %choice3%==3 goto lose3
    cls
    :lose1
    cls
    echo haha, you lose :D
    pause
    echo try again? (y/n)
    set /p kj=
    if %kj%==y goto mathquiz
    if %kj%==n exit
    cls
    :lose2
    cls
    pause
    set /p kj=
    if %kj%==n exit
    cls
    :lose3
    cls
    pause
    set /p kj=
    if %kj%==n exit
    cls
    :number1
    cls
    echo ok lets play the thing you selected %name%! Big number!!!
    pause
    echo type set to go to settings
    set /p sets=
    if %sets%==set goto settings
    echo choose a number 1-10
    set /p cnumber=
    if %cnumber%==1 echo i choose 2! I Win! Play Again? (y/n)
    set /p yorno=
    if %cnumber%==2 echo i choose 3! I Win! Play Again? (y/n)
    if %cnumber%==3 echo i choose 4! I Win! Play Again? (y/n)
    if %cnumber%==4 echo i choose 5! I Win! Play Again? (y/n)
    if %cnumber%==5 echo i choose 6! I Win! Play Again? (y/n)
    if %cnumber%==6 echo i choose 7! I Win! Play Again? (y/n)
    if %cnumber%==7 echo i choose 8! I Win! Play Again? (y/n)
    if %cnumber%==8 echo i choose 9! I Win! Play Again? (y/n)
    if %cnumber%==9 echo i choose 10! I Win! Play Again? (y/n)
    if %cnumber%==10 echo i choose 10! Tie! Play Again? (y/n)
    if %yorno%==y goto number
    if %yorno%==n exit
    cls
    :settings
    cls
    echo CHOOSE :D
    pause
    echo 1. I want me to always win
    echo 2. I want me to always lose
    set /p sets1=
    if %sets1%==1 goto number2
    if %sets1%==2 goto number1
    cls
    :number 2
    cls
    pause
    set /p sets=
    set /p cnumber=
    if %cnumber2%==1 echo i choose 1! Tie! Play Again? (y/n)
    set /p yorno2=
    if %cnumber2%==2 echo i choose 1! You Win! Play Again? (y/n)
    if %cnumber2%==3 echo i choose 2! You Win! Play Again? (y/n)
    if %cnumber2%==4 echo i choose 3! You Win! Play Again? (y/n)
    if %cnumber2%==5 echo i choose 4! You Win! Play Again? (y/n)
    if %cnumber2%==6 echo i choose 5! You Win! Play Again? (y/n)
    if %cnumber2%==7 echo i choose 6! You Win! Play Again? (y/n)
    if %cnumber2%==8 echo i choose 7! You win! Play Again? (y/n)
    if %cnumber2%==9 echo i choose 8! You win! Play Again? (y/n)
    if %cnumber2%==10 echo i choose 9! You win! Play Again? (y/n)
    if %yorno2%==y goto number
    if %yorno2%==n exit
    This is my code. It won't work, for some reason.
    Please reply.
    Sorry bout the spacing
    @echo off
    :Main
    echo.
    echo.
    echo Trivia Game
    echo.
    echo.
    if %input%==a goto start
    goto error
    :error
    pause
    goto Main
    :instructions
    echo This is a trivia game. Just do what you think you need to do.
    pause
    goto Main
    :wrong
    echo Sorry, but...
    echo YOU LOSE!!
    echo Now start over. You deserve another chance!
    pause
    goto Main
    :start
    goto error
    :score 1
    pause>nul
    goto Q2
    :Q2
    echo What is a duck?
    echo [a- THE BEST ANIMAL EVAR] [b- An ordinary animal]
    echo [c- A vegetable] [d-Something random]
    if %input%==a goto score2
    goto error
    :score 2
    set a/ qdone=%qdone%+2
    pause>nul
    goto Q3
    :Q3
    echo How do you make a cake?
    echo [a-Using the power of your MIND]
    echo [b- Using a recipe]
    echo [c- Go buy it] [d- Get your friends to make it for you]
    if %input%==a goto wrong
    if %input%==b goto score3
    goto error
    :score 3
    set a/ qdone=%qdone%+3
    pause>nul
    goto Q4
    :Q4
    echo 5 cubed= ?
    echo [a-15] [b-125] [c-250] [d-500]
    if %input%==b goto score4
    goto error
    :score 3
    set a/ qdone=%qdone%+4
    pause>nul
    goto Q5
    :Q5
    echo --------------------------------------------
    echo What file format does this game use?
    echo [a- .cmd] [b- .exe] [c- I don't even know] [d- .bat]
    if %input%==d goto winner
    goto error
    :winner
    echo Great job! You beat the trivia game!
    echo If you'd like, email this to your friends!
    echo Be sure to inform them that it can only be used on Windows PC's.
    echo Thanks for playing!!!!
    pause
    There are some errors in the coding
    I fixed them and this is the new one:
    @echo off
    :Main
    echo.
    echo.
    echo Trivia Game
    echo.
    echo.
    set /p input=
    if %inpu%==A goto start
    if %input%--B goto instructions
    goto error
    :error
    pause
    goto Main
    :instructions
    pause
    goto Main
    :wrong
    echo Sorry, but...
    echo YOU LOSE!!
    pause
    goto Main
    :start
    goto error
    :score 1
    pause>nul
    goto Q2
    :Q2
    goto error
    :score 2
    pause>nul
    goto Q3
    :Q3
    goto error
    :score 3
    pause>nul
    goto Q4
    :Q4
    echo 5 cubed= ?
    goto error
    :score 3
    pause>nul
    goto Q5
    :Q5
    goto error
    :winner
    pause
    By Q4 you wrote: set p/ input, That will NOT work you have to make it: set /p input.
    Make the / before the p!
    I tried all of the trivia batch files on this page and none of them worked, so I came up with my own. I tested it out like a million times so I know it works.
    Save as a batch file (.bat).
    color a4
    @echo off
    title Trivia game
    :Main
    set /p choice=Type A and press ENTER to play. Type B and press ENTER for instructions. Type C and press ENTER for credits.
    if %choice%==a goto start
    if %choice%==b goto instructions
    if %choice%==c goto credits
    :instructions
    echo Instructions: Type the letter of the answer you think is correct.
    goto main
    :credits
    echo Credits: This game was made by JAYFIN programing
    goto main
    :start
    @echo off
    set /p choice=What food group has the highest levels of proteint? 1: Bread, 2:Vegetables, 3:Meat, 4:Fruit
    if %choice%==1 goto wrong
    if %choice%==2 goto wrong
    if %choice%==3 goto correct
    if %choice%==4 goto wrong
    echo That answer is unacceptable. Try again.
    goto start
    :wrong
    echo Wrong answer try again.
    goto start
    :correct
    echo Answer correct.
    goto Q2
    :Q2
    @echo off
    set /p choice=Who said: "I'm the president of the United States and I'm not going to eat any more broccoli"? 1:George H. W. Bush, 2:Bill Clinton, 3:Barak Obama, 4:Ronald Reagan.
    if %choice%==1 goto correct q2
    if %choice%==2 goto wrong q2
    if %choice%==3 goto wrong q2
    if %choice%==4 goto wrong q2
    goto Q2
    :wrong q2
    goto Q2
    :correct q2
    goto Q3
    :Q3
    @echo off
    set /p choice=In Peter Pan, what sort of creature was Nana? 1:Dog, 2:Human, 3:Firefly, 4:Fairy.
    if %choice%==1 goto correct q3
    if %choice%==2 goto wrong q3
    if %choice%==3 goto wrong q3
    if %choice%==4 goto wrong q3
    goto Q3
    :wrong q3
    goto Q3
    :correct q3
    goto Q4
    :Q4
    @echo off
    set /p choice=What's the name of the bird that Sylvester (from loony tunes) chases in vain? 1:Cupcake, 2:Tweety Pie, 3:Jerry, 4:Eli.
    if %choice%==1 goto wrong q4
    if %choice%==2 goto correct q4
    if %choice%==3 goto wrong q4
    if %choice%==4 goto wrong q4
    goto Q4
    :wrong q4
    goto Q4
    :correct q4
    echo Answer is correct.
    goto Q5
    :Q5
    @echo off
    set /p choice=Where was the second Atom bomb dropped? 1:Tokyo, 2:Osaka, 3:Hiroshima, 4:Nagasaki.
    if %choice%==1 goto wrong q5
    if %choice%==2 goto wrong q5
    if %choice%==3 goto wrong q5
    if %choice%==4 goto correct q5
    goto Q5
    :wrong q5
    goto Q5
    :correct q5
    echo Congratulations! You have completed this quiz.
    echo JAYFIN Programing
    goto Main
    Did you at the places for the code to got
    Ex:
    @echo off
    :start
    echo enter a number
    set /p num=(1-3)
    if %num% == 1 goto num1
    if %num% == 2 goto num2
    if %num% == 3 goto num3
    :num1
    echo you entered the number1
    pause
    goto start
    :num2
    echo you entered the number2
    pause
    goto start
    :num2
    pause
    goto start
    I'm currently making a trivia game with passwords and a help menu.
    You got a/ backwards.
    I tried /a, and that worked instead of a/
    so I think you got that backwards
    I'm trying to get this to work, when you have the command "if %input%==a goto PLAY" where is play? It just closes my window...
    Oh sorry, i must have forgot to put that in. Well, you can create a :play label otherwise you can just change the script so that...
    By the way, if there is a label that does not exist in the script, then it just closes it
    Woops XD
