How to Make a Simple C Program
1,773
19
6
Posted
Introduction: How to Make a Simple C Program
These instructions will show you how to construct a very basic C program. Currently computers are found in almost every household in America and programming is a method that lets us interact directly with them. Thus I created this instruction for anyone with a windows computer to follow. People with no programming knowledge might spend 30 or so minutes, but those with more experience will take less time. By the end of the instruction you should have a working program that you constructed yourself.
Needed Things
  • Windows computer
    • Admin access may be needed
    • Adaptations can be made with other computers
  • Internet connection
Step 1: Downloading Software
Note: If you are running a non windows computer this step and the one that follows won't pertain to you.
1. Click on this Link > MinGW
2. Click the Download link on the webpage
Figure 1
Note: You will be redirected to the page in Figure 2
3. Click the Download link on the new webpage
Figure 2
Note:You will be redirected to the page in Figure 3
4. Wait till the download completes
Figure 3
Note: Can take awhile
5. Navigate towards your computers downloads folder
Step 2: Install the Software
1. Run the Installer
Note: you might run into a popup, just hit run as in Figure 4
2. Click on the Install button
Figure 5
3. Uncheck the Graphical User Interface box
Figure 6
4. Click the Continue button
Figure 7
5. Wait for the software to download
Figure 8
6. After the software has finished downloading click on the Quit button
Figure 9
Step 3: Create the Code
1. Open Notepad
Click the windows button then type "notepad" as in Figure 10
If done right should end up at Figure 11
2. Type the files to include
#include <stdio.h>
Figure 12
Note: You can add other files you would like to use, we will include this so that we can have output
3. Add the Main Statement and the brackets
int main( int argc, const char* argv[] ) {
Figure 13
4. Add the Printf Statement within the brackets
printf("Hello World! Made by [insert name].");
Figure 14
Note: replace [insert name] with your name for added personalization
5. Save the File as a .c file
Figure 15 then Figure 16
Step 4: Compile and Run
1. Open Command Prompt
Click the windows button then type "cmd" as in Figure 17
If done right should end up at Figure 18
2. Type in the GCC command
gcc First.c -o First
Figure 19
3. Type in the command to run the program
./First
Figure 20
Step 5: Finished
There you have it you have constructed your first C program. Now adapting the simple code we constructed you can make more complex programs. If you experienced any problems try the MinGW webpage, there is a troubleshooting section. If that doesn't fix the problem try going over the instructions again. If neither of those help you try asking your questions on Stack Overflow.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
6 Comments
Everytime I use gcc, it says it's not recognized as an internal or external command, operable program or batch file. What does that mean?
Why do you need a Windows computer? Being UNIX-alike Linux is made to be an IDE.
pfred1@buck:~$ gcc -v
gcc version 4.7.2 (Debian 4.7.2-5)
I know that is why I stated that the some steps weren't necessary, but the instuctable was based around a windows machine. However could be easily adapted for Unix machines. Utilizing a notepad like application and the native gcc compiler you could follow these instructions as well starting at step 3.
Ming is a very good and well-maintained port of gcc to the Windows environment, but it is a very heavy and complex program for a casual coder. Let me recommend tcc at http://bellard.org/tcc/ - it requires no installation, no admin access, and is just a single zip that can be unpacked and used anywhere. It is much faster than gcc, although it produces considerably inferior quality code - but it is ideal for a beginner to experiment with, and the full source of the compiler (which can compile itself) is open source as well. You can also use it as a c-scripting environment (compile-and-go) which skips linking and the like (confusing for beginners) and lots of other very handy attributes. Check it out.
ey, step 3 adding code shows the html used in the site mixed with the C code, newbies could be confused with that if they copy it.
