This is a step by step instruction of how to make an one-string simple electric guitar.
This was originally experimented by Paul in the museum's Curiosity Lab .
Children should work with a responsible adult helping your with your project!
What you need:
    (1) 1x2 White Pine lumber approx. 12" in length
    24 AWG magnet wire
    Winding Jig (Instructable coming soon)
    Epoxy
    220 Grit sand paper
    (1) Neodymium magnet 1/4" x 1/4" cylinder
    (1) Jumbo craft stick
    (1) #12 Screw eye
    Security cable 22 AWG strand
    (1) 3.5mm (1/8") Mono plug
    Steel wire
    Wire strippers
    Screwdriver
    Guitar pick
(Other tools + materials not shown in the image)
    Medium binder clip
    Soldering iron
    Solder
    Scissors
    Hot glue gun
Step 1: Glueing Magnet Sandwich
1. Roughen up both sides of your neodymium magnet by scraping on your sand paper.
2. Cut your jumbo craft stick to make two 1" x 1" square pieces.
3. Epoxy the magnet to your craft stick piece.
*Please read hazards + instructions for using epoxy.
4. Epoxy both sides of magnet to create magnet craft stick sandwich.
Ortzinator says: Aug 16, 2012. 11:30 PM
Where'd you get your giant scissors? I have some too. Mine were used in a tire factory to cut sheets of rubber.
aemj says: Aug 15, 2012. 7:57 AM
Has anyone tried to link this up into a circuit with a light bulb? I'm hoping to show that electric guitars generate electricity and thought it would be visual way to do this. I dont know whether enough electricity is generated to do this though? Any thoughts or adivce woudl be great!
whisper199 says: Mar 7, 2011. 2:32 PM
cool you mind if I use it for my homework
n0ukf says: Feb 17, 2011. 4:01 PM
I have found that at least some sound cards need you to use a three terminal (stereo) plug into the mic input, otherwise the barrel will short out the ring connection to shield and you'll get no sound.
Children's Museum of Pittsburgh (author) in reply to n0ukfFeb 18, 2011. 7:00 AM
Thanks - n0ukf We have not encountered that problem, yet. We will keep that in mind for diagnosing problems in the future. Thanks for sharing.
n0ukf in reply to Children's Museum of PittsburghMar 5, 2011. 9:09 AM
I also found when plugging a regular electric guitar into the computer's mic-in that the volume and/or tone controls would be noisy. I traced this problem to the DC put out the mic jack for powering the condenser mics. This could also potentially cause trouble (burn out the voice coil, or just alter the frequency response) for dynamic mics plugged in unless you add a DC-blocking capacitor in-line.
frikkie says: Feb 24, 2011. 8:09 AM
Sounds cool.how about a video so we can hear what it sounds like?
Mudbud in reply to frikkieFeb 24, 2011. 4:32 PM
Yeah, me too....
gbryanmiller says: Feb 22, 2011. 5:58 AM
This instrument is also known as a Diddley Bow. http://en.wikipedia.org/wiki/Diddley_bo
pquin3 says: Feb 20, 2011. 12:46 PM
How many winds on the winding jig?
Children's Museum of Pittsburgh (author) in reply to pquin3Feb 21, 2011. 7:34 AM
Hi pquin3. That's a good question. I have only seen the pick-up not work with less than 100 windings, though I recommend that you try different numbers and see what works best.
Khord says: Feb 20, 2011. 11:10 AM
Good work, reminds me of Jack White's introduction in the documentary "It Might Get Loud" http://www.youtube.com/watch?v=xCFXeChXfcI
landru says: Feb 20, 2011. 7:37 AM
you've written "scrapping" and "scrap" where i think u want "scraping" and "scrape" ... in case u care
Children's Museum of Pittsburgh (author) in reply to landruFeb 20, 2011. 9:08 AM
All fixed... Thanks landru!
fretted says: Feb 18, 2011. 6:08 PM
Love the Winder Could ahve saved 350 bucks if i would have just built my own great ible great for someone who wants to understand the basics of how a guitar works ....
Great Job
spark master in reply to frettedFeb 20, 2011. 8:31 AM
lindseys publications used to have a booklet on how to build a coil winder (think tube/ham radio needs). But the scale is whatever you like. I would want as fine a wire as I could get to make the coil more sensitive. (you can get more turns on the core)
mental man says: Feb 19, 2011. 7:21 AM
HOWDY hey ya gotta look up Diddley BOW on you tube and it will show you how to make what may be the oldest type of instrument in the world which is a one string guitar.
Yastobaal in reply to mental manFeb 20, 2011. 8:22 AM
Here's a great example:
http://www.youtube.com/watch?v=u4GNIAWbUNg
landru says: Feb 20, 2011. 7:55 AM
have you experimented with different amounts of winding on the pickup? the i'ble doesn't give me a clear indication of whether the wire is wound around the pickup for two complete loops or 20 (or whatever)... but it is a great instructable!
also, is there a magnet field strong enough to be concerned about proximity between the instrument & a laptop's hard disk, e.g.?
duct tape says: Feb 19, 2011. 1:23 PM
Could you share a recording of it? I just want to hear what it sounds like before deciding to build it.
Dr Qui says: Feb 18, 2011. 8:29 PM
This must sound vile, I like it :-)
More of a Twanger than a guitar.
ilpug says: Feb 16, 2011. 7:45 PM
this is very cool. any ideas for making a multiple string one? i reccomend you use a hard substance like tough plastic for construction however, because the soft porous wood will absorb a lot of the sound. also note that in a real guitar, there is a metal piece on the outside of the pickup very close to the strings that improves sound pickup. Yours is covered in wood, so that might affect the sensitivity. very good simple build.
Children's Museum of Pittsburgh (author) in reply to ilpugFeb 17, 2011. 12:02 PM
Good suggestion - ilplug. The simple electric guitar was designed to be the bare minimum you would need to make an electric guitar, based on price and materials. We encourage everyone to improve upon and experiment with this design. I will try using a hard wood today and let you know the results.
Children's Museum of Pittsburgh (author) in reply to ilpugFeb 17, 2011. 6:44 AM
(removed by author or community request)
ilpug in reply to Children's Museum of PittsburghFeb 17, 2011. 9:56 AM
thanks. good luck on the new build.
Murphy85 says: Feb 17, 2011. 9:04 AM
If you want cool tones out of this thing, instead of using a screw driver to adjust pitch, use a glass shotglass, or a piece of really high polished copper tubing. Congratulations, you now have a one-string lap steel guitar.
Children's Museum of Pittsburgh (author) in reply to Murphy85Feb 17, 2011. 11:46 AM
Good suggestion - Murphy85. We encourage everyone to experiment producing all kinds of sounds with their simple electric guitar. We have tried PVC pipe, screwdrivers, dowel rods, etc and look for more objects to experiment with to produce sounds. For a good song that features a lap steel guitar search "Sleep Walk".
UrbanSurvival says: Feb 17, 2011. 9:32 AM
If you are going to build this, you need the right soundtrack.  Seasick Steve's
Diddly Bo
 is all about making a homemade guitar, plus it is performed on a homemade guitar.
Very cool instructable.
zazenergy says: Feb 16, 2011. 3:02 PM
Awesome! Thanks so much for sharing this.
Children's Museum of Pittsburgh (author) in reply to zazenergyFeb 17, 2011. 6:46 AM
Your welcome - zazenergy We love to share!
Kiteman says: Feb 16, 2011. 2:27 PM
Cool - any chance of a recording of one being played?
Children's Museum of Pittsburgh (author) in reply to KitemanFeb 17, 2011. 6:35 AM
Good suggestion - Kiteman. We will try to get that up to our blog as soon as possible. Maybe we can share songs played on our homemade instruments.
Kiteman in reply to KitemanFeb 16, 2011. 2:29 PM
Oh, and how many turns do you recommend on the coil?
Children's Museum of Pittsburgh (author) in reply to KitemanFeb 17, 2011. 6:38 AM
Good question. I recommend you try and see for yourself what works best. However, I have only seen the pick-up not work with less than 100 windings.
young skipper says: Feb 17, 2011. 3:28 AM
Excellent, I will win all the ladies now. Thank you.
-Fernando
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
