How to Make a Simple Pull-back Car(rubber Band Powered)
315,791
28
31
Published
Introduction: How to Make a Simple Pull-back Car(rubber Band Powered)
About: Love simple robotics, electronics, sensors, arduino projects and generally building, modifying and opening up stuff
This is a simple instructable that tells you how to make a rubber band powered pull back car.
THINGS YOU NEED
*rubber band
*kebab skewer
*straw
*cardboard
*2 old CD's
*a toy car
*glue,scissors,compass,tape,pen.
WHAT TO DO
1.Cut out four cardboard squares and keep them aside.
2.take the straw and cut out 2 small pieces.
3.Tape/glue these pieces to the piece of cardboard.(this joint has to strong)
4.put glue around the hole in the CD and stick one cardboard square on it.tape it to make it stronger.Do the
same on the other side of the same CD.Do the same on the other CD.
5.Mark the center of the CD on the cardboard(stuck to the center of the CD) and using a compass make a small hole on both
the cardboard pieces on the sides of the CD. Repeat on the other CD
6.Insert the kebab skewer into one of the CD's.Now put the other end of the skewer through the straws on the cardboard and put the other CD on the other side of the skewer.
7.Attach the toy car to the other end of the cardboard piece on the underside.
8.Loop a rubber band around the exposed part of the kebab skewer and stick it with tape or glue.
9. The other end of the rubber band and stick it to the front of the cardboard.
10.pull back the car.The rubber band will wind around the axle(KEBAB SKEWER)and when you leave the car, the rubber band will unwind and in the process turn the axle and thus the car will move forward.
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    • Backpack Challenge
      Backpack Challenge
    31 Discussions
    i dont understand i need measurements for class but it doesnt show them
    How far will it travel
    11311
    2 years ago
    you are so funny beacause every thing is clear mayby you cant see well
    Dude, there ARE pictures. And there are other websites on the internet...
    What forces are acting on this car?
    I dont think this car would go more than a foot. The rubber band is clearly taut, and taped in place. After you wind it up and let it go, the rubber band will unwind, causing the car to move forward, but then, because the rubber band is taut and affixed to the axle, it will act as a brake, preventing the axle from further spinning.
    im doing this for a grade 8 science project, most people arent doing pull backs for this, i know the "other materials" question has already be answered but what about having the 2 back wheels be closer together? it would focus the power in a smaller area, but it might affect the direction, so i was going to have the 2 back wheels be closer together and have the 2 front wheels be more than double the distance apart than the back wheels, do you think that would work?
    It should work but if the front wheels are very far apart then even a slight deflection of one of them (due to weak joints or errors during attachment) can cause then car to change it's direction by a lot.
