How to make a simple shelf hung with a french cleat.
 by mattl
Featured
This instructable shows how I used an old oak table leaf to construct a simple yet durable wall shelf which is hung using a french cleat. I know there are lots of intructables about how to make a shelf, but I am particularly fond of the french cleat hanging method due to it's simple construction and how much easier it is to hang a shelf.
Needed:
Some scrap lumber
1/4" wood dowels
wood or hot glue
sandpaper
tape measure or ruler
saw (preferably with a tilting table or blade to allow for angled cuts such as band or table saw)
drill
stain
wood screws
Step 1: Select some lumber.
Here are a couple of the oak table leaves I found in my attic which were missing the rest to make a table.
steven_t_95 says: Feb 9, 2012. 11:56 AM
i am doing this project in highschool and i have to wright abunch of stuff down for the presentation but some of the stuff was missing like, how much the shelf can hold and the size. but i could find everything else.
mattl (author) in reply to steven_t_95Feb 10, 2012. 6:24 AM
Hi, the surface of the shelf is 6" deep and 15" wide. I have placed potted plants that weigh as much as 5lbs on it when watered. I would think you could put as much as 10lbs of weight on them. The key is whether you are able to drive the screws into a wall stud or something of similar strength. French cleats can bare a large amount of weight due to how they distribute it evenly over several anchors.
Hope this helps and good luck with your project!
-Matt
Dipankar says: Nov 2, 2008. 3:38 PM
What I would give to have a workshop like yours except money. Here it will cost a fortune. Your work is good, should be with tools like that.
mattl (author) in reply to DipankarNov 2, 2008. 7:39 PM
I can appreciate that. I have purchased major power tools one at a time as I can afford them or have requested them as gifts for birthdays etc. Honestly, a $100 band saw is an extremely worthwhile investment; a tie is a good drill (drill press or hand drill) followed by a table saw. The band saw is great because it has a small footprint and is very versatile.
mattl (author) says: Sep 18, 2008. 7:03 PM
Thank you for your kind comments. I'm all about detail.
Sandisk1duo says: Sep 13, 2008. 4:38 PM
Very well documented!
shooby says: Sep 13, 2008. 4:23 PM
This is far more elegant than the use of two solid right-angled triangles, nice job.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
