loading
Step 19: Hang the shelf.
Finally I simply slid the shelf down onto the cleat which is attached to the wall. The only thing I plan to do differently in the future is to countersink the screw holes and plug them after the cleat is mounted.
I think you'll find that while there are a few extra steps to make this type of mount, it pays off when it comes time to hang the shelf.
<p>I'd have done this a bit differently: Use my tablesaw to rip a 45&deg; down the middle of a board. One half for the wall cleat, the other half for the shelf cleat. But dude, this is beautiful. </p>
You make this very simple, I hope I can build something close to what you have designed. I need to make the shelves a 48 inches in length.
i am doing this project in highschool and i have to wright abunch of stuff down for the presentation but some of the stuff was missing like, how much the shelf can hold and the size. but i could find everything else.
Hi, the surface of the shelf is 6&quot; deep and 15&quot; wide. I have placed potted plants that weigh as much as 5lbs on it when watered. I would think you could put as much as 10lbs of weight on them. The key is whether you are able to drive the screws into a wall stud or something of similar strength. French cleats can bare a large amount of weight due to how they distribute it evenly over several anchors.<br>Hope this helps and good luck with your project!<br>-Matt
What I would give to have a workshop like yours except money. Here it will cost a fortune. Your work is good, should be with tools like that.
I can appreciate that. I have purchased major power tools one at a time as I can afford them or have requested them as gifts for birthdays etc. Honestly, a $100 band saw is an extremely worthwhile investment; a tie is a good drill (drill press or hand drill) followed by a table saw. The band saw is great because it has a small footprint and is very versatile.
Thank you for your kind comments. I'm all about detail.
Very well documented!
This is far more elegant than the use of two solid right-angled triangles, nice job.
About This Instructable
41,324views
96favorites
License:
More by mattl:Make a super cheap, easy and comfortable to use sanding block. How to make a towel or coat rack. How to make a glass box of emotion.
Add instructable to:
