3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a simple, small and strong electromagnet
Hi everyone, i am going to tell u how to make a small, simple and strong electromagnet. Sorry about the bad quality pics and videos and i could not upload many pics step by step, but i will try to explain as much as i can. U can see the videos in the last step.
Step 1The items you will need
The items you will need are:-
1. 20 gauge enamel coated copper wire also known as magnet wire. ( I bought around 20 meters)
2. a spool like the one i use or something similar.
3. electrical tape.
4. 6v battery (better if using 800-850 ma) i used a 1.5A.
5. A ac to dc converter.
6. aligator clips.
7. a neodymium magnet.
And a lot of time.
2 comments
Dec 13, 2011. 7:39 PMjpoopdog says:
even better, just use a weak solid ferrite magnet for the core, which you would increase its magnetism with using the coil. if your core magnet is too strong, heat it up a little bit so its hot to touch, and it will gradually loose its magnetism. stop heating and cooling once its weak enough. but overheat and it looses it completely.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:amruth
