3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a small wood stool.
  • last photo ←
Recently while talking to my younger sister I learned that my niece has entered the climbing phase. She will drag any and all movable objects to where she will be able to climb up onto things such as desks, counters etc. I commented to my sister that when we were young we always had small stools which were safer than things like totes. This inspired me to build a small stool for my niece as a Christmas present.
For me this was an extremely low cost project as I already had a number of antique table leaves which I had found in my attic upon purchasing my home. since I didn't have the table that they belong to and they were a little bit on the rough side I decided to use one of those for this project as I have in the past for others.
All other materials I already had on hand from past projects as well so I really have no expenses to itemize. Depending on what you have on had and the type of wood you want to use this stool could easily be made for under $20. If you have to buy everything it could certainly be more.
1 3/4" oak board
Wood glue
stain
latex wood filler
polyurethane
sandpaper
brad nails
table saw (a circular saw could also be used)
router with round over bit
compound miter saw (table saw or circular saw could also be used)
block hand sander
brad nailer
clamps
rags & brushes
belt sander (or any other type)
Step 1Cut the board to the desired size.
Begin by cutting what will become the top surface of the stool. I cut this to 16" x 10-1/2". I often don't measure first but look at the piece of lumber and visualize how the surface area will look when finished. Since this was a table leaf I chose to just trim it down slightly to the above dimensions. I then cut another piece identical in size. My reason for this is that I thought it would be nice looking to glue the two together to make it a thicker more rugged stool. While I was cutting the board down to size I created several strips of wood to use for the legs & bottom side trim. I cut the strips 1-1/2" wide.
14 comments
Jul 15, 2010. 5:37 PMtinstructable says:
Why polyurethane? With a clear coat of lacquer, it's only 30 minutes drying time per coat. That's what I've always used.
Jan 2, 2009. 11:01 PMstatic says:
I found the into interesting. Here Children are discouraged from climbing up to places not intended for people to be on. However short step stools are provide so they can use the bathroom sink.
Jan 1, 2009. 7:42 AMcolinj says:
The bench looks great but how about a picture of your niece seeing her present for the first time and/or using it.
Jan 1, 2009. 2:02 PMcolinj says:
that sounds like a good call.
Jan 1, 2009. 10:45 AMjohnmxl says:
Looks great, but how stable is it with a climbing child? Wouldn't a base as wide as or wider than the top be better?
Jan 1, 2009. 1:46 PMjohnmxl says:
Thanks for addressing my question. I guess I'm thinking more like a parent these days than the inquisitive boy of my youth. I silently applaud every time one of my kids push the envelope - it means I haven't completely succumbed to the nerf society!
Dec 28, 2008. 3:20 PMmg0930mg says:
Great job. I love how it looks.
Dec 27, 2008. 1:24 PMPhil B says:
In Step 1 your photo shows the sawblade sticking up above the wood an inch and a half, or so. You will actually get a smoother cut if you lower the blade so it sticks up above the wood only about 1/8 inch. Also, if your hand slipped and came in contact with the blade, a blade barely sticking up above the wood will produce a flesh wound. Sticking up an inch and a half or more it will take off fingers or part of your hand. Otherwise, nice job on the bench!
Dec 28, 2008. 5:17 AMPhil B says:
Pushsticks are great. Thanks for not minding my suggestion. Someone did a study once and found that extra safety devices on automobiles, like ABS brakes, gave people a sense of security that enticed them to take more risks, and they were no safer in the end. Saws I have used did and do not have as many blade guards as many saws do now. I have always felt blade guards may lull the user into taking more chances. To me, very safe practices coupled with extreme vigilance is more reliable than a blade guard.
Dec 27, 2008. 3:22 PMsgsidekick says:
Nice bench. Looks simple enough that even I could do it!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:mattl(OhCripes.com)
