3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a solar iPod/iPhone charger -aka MightyMintyBoost
I wanted a charger for my iPodTouch and the MintyBoost was definitely my first choice. I wanted to take it a bit further and make it not only rechargeable but also solar powered. The other issue is that the iPhone and iPodTouch have large batteries in them and will deplete the two AA batteries in the MintyBoost rather quickly so I wanted to increase the battery power as well. What I really wanted was a MightyMintyBoost!
Apple has sold over 30 million iPodTouch/iPhone units- imagine charging all of them via solar power.... If every iPhone/iPodTouch sold was fully charged every day (averaging the battery capacity) via solar power instead of fossil fuel power we would save approximately 50.644gWh of energy, roughly equivalent to 75,965,625 lbs. of CO2 in the atmosphere per year. Granted that's a best case scenario (assuming you can get enough sunlight per day and approximately 1.5 lbs. CO2 produced per kWh used.) Of course, that doesn't even figure in all the other iPods, cell phones, PDAs, microcontrollers (I use it to power my Arduino projects) and other USB devices that can be powered by this charger- one little solar cell charger may not seem like it can make a difference but add all those millions of devices together and that's a lot of energy!
There are some really nice features about this charger:
It's solar powered!
It's small.
Large battery capacity- 3.7v @2000mAh
On board charger charges via solar, USB or wall wart. Accepts input power from 3.7v to 7v.
Remove the solar cell after charging and you have a nice compact USB power supply.
Unplug the solar cell and use the Velcro to secure the MightyMintyBoost inside a backpack or messenger bag- now plug in a larger solar cell attached to your bag for even faster charging. Using a slightly larger solar cell (6v/250mAh) you can generate enough power to fully charge an iPhone in about 5.5 hours and an iPod Touch in 4 hours.
Building this is really easy and straightforward- it only took me around an hour so follow along and build one for yourself!
Safety note and general disclaimer: Be careful cutting the Altoids tin as it can have some really sharp edges- file them smooth if necessary. Assemble this at your own risk- while it is really easy to build, if you mess something up there is the potential to damage the electronic device you are trying to charge. Be careful in your assembly and soldering work and follow good safety practices. Only use a type of battery charger specifically designed for the type of battery you are using. Please read through the entire Instructable before asking questions- if there are are any questions just ask and I'll help out as best as I can!
Step 1Tools and materials
Tools and materials
Here's what you'll need to build your own MightyMintyBoost:
Tools:
Soldering iron
Scissors
Wire cutters
Pliers (or muiltitool)
Multimeter
Metal shears
Clear packing tape
Materials:
MintyBoost kit
Lithium polymer battery charger (the original one specified was discontinued)
3.7v 2000mAh Lithium Polymer battery
JST connector/wire
Small solar cell
2" x 3" adhesive backed Velcro
Small double sided adhesive squares
Altoids tin
7/10/10 UPDATE: Adafruit now also sells all the parts you need to make this a bit more mighty. Have a look here!
http://www.adafruit.com/blog/2010/07/09/how-to-make-a-solar-mintyboost-a-solar-power-charger-for-your-gadgets/
7/18/11- ANOTHER UPDATE: Adafruit recently introduced a new LiPo charger that is specifically designed for solar charging that has much better performance. It's not as small but the performance gains would make it worth it. Have a look and read about the design here-
https://www.adafruit.com/products/390
Some notes:
The single cell Lithium Polymer charger can accept input power that ranges from 3.7 to 7v maximum. When the cell reaches full charge the charger will automatically switch to trickle charging. When charging using the mini USB port, the charging current is limited to 100mA. When charging using the barrel plug jack, the charging current is limited to 280mA.
The solar cell maxes out at approximately 5v @ 100mA in bright sunlight. If you need faster charging simply use a larger solar cell- a 6v cell @ 250mA would work very well and they are easily obtainable and inexpensive. I used the size of solar cell that I did because I wanted it to be super compact.
I could not find out from the manufacturer if the solar cell I used has a blocking diode. A blocking diode is used in many solar charging systems to prevent the solar cell from draining the battery during low light conditions. Instructables member RBecho pointed out that the charging circuit used negates the need for a blocking diode in this application. You can tell when the solar cell is producing enough power because the little red LED on the charger will come on during charging.
« Previous Step   View All StepsNext Step »
903 comments
1-40 of 903next »
Sep 27, 2010. 1:28 PMLandcruiser87 says:
Love this setup,
I plan on building a 12V system for other power hungry applications, but instead of a flimsy altoids can, i decided to beef it up a bit with a pelican project box. If anyone has any suggestions about how to cover ports a little better, that would be great.
Check it out!
Love the instructable! Great work.
Sep 28, 2010. 1:14 PMLandcruiser87 says:
Thanks! They're possibly one of the best made containers of any sort. I've been using them for various things here and there over the past 7 or 8 years. I like the idea of using Sugru for port covers! I was having all sorts of failed trials with grommets, silicon and other failed devices, but sugru might just be the ticket. Thanks Honus!
May 26, 2012. 10:27 AMdhabib03 says:
thanks man! but those of you using the mintyboost 3.0 kit just no need for other parts you just need a 6 watt solar panel and the minty boost 3.0 kit just assemble the kit and instead of putting the battery holder put the solar panel
May 13, 2012. 5:41 PMJmorgan77 says:
I know that a usb is supposed to accept just 5v.Does anyone know if a 5.5v solar panel would be too high of an output for the new sparkfun charger with just the mini USB?
May 13, 2012. 6:03 PMJmorgan77 says:
Nevermind, the data sheet says 3.75-6v input.
May 9, 2012. 8:22 PMMyTopFan says:
In the new sparkfun charger, there is a selectable 100 or 500 mah charging current. I am using a 5.5v 250mah solar panel, do for best results which should I have it set at?
Apr 22, 2012. 10:37 AMMyTopFan says:
Im new to this so correct me If I'm wrong.
Could I just leave out the middle man and solder th solar panel wires straight to the lipo battery to charge it?
Apr 22, 2012. 5:46 PMMyTopFan says:
Thanks.
one more thing, you said that the charging circuit used doesn't require a blocking diode. Since that model was discontinued, does the other one listed require a diode? ( http://www.sparkfun.com/products/10161 )
Thanks in advance.
Apr 11, 2012. 2:45 PMdvgs says:
sweet - Thanks for the help!
Apr 11, 2012. 9:27 AMdvgs says:
would a mini usb that comes on the cell phone chargers work?
Apr 10, 2012. 7:14 PMdvgs says:
In the picture your using the old lipoly charger but i have the new one that dosent come with the barral jack and the new lipoly charger looks compleatly different the the old one and i cant figure out how or were i would conecct the solar panal to the lipoly charger. Can you help me figure out were to connect the solar panal on the lipoly charger?
Apr 9, 2012. 8:20 AMTrollRolal92 says:
Hi Honus!
Just wanted to say this was an awesome project and a great gift idea for my girlfriend! Being that she drives around a lot it is comforting to know that if she ever breaks down she'll have a charged phone ready to call somebody to get some help!
First and foremost I am a complete rookie for these kind of things and I am still riding the learning curve, so exuse my questions if they seem ridiculous.
So I built this about a month ago and it worked very well!
However I would like to try and improve on my previous attempt, add a pelican case, a larger solar cell, larger LiPo battery.. I'm just looking for some clarification on a few things if you could give me a hand.
1. If I upgrade to the 6v 2 watt solar cell, will the battery charge faster?
2. Will I need to upgrade to the 2200 mah battery to charge faster as well?
Essentially I am just looking to charge faster than the current 3.7-3.9 volts I am currently getting from my first charger without crossing over the 7v threshold/without needing to make it anymore confusing for myself.. If you could break it down for me into elementary terms, that would be awesome! I looked through the comments section and abused google and could not quite get a grip on what I would have to do to complete this myself.. I appreciate your time in making this article and your support with my question.
Apr 9, 2012. 12:11 PMTrollRolal92 says:
Ok thank you awesome analogy it is very clear to me now!
Just one more if you wouldn't mind, if I do use that 6v 2watt panel, would I have to make any other changes? Such as use a different LiPo charger? Or will it work exactly the same as if I were going to use the smaller cell?
Thanks again Honus!
Apr 9, 2012. 8:26 AMTrollRolal92 says:
If it helps, I will be using the iPhone 4s..
Apr 7, 2012. 4:37 AMMacOSJoey says:
Great idea! The stats you gave in the description about how much power these gadgets used really surprised me! I've been running my iPhone off of solar and plan to keep doing it!
Aug 23, 2011. 1:47 PMpfricks says:
Keep in mind that the iphone & battery was not made for extreme heat
Apr 9, 2012. 9:09 AMwaterlubber says:
He meant "Keep in mind that the iPhone and the iPhone's battery was not made for use in extreme heat"
Aug 27, 2011. 9:10 PMLittledrumer says:
when the solar panel moves out of the sun will it start draining the battery. i charged my battery for a couple of hours but the solar panel went into shade and my battery wouldent charge my ipod and i cant think of any thing else that could of draind the battery so quickly. any other sugestions?
Apr 9, 2012. 9:06 AMwaterlubber says:
Insert a diode. The power only goes one way. It's just the way panels are built. Diodes fix it. Simple.
Sep 3, 2011. 9:09 PMmarkee2 says:
Am building one but got some charging problem with iPhone.
Adding the circuit below can solve the problem.. maybe, anyone got some idea?  circuit copied from:
http://www.simple-electronics.com/2011/09/iphone-charger-circuit.html
Apr 9, 2012. 9:04 AMwaterlubber says:
I think you get that when the input power is too low...I've got that on a car charger.
Apr 9, 2012. 9:01 AMwaterlubber says:
Cool! Once a took an old Tetris game and popped out the batteries. I then took a solar charger and connected it to the contacts on the Tetris with clip leads. The screen sometimes went dim, or it got too bright, but by adjusting the panel I could make it work. Yummy! Solar Tetris!
Feb 22, 2012. 5:40 PMgarren11 says:
Okay im planning on using a 6v 2W solar panel, with the solar lithium ion/ polymer charger, minty boost v 3.0 . Can i use a lithium ion batter pack - 3.7V 4400 mAh which has 2 batteries in a circuit. It says it runs at 2A but the website said use caution and use at 1.5A if its going to be recharged. I will be using a pelican box to hold all my compomites. Would this setup work to charge a iphone or ipod. All help is welcome.
Jan 24, 2012. 3:59 AMblackboxrecorder says:
Is it possible to scale this up so that it has 10xAA batteries?
1-40 of 903next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
621
Author:Honus(Multi-Bot)
I'm a former bicycle industry designer turned professional jeweler. I like working with my hands and am happiest when I'm in the shop building my creations. If you need help with your project just let...
more »
