Step 4Add the solar cell
The second method is to replace the connector with another JST connector and plug it into the third connector marked 5v on the charging circuit. I didn't have another JST connector handy so I just soldered a salvaged two pronged connector to the charging circuit where there are two open pins on the 5v line.
Using the second method certainly is a bit cleaner since you don't have the big barrel plug sticking out of the side of the tin.
Now attach the solar cell to the top of the Altoids tin using some 2" wide Velcro. I wrapped the battery pack with a layer of clear packing tape to help protect it. Then the battery pack is simple set down on top of the two circuit boards- it's a near perfect fit.
Now set your MightyMintyBoost out in the bright sun and charge it up! You should see a little red LED on the charger board light up. Once it's fully charged connect your iPod/iPhone/USB powered device and enjoy!
| « Previous Step | View All Steps | Next Step » |
Have you tried just charging the battery using the solar cell and not with the ipod/iphone connected?
I have done a similar application and designed a customised charger/boost circuit using ideas from a microchip application note, when an external supply is available this takes priority and supplies the boost convertor and charges the battery separately.
I've bought a solar charger with a mini USB output. Its output voltage and current is 5.5v and 400-800mA. The problem is that my iPod Touch won't charge. Do you know what may be causing the problem? Maybe not enough current? What could I do to solve the problem?
Thanks in advance!
Great guide!! - if I had seen it before I wouldn't have bought this charger ;)
The other issue is that iPods and iPhones require some interaction over the USB port data lines so you will probably have to modify the charger to make it work by soldering resistors to the USB data pins.
This link explain everything, as implemented in the mintyboost: http://www.ladyada.net/make/mintyboost/icharge.html
You will definitely want to use the 500mA variant, NOT the 1 Amp charging current variant.
Hope this helps!
How about make a 5V input (e.g. PC USB port) for the 3.7v 2000mAh LiPoly battery recharge instead of this small solar cell??
I've been working through the same problem over the last week. What I found through my troubleshooting efforts is that devices are sensitive to serial data line voltage. Using a 3.7V LiPo battery sets the serial data line voltage far too high (3.6V+ when the required voltage is 1.9-2.3V) for an Apple product to register the charger as a charger. To counter the increase in input voltage I used a voltage divider with 39kOhm/56kOhm values. For all those interested, a discussion on how the voltage divider is set up can be found here. I've confirmed that the fix works on several different iPods (120GB and iPod nano 3rd generation) as well as an iPhone (sorry, didn't get the generation but I think it was the generation before the 3GS).
Best wishes,
Jake
So far two different iPhones have tested good: the 3G and the 3Gs.
Best wishes,
Jake
Thanks
Sorry. No 5th generation iPod yet. However, I have a feeling the iPhone 3Gs is one of the more sensitive devices that Apple makes where the serial data lines are concerned. If I do end up trying to charge a 5th generation iPod I'll be sure to post the results.
Best wishes,
Jake
Is there anyway possible you could post or email me instructions on how to hook up the SPARKFUN LiPoly Fast Charger - 5-12V Input ???
I'm going to use the Sparkfun Solar Cell Large ...
as you can probably tell i dont care about fitting it in an altoids tin, haha
Last question is: do you think it would be possible to charge without the battery? As in making it a Solar charger only? as that would also cut the cost down alot.
