Spray bottles are iconic household items. Whether you are spraying cleaners on a counter top or misting water on your plants, they are quite useful but they have some limitations. They can only operate when the end of the suction tube is submerged in the liquid. They have no problem as long the bottle is full and held upright. But if the fluid gets low or if you try to spray something at an angle, the sprayer might stop working. So, I figured out a simple modification that will let them function in any orientation.
By replacing the hard suction tube with flexible tubing and adding a weight to the end of it, the suction tube will naturally fall to the lowest point of the container. This will allow end of the tube to stay submerged regardless of how the bottle is positioned. Here's how to make it.
Remove these ads by
Signing UpStep 1: Materials
Spray Bottle
Flexible Tubing with 1/8" inner diameter (such as aquarium airline tubing)
5 x 1/4" Stainless Steel Nuts (or other weight)
Scissors
Glue (optional)
Visit Our Store »
Go Pro Today »
Regarding corrosion: Simpler than coating the weight and better than using stainless, I'd suggest finding some bronze hardware (not brass). Alternatively, given that strength is not an issue, you could also use lead, or even gold! On the less elegant front, a chunk of plumber's putty would probably also work.
Take the stiff tubing that you clipped off, cut about a 0.5-1 inch piece of it. Cover your metal weight entirely in silicone/Sugru/Oogoo. After that dries, Oogoo the sealed weight to the side of the piece of stiff tubing. Stick your short weighted tube on the end of the flexible tube. Now you have totally sealed weights that won't fall off.
Thank you.
Where have you been all these years?
I wonder if, as you say, the stainless steel nuts will rust could one not coat them with a lacquer such as polyurethane or even nail polish?
Let's assume I use 6 nuts to adapt the bottle.
What am I to do with the other 94 nuts?
$30 is quite a premium to pay for such a bottle even as good as it is.
For the weight,hobby-stores sell perforated glass or ceramic bowls.
Cigarettes kill.
Why haven't I never thought about that before, or someone else for that matter.
Life will be so much easyer for me after having seen this. I use those bottles every day.
A big THANK YOU isn't enough, wish i could serve You a cold one :-)
Best wishes
oz5es
Why I signed up here?
This is the answer :):)
aluminum can react with certain chemicals to produce Hydrogen/Oxygen mix which can be explosive
Simple and very handy!!
Thanks for sharing!
''A system utilizing a flaccid tube for delivery of liquids with a spray container is disclosed. This device can be substituted for the usual straight, non-flaccid tubing widely used with liquid dispensing containers''.
sorry, couldn't resist
You could add a step to prolong the use-life of the nuts:
Covering them, once on the tube, in clear silicone caulking.
PTFE Teflon Sheet that 7mm thick can withstand ALOT of different chemicals and also high heat (not that anyone will be spraying boiling water or anything lol)
BUT i was really surprised at the sheer HEAVY weight of Such a SMALL amount of this stuff, i had found someone selling offcuts on ebay and it is GREAT Stuff (Heavy, Resistant to Most Chemicals !!)
Hope this helps anyone out there !!
Happy hacking lol !!
Excelent and i agree with last comment, I CANT believe this hasnt been made the 'norm' !!!!
Many thanks for sharing a EXTREMELY useful Hack !!!
just like the tube weights for gas rc planes fuel tanks..
this is so great, you deserve to work in a big company with a wealthy income.
I simply love this idea!!
Thanks!
