Why would you need a steam distiller?
-Steam distillation is the main method of separating essential or volatile oils from plant material, however commercial steam distillers cost around $400 and essential oils cost a lot too. With this Instructable you can start producing essential oils for less than $40.
Remove these ads by
Signing UpStep 1Introduction
Basically steam goes through plant material, where it absorbs the essential oils, then is condensed and the oil is separated from the water.
L
I wouldn't expect the Yarrow extract to be blue, but I think you may be able to extract with (cold) alcohol as an alternative.
L
And I want to get the essential oil, so I can't do a alcohol extraction (it would pull out other stuff and be hard to concentrate). And to do a solvent extraction for essential oils uses a lot of costly solvents and could leave impurities.
-mitch
An unfortunate side effect of running STEAM(or very hot water) through galvanized pipe is that Zinc Carbonate ends up dissolved in the product. In old water pipes, it's not much of a problem specifically because it is so dilute... but you're distilling! It's not gonna kill you or anything, but might cause some irritant issues with your lungs/stomach/skin if any significant quantity is inhaled/ingested/applied.
