3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a still
How to make a still
This contribution tells you how to distill liquids in your own kitchen.
Maybe for illegal liquor, maybe for purifying water.
! Drinking distilled alcohol may be harmful / fatal.
! Distilling alcohol may be illegal
! Drinking distilled water may be harmful / fatal
Step 1Materials
Materials
I used:
A pressure-cooker
8mm OD copper tubing
A plastic bucket.
347 comments
1-40 of 347next »
May 28, 2012. 12:17 PMwarren_adams says:
The pressure-cooker, isn't that made of stainless steel or aluminum? I have read a few things about it's effect, I mean using this kind of metal distiller in the spirit taste as against using a copper still. I broke my whiskey still so I thought I might as well come up with an improvised distiller. I've made a couple of run with my old still using a recipe from this site: http://www.whiskeystill.net/pages/how-to-make-moonshine, it was excellent. I'm all new to this hobby but the recipe really worked well for me. I'm just not sure how it will turn out if I prepare it with a homemade distiller.
May 27, 2012. 12:31 PM'yusrianto says:
hi lemonie .. this is one Great instructions..
umm..just a question about the picture of your stove, what was that chili sauce pan doing up there again? i din quite get it thx
May 2, 2012. 8:33 PMjmellott says:
I just recently found this instructable, great job by the way, and i was curious how much tubing you needed, unfortunately that stuffs not cheap
Apr 28, 2012. 6:17 PMyanik12 says:
Can anyone who has a decent knowledge of home brewing spirits inbox me, i have a few questions. Thanks
Apr 10, 2012. 2:57 PM~KGB~ says:
Do you actually have to use malt or is it ok just to use: yeast, corn meal, water and sugar? Also, how much of each component would you need for about a 1Ltr kettel? Thanks...
Apr 11, 2012. 1:23 AM~KGB~ says:
Oh ok, i read that you need all of the above components to make it, but you could do it without the malt...
Mar 16, 2012. 11:48 PMchano91 says:
hey,just wanted to know what is that cork looking thing on the pressure cooker itself connected to the copper and is there a possible way i could install a thermometer? btw great job!
Mar 15, 2012. 1:13 PMlittledemon says:
hi newbee here has any one used a demi jon instead of the pressure cooker ta
Mar 11, 2012. 3:53 AMrosendomuyo says:
For a pressure cooker still how much Water Cornmeal Sugar Yeast and Malt do i need to make this.
Mar 11, 2012. 5:10 AMrosendomuyo says:
so what do i brewed in this one ?
Mar 12, 2012. 5:38 PMrosendomuyo says:
sorry i did not say it right i need to make about 190 proof alcohol or higher for my car so i need to know the recipe for a pressure cooker still thank you.
Mar 13, 2012. 3:47 PMrosendomuyo says:
i look at bio-diesel can not do it and i have not look in to vegetable-oil but to make a car run on alcohol is just about 300 dollars to do.
Feb 20, 2012. 12:10 PMDraasch says:
Hello. I need some help!! My father built a still when I was little and it amazed me. He is elderly and cant remember how he constructed it. Can anyone tell me the steps I need to take to have my own?
Feb 20, 2012. 12:17 PMDraasch says:
Still reading! WOW this is great!!!!
Jan 27, 2012. 10:14 AMpegasus917 says:
Oh just a note though. It will taste real sweet and peachy when first done then as it ages it gets more refined.
Jan 27, 2012. 10:12 AMpegasus917 says:
If it calls for 3# then its 3 pounds of that ingredient.
Jan 26, 2012. 1:18 PMpegasus917 says:
Stevegrimmer- here is a site with a recipe for some great brandy that doesn't need any special equipment and no distilling required http://brewery.org/brewery/cm3/recs/12_51.html
I have been making it for years and years with peaches and it is always a big hit. Potent too. My family and friends just love it.
Jan 27, 2012. 9:16 AMstevegrimmer says:
hi pal what douse # Qt and 112f mean please
Jan 27, 2012. 10:11 AMpegasus917 says:
Pound sign (#) and 112 degrees Fahrenheit
Jan 27, 2012. 7:07 AMstevegrimmer says:
thanks pal im off out to get ingredients now. let you know how it turns out.
Jan 20, 2012. 12:11 AMDorsel says:
Hi, I would like to build a column still and have done some research but have some questions. Some columns are short and some very tall. (5ft or so) Dose anyone know why and what’s better? Also should I put the thermometer close too the boiling mash or at the top of the column just before the condenser? Thanks for the help.
Jan 25, 2012. 6:29 AMstevegrimmer says:
hi lemonie
im just trying your pressure cooker still out. can you give me a recipe for brandy. i saw them making moonshine brandy on telly [moonshiners] but i dont know recipe or how much to put in. thanks pal for your time,
Jan 25, 2012. 1:12 PMstevegrimmer says:
thanks pal. on telly they used fruit ie bananas. you know anything about that.
Jan 9, 2012. 11:11 AMtboy1972 says:
Hello I am wanting to kake a couple 400 gallon pots to cook my mash in what is the cheapest and simplest way i should go about doing this? Thanks Tobester
Jul 24, 2011. 8:37 AMwiseolemule says:
Do any of you out there know of a distilling process that will turn a plant product, say Hemp Budd's in to a medicinal oil?
Jan 8, 2012. 12:36 PMlx2036 says:
You're looking for an essential oil distiller. Basically a still with a longer column where steam is used to "strip" the oils out of the hemp (or whatever) held in the column itself. The key word you're looking for is "Sieve Tray Still." Google it, and if you don't turn up anything, try "essential oil distilling." I know Whiskey Still sells the smaller ones for a decent price, but if you can make your own, that'd be best and would help you learn the process better.
1-40 of 347next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
315
Author:lemonie
I'm an experimentalist, a scientist and I have a tendency to do things just for the sake of doing them, or to find out what they're like. I don't like stuff that sucks, please show me something that...
more »
