How to Make a Stylish Maxi Skirt
13,636
48
Posted in CraftFashion
Introduction: How to Make a Stylish Maxi Skirt
About: Learn how easy is to design your own clothes! The best Do-it-yourself videos on the web! Join me :D
Perfect for summer days!
You can achieve so many looks, with tops, adding a belt, according to your shape and style.
You'll need:
- Jersey, cotton jersey
- scissors
- elastic band
- Sewing machine
- pins
Good luck! :D
Step 1: First Step
Picture #1 and Picture #2: Fold the fabric and use the pins to hold it together
                                                Dobla la tela por la mitad y utiliza los alfileres para unirlas y sujetarlas juntas
Step 2: Second Step
Picture #3 and Picture #4: Cut open the side. Don't forget the pins has to go on both sides
                                               Corta un lado para que queden abiertos, no olvides colocar los alfileres en ambos lados
Step 3: Third Step
Picture #5 and Picture #6: Now is time to sew the sides, the stitch I use was simple straight
                                                Ahora llego el momento de coser los lados, solo cose con una puntilla recta.
Step 4: Fourth Step
Picture #8, Picture #9 and Picture #10: Make a hem, and leave one part open
        Realiza un dobladillo y deja una parte abierta
Step 5: Fifth Step
Picture #11: Grab the elastic band and measure around your waist
                       Agarra la banda elástica y mide por tu cintura cuanto vas a necesitar
Picture #12 and Picture #13: Now insert the elastic in the hem you just did, all around the skirt
                      Ahora coloca adentro del dobladillo el elástico, alrededor de toda la falda
Picture #14 and Picture #15: When you get al the elastic inside the hem sew together both ends
                                                     Cuando termines de colocar todo el elástico adentro del dobladillo cose las dos puntas
Picture #16 and Picture #17: Then secure the elastic by sewing again the hem with the elastic
                                                     Luego para asegurar vuelve a coser el dobladillo con el elástico.
Good Luck! :D
    • Trash to Treasure
      Trash to Treasure
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    This is so simple! It's definitely something I think I can tackle.
