Let me note at the onset that this instructable is not a joke. It is long and detailed, with lots of pictures. If you're really not interested in building a tire swing, then don't waste your time looking through it. But, if you are truly interested in building a tire swing, then this is serious and detailed instructions that ought to give you every tool to be successful. Good luck!
Remove these ads by
Signing UpStep 1: Pick out a tire!
Once the tire is chosen, look at both sides of it and determine which side looks better. This will be the top side. Flip the tire over and drill holes in the bottom sidewall. To do this, set the tire on a surface that will be at a height appropriate for drilling without straining your back. I used our new picnic table & it did the job perfectly. Use about a 1/2" drill bit and drill holes around the sidewall, ever few inches. The holes don't have to be perfectly spaced, but it'll drain better if the holes are more evenly spaced. I used the tread pattern to space the holes. Here's a picture of the bottom of the tire with the drain holes already drilled.
Visit Our Store »
Go Pro Today »
Also, the weight rating on the components you selected assumes a static weight. A 200 pound person swinging probably produces a lot more tension at the bottom of the swing arc than a 200 pound person just sitting on the swing. That said, in addition to the safety factor that you used, there is probably also a safety factor built into the numbers printed on the packaging.
Just thought you might like to know that the "connector link" you describe is commonly used in climbing and is called a maillon (pronounced may-on not mal-eee-on), can be bought for a few dollars from climbing shops. Thought it might help people find them.
All my best
Brian Bartlett
Even just taking loads of photos of the construction process and breifly outlining it in an instructable would be great, you wouldn't need to go in to the extreme detail you did here since they'd be looking to make one fore themselves.
Ever built a shed built by a civil engineer? I moved three tonnes of dirt with a shovel and a wheelbarrow, we then concreted in the main corner posts and the doorframe... The people that moved in after use moved the shed and used the foundation as a patio after tiling it, since it had to be prefectly level.
For the pinching problems with the chains you could nick the cover off a tow rope chain or even the stuff used on lock chains...
Picnic tables are pretty bad for warpage, you need a start with properly treated or seasoned wood and immediately it'll need a good seal of varnish on the whole thing to keep the water from ruining it, around ten coats does the trick. Also by that stage it should be slick enough to wipe dirt off without having stuff stick in.
I like the idea of an observation deck, this thing sounds as over the top as my plan for a three story shedhouse if Iver get land...
