Let me note at the onset that this instructable is not a joke. It is long and detailed, with lots of pictures. If you're really not interested in building a tire swing, then don't waste your time looking through it. But, if you are truly interested in building a tire swing, then this is serious and detailed instructions that ought to give you every tool to be successful. Good luck!
Remove these ads by
Signing UpStep 1Pick out a tire!
Once the tire is chosen, look at both sides of it and determine which side looks better. This will be the top side. Flip the tire over and drill holes in the bottom sidewall. To do this, set the tire on a surface that will be at a height appropriate for drilling without straining your back. I used our new picnic table & it did the job perfectly. Use about a 1/2" drill bit and drill holes around the sidewall, ever few inches. The holes don't have to be perfectly spaced, but it'll drain better if the holes are more evenly spaced. I used the tread pattern to space the holes. Here's a picture of the bottom of the tire with the drain holes already drilled.
Also, the weight rating on the components you selected assumes a static weight. A 200 pound person swinging probably produces a lot more tension at the bottom of the swing arc than a 200 pound person just sitting on the swing. That said, in addition to the safety factor that you used, there is probably also a safety factor built into the numbers printed on the packaging.
Just thought you might like to know that the "connector link" you describe is commonly used in climbing and is called a maillon (pronounced may-on not mal-eee-on), can be bought for a few dollars from climbing shops. Thought it might help people find them.
All my best
Brian Bartlett
