loading
Step 2: Attach the Eye-Bolts (Part 1)
Next, flip the tire over so that it's top-side up. This is where we're going to attach the eye-bolts that'll attach to the chains that will support the tire swing. Since a triangle is the most stable plane, you'll want to find three spots, equally spaced around the sidewall, for each eye-bolt. You can use all kinds of geometric formulas for determining the ideal spots. I simply picked an arbitrary spot for my first hole. I went ahead & drilled it with a drill bit just barely big enough for the shaft of the eye-bolt. I put it in a spot where the fender washer won't stick out over the curvature of the tire. Here's what that looks like:
<p>OK. First, let me tell you, I can barely use a butter knife and duct tape. Yes. I'm that mechanically challenged. Yes, I'm a father, and I did admit that. My 6 year old came home from school and complained she never got enough time on the swing at school...so, my fingers ran across the keyboard, and this site came up. Off to the store I went. Like one of the prior posters, a tire shop was more than happy to put a gently used (and they power washed it for me too, once they found out what I was going to use it for) 16&quot; tire in my trunk for nothing, and shook my hand on the way out, wishing me luck on my project. As you may or may not be able to tell, I'm not the tool owning guy in the neighborhood, but a $12 investment on vice grip hand pliers was worth every penny. With upgrading my drill bit, the stainless steel (to prevent rust) hardware/chains, measured all at 1/4 inch rated above 500 lbs, I spent about a $100 at Home Depot. That also included my Monster drink. 2 hours later, here are the pics. Awesome instructions - -so easy, even for a mechanically challenged father.</p><p>Thank you!!!</p><p>P.S. Do not forget the swivel at any cost!!!It's half the fun!</p>
My hubby and 13 year old daughter made this last night. They used rope to hang it from the tree, but otherwise loved the instructions! Thank you so much!
<p> There's nothing like an old-fashioned tire swing to get kids off their electronics and using their energy and imaginations. And for those of you with children/ grandchildren in your family, check out the children's book High in the Sky by Kathleen Gauer. A bouncy, fun-to-read story that follows a child's energetic and wildly imaginative adventures - all while riding a tire swing. A book to delight young and old alike! Get your signed copy at www.skippingstonepress.net</p>
slightly modified with tow belt instead of longer chain. kids love it!
<p>I'm having trouble finding heavy duty eye bolts. Please could you give some guidance on the size / spec?</p>
What about using rope instead of chain? Does that work?
<p>im gonna do that</p>
Wow that was 2 years ago I made that comment :)
<p>ill try it my mom and dad is taking dow my accaul backyard swing:( no fun</p>
Made it using these directions this week -- super easy and the kids love it!
I made the swing and it came out great!
<p>This inspired me to get a tire swing! I found a used tire place that GAVE me the &quot;junk&quot; tire. I bought chains and links rated 660-2200 lbs so, no issue on whomever was going to get on it. I forgot the swivel. so I'm headed back tomorrow to get that! Thanks for the help!</p>
I followed your instructions to a point, I used an old swing to hang over the tree, all my parts came from an old swing set and I used a 19 inch tire. Except instead of using chain I used rope and its holding up, to me, my older daughter and my 3 year old
we made ours but the only problem is when our daughter (who is 3) sits on one side opposite side lifts up as she swings and there is slack in the chain. any ideas to correct this?
Thanks for the detailed instructions. We just made this swing this weekend and it took about an hour and $80 worth of hardware. Our branch is pretty high and the tire is really big so we got heavier load capacity components and chain. We also added braided rubber tubing as a means to protect the branch and the kids' fingers; just thread the chain through the tube or pull like you would wire through conduit.<br>One note our tire is pretty big and is steel reinforced so drilling the cores on the bottom was pretty tough!
Appreciate this alot. We decided to do this before we saw your project. We googled the how to and this came up first. It helped us finish what we already figured out.<br>For an even more frugal project, we used swing hardware salvaged from an old metal swing set we found. Thanks again.
We are using your instructions to build this swing for our little guy this weekend, as an Easter present. We really appreciate your clear and thorough instructions. Thank you for sharing, and I will posts some pics as soon as we unveil!
<p>We used an old car tire for this one. Works like a charm and can hold almost the entire family! I didn't use a clip hook, but instead opted for some extra connector links to put it all together.</p>
<p>Great directions! You made it easy for us tool challenged people.</p>
<p>It's not clear to me why you have the clip hook and how it'd be used to adjust the height of the tire from the ground. Hooking to the chain anywhere gives you the exact same height. The only obvious (to me) way to change the length from the tree is to use the connector link that closes the chain to close it with a shorter chain loop (i.e., leave some links out of the closed loop).</p>
hi this is excellent!! I just bought all my hardware yesterday... will rope work as well as the chain? and how did you decide the 3 pieces of chain should be 3'? and how tall off the ground you say?
Thank you so much for sharing this very detailed and thorough tutorial. I just &quot;acquired&quot; a tire from my car and have been dying to make it a swing for my 3yo, but had no idea where to begin except the ol' school rope-over-a-limb approach. I'm super excited to get this going for my first Spring project of the year!
Another Tire Swing tutorial suggested running the part of the chain that will touch the limb through a piece of heavy duty garden hose to protect the tree limb. What are your thoughts on that? Also, we will be using our swing in our front yard only when our grandkids come to visit a few times a year. It appears that your system would allow us to take it down when not in use and easily re-hang it when the kids come. Is that possible with this design?
The garden hose will certainly help - I'd even go a step further and suggest wrapping the branch with a carpet sample square (usually available for a few dollars @ a carpet store). You basically want to avoid any rubbing of the bark. The concept is the same as wearing leather gloves when working with shovels/axes/etc. - the in between layer takes the brunt of the friction so your skin (or bark, if you happen to be an Ent or some other type of tree) stays safe.
Ran across this post last week, after a friend gave me a very nice &quot;used&quot; tire from a previous tire swing (roped) and about $50 in materials, I now have a wonderful tire swing that can support a minimum of 800lbs :) Thank you for the how to and here's to the many hours of fun and enjoyment my boys will get out of this swing!!! p.s. I used a sadle connector due to buying too big a hook for my chain :)
This is great tire swing. It is exactly what I was looking for. Thank you for letting me know the weight limits too. My only real problem is I am hanging it from the walk-way on my dock which is metal. I am hoping if I add hose around the top chain, it will minimize the loud metal and chain clanking or grinding.
Just finished ours, thank you so much for the idea - our monster tire and 800 lb rating can fit up to 3 heavy adults safely. However, check if all the components fit together at the shop! Also, check the weight ratings (some brands only rate to 20 lb, especially on the S hooks). I can see this being a 10+ hour project and future headache if you don't. If I build another my shopping list would be the tire, the 3 &quot;complete&quot; eye bolts, 6 C links, the swivel, and the 4 chain lengths; 3 C's would be to connect the chains to the tire (instead of S hooks), 1 to connect the 3 chains together to the swivel, 1 to connect the other end of the swivel to the long chain, and 1 to adjust the long chain length. The 1/4&quot; C links are rated for heavier than the 3/8 and 1/2&quot; S hooks (at least at Lowe's). This project cost about $100 for me with a free tire, however I can see it being under $50 if you can get the chain online / on sale.
Thanks for this great Instructable. We followed your instructions and ended up with a perfect tire swing for our three-year-old. He's thrilled!
Excellent instructions, thank you! A few variations: instead of all chain, I used 3/4&quot; nylon 1,450lb WLL rope from the limb (16' up). To attach to the tire, I used &quot;swingset chain&quot; that was already coated with plastic. Instead of 'S' hooks, I used quick-links. Everything else was exactly the same as yours. My 8yo son and I did this together as a father/son project, and he was absolutely giddy about it! :-)
what would be the weight limit for this swing?
I've got a 4x6 beam, about 9 feet off ground, setup for a couple of swings for my 4 and 7 year old grand kids. Wondering how much room would be needed between support post for a tire swing with one of those swivel brackets? Or I could do the swing like in this forum and how much space should I leave?Thanks
Does anyone know what to coat the tires with to get them to be hard and shiny and smooth, like on a playground? I'm thinking of using Krylon plastic spray paint. That way they tires won't leave marks and detriorate in the heat/sun as the rubber leeches out its checmicals that make it soft.
thank you for the easy-to-understand directions and pictures. the swing (and your yard in general) are very handsome.
A suggestion. Wasps/hornets are territorial. If they find an existing nest they won't build in that area. I've seen decoy nests on Gardener Supply Company's webpage. Hang one of those near the swing and they shouldn't be a problem.
Does the swivel get any side load when the kids are swinging? I am about to build this for three 7 year olds and I know they will test the limits of its range of motion. I would guess the swivel's rating doesn't factor anything in besides tension.<br> Also, the weight rating on the components you selected assumes a static weight. A 200 pound person <em>swinging</em> probably produces a lot more tension at the bottom of the swing arc than a 200 pound person just sitting on the swing. That said, in addition to the safety factor that you used, there is probably also a safety factor built into the numbers printed on the packaging.<br>
Thank s a bunch for this idea and great instructable! -Mike
Excellent instructions and photos. I thank you and I know my grandkids will thank you. Bill
Hey ya'll if you have a 1&quot; hole saw or a big drill bit drill 3 holes in the bottom side of the tire. This will let all the H20 drain out. most side walls are reinforced with nylon not steel belts. But I have a problem, my tire is several years old the black coming off is excessive. How do I stop it? I power washed it, can I wax it?
Great instructable here. Here's my 2 cents (from an aerospace engineer working in structures). For any given swing, if you were to start 90 degrees from the vertical, the tension in the chain at the bottom of the arc will be 3 times your weight. Therefore, PLEASE PLEASE make sure that your rope or chain working load limit (WLL) is at least 3X the maximum load of the swing. I wanted my swing to accomodate a 250 lb adult, and therefore needed components with a 750 lb WLL. The big weak link in your design here are the eyelets. I could only find eyelets with a 80 lb WLL after searching around! This means the swing is really only safe with a 80 lb child ((3-80lb eyelets * 80 lbs)/3MG)=80 lb. I strongly recommend using ubolts instead for the chain-to-tire attachments, especially if your swing will be used by adults and is potentially dangerous (my chaiin length is over 20 ft!)
Forgot to mention my advice is against the non-welded eye bolts as pictured in your tutorial. Welded eye bolts are another story and are much stronger (but also harder to come by - neither home depot or lowes sells these in my area)
Brilliant ible :D<br /> <br /> Just thought you might like to know that the &quot;connector link&quot;&nbsp;you describe is commonly used in climbing and is called a maillon&nbsp;(pronounced may-on not mal-eee-on), can be bought for a few dollars from climbing shops. Thought it might help people find them. <br />
Instructions were great!&nbsp; DH just hung our swing last weekend after purchasing everything we needed at Lowe's and he did a fab job!&nbsp; We have plenty of trees in the back yard but none with an appropriate limb for the swing.&nbsp;My husband (former boy scout and retired Navy) advised me it was no problem...he would &quot;lash some boards to the trees.&quot;&nbsp; I was the doubting thomas but it all worked out great.&nbsp; He screwed together 2 - 2x6 boards for strength and lashed them in between 2 trees, nothing was screwed into the trees.&nbsp; He tested it with his 200 lb weight and all is well.&nbsp; Now we just have to wait for the grandkids (7 and 5) to arrive from Germany for the month of July.&nbsp; I am sure they will have tons of fun!!&nbsp; Thank you adlabens for taking the time to post these instructions and inspiring us all!&nbsp; <em>I have been unable to upload photos...sorry.</em>
Hey I just wanted to say that I used your directions and built a killer tire swing. I had rented a 43' lift for the day to cut down some tree limbs and thought ahead of time that that would be a great idea to put up a tire swing the same day. I spent about $65.00 in materials by using a heavy duty manilla rope 3/4'' that has a weight capacity of 640lbs and bought 15' of chain for the triangle down to the tire itself. The tire was free from my local motorcycle shop. They were more than happy to give away as many tires as I could take. So I grabbed 5 of them. One suggestion if you have the option is to try the tire out on your backside first before stringing it up. I had one of the five picked out but then asked my wife to see what she thought and she went and put it on her tushie and said no go. She proceeded to try out the other ones which were of different diameters and found one that &quot;fit good&quot;&nbsp; It happened to be the Harley Davidson tire. Everything looks great and the kids love it. I've roped the tire up to an eye bolt running through a limb about 30' feet up so the kids have a nice big swing. The swivel works great and I used lithium grease on it to keep it quiet. Good suggestion.&nbsp; One more suggestion that should be obvious to most folks. Watch out where the tire swings to. We have some electrical wires that our tire could hit if you were to swing high enough but most of our kids won't be swinging that high. But it could happen. I'm just saying that folks should check that before stringing up. Thanks soooo much for your helps and suggestion. They saved me money and time. <br /> All my best<br /> Brian Bartlett<br />
Great instructions! All supplies were at Lowes and a tire store gave us a free tire. Swing is over 50 feet high and my kids love it! It cost half the cost to make than it would cost to purchase from a swing-set store. Thanks for the Instructable.
Liandyk, I was at a tire shop the other day, and talked with them about building another tire swing. They offered to give me one of their used tires for that purpose - they service tractor/trailers, so it was a HUGE tire & would have sat at least 4 kids, maybe 8! So, if folks are nice & don't want to use the tires for their vehicles, it seems this is a good way to get a tire! Also, with a tire that size, I'd have used four supporting chains rather than the 3 I used on the motorcycle tire. And, with 4, even on the motorcycle tire, it would have made it easier for two children to share it. That may be the only mistake I made.
Ok guys...I'm a 56 year old school teacher (white haired and female) and I made one of these for my 2 year old granddaughter. It was easy, the directions are great. I did add the tubing over the chains to avoid pinched fingers. She loves it! I got all the components at Lowe's and it was worth every penny. It is the first thing she goes for when she gets out of the car. We expect many years of use. Thank you, Aldabens...good job!
NCurrier, I am humbled by your praise. I'm just 6 years younger than you, but my children (ages 7 & 3 & 3) love it also. Yep, I started a bit late. But the kids love it just the same! Thank you.
Where can one buy a swivel?
About This Instructable
956,066views
203favorites
More by adlabens:How to make a tire swing!
Add instructable to:
