3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Shape Shifting Wood Trivet
Step 5Connect the pieces
Connect the pieces
In order to connect the pieces you should make the connections out of a silicone sheet (if you can't find any check out the last picture). The length between the two holes has to be the diameter of your wooden disks.
The holes need to be a bit bigger then then your small wooden pieces. I've started to cut the outline with the circle and the box cutter and when I was done with all the pieces, I started cutting the smaller holes.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
177
Author:BrittLiv
I'm a Chemical and Biological Engineering student especially interested in Computational Fluid Dynamics. To balance all the theoretical work I like to make stuff in my free time.
