Step 4Printing your photo on tissue paper
Take your strips of 10 x 20cm tissue paper. Put double sided adhesive on upper and lower side.
Attach to middle of printer paper.
Do NOT use common tape as it will melt in your laser printer and make it useless (take my word for granted, I have tried)
Print the 5 documents on the 5 pieces of tissue paper
If you're using Mac OS X, though, there's a place you can adjust the amount of ink used! From the dropdown menu in the Print dialog (It usually says "Layout"), choose "Advanced Printing Options." From there, you can move the ink volume slider down. Just moving it down one notch worked wonders for me.
Also, if you use an inkjet printer, there's no need for double-sided tape, because inkjets don't rely on heat like laser printers. Regular scotch tape worked fine for me.
If yours is an HP, in printer properties, set it to print in greyscale with black cartridge only.
can I ask what type of tissue? must it be single sheet? For example, some tissue is multi-ply.
