Introduction: How to Make a Vertical, Ergonomic (tie-fighter) Keyboard
Inspired by the discussion about vertical mice and keyboards on my Ergonomic work station Instructable I decided to give a vertical keyboard a chance. I checked out the Safetype, but was disappointed both by the horizontal placement of the arrow keys and the price. So, I decided to make my own tie-fighter-like vertical ergonomic keyboard.
The tie-fighter keyboard allows you type in a neutral, handshake position with your arms and shoulders supporting your hands. I consider this to be one of the lowest stress positions. As you can't look down to the see the keys, you do need to touch type to do use this; typing in passwords can, admittedly, be a bit frustrating but I'll take that over sore wrists any day.
I figure that we evolved, among other things, to pick berries rather than typing on a keyboard all day long. The tie-fighter vertical keyboard position is a lot closer to a berry-picking position than a standard keyboard.
Check out my other various ergonomic Instructables: Ergonomic Work Station, Stand Up Desk, Standing Desk, and Create an Ergonomic Standing Desk and Office on the Go.
Step 1: Motivation and Parts
A handshake position (thumb up) seems to be the most neutral and strain-free position for my hands. I've been using a handshake-position mouse (3M Ergonomic mouse) for a few years, and feel that it doesn't cause much harm. I'm not certain any computer input device causes no harm, and have recently added left and right handed Evoluent vertical mice to the mix. I now switch between left and right handed mousing at work and use the 3M at home.
However, my keyboard, a Goldtouch, only goes to about 30 degrees. So, in comparison to the mice, it is essentially flat. This position has been incrementally bothering me more and more.
Parts
Goldtouch Keyboard - they seem to run $150 new, so grab one on Ebay. I've bought several, all in great condition and some even new, for $30-$50 each.
wood - 2x4, 2x3, whatever scrap you have lying around
wood screws
2 outdoor adjustable light fixtures
Step 2: Disassemble the Goldtouch
The Goldtouch is a really easy to take apart, and I applaud them for making a hacker-friendly device.
Remove the screws and take off the bottom half of the case. Remove the screws holding the ball joint in place.
Step 3: Estimate Position
With the bottom half of the case removed, free the wire connecting the two sections of the keyboard. Using some books, or whatever you have, position the two half approximately how you would use them. I went for shoulder width apart. With the thickness of the keyboard itself, this yielded 10 inches between the two sections.
Luckily, there seems to be just enough extra wire to accommodate this positioning.
Type for a little bit to convince yourself this isn't a totally crazy idea.
Step 4: Cut the Case
There's enough wire to go between the two sections, but not enough to use the existing holes for the wire. So, mark the case to expose more of the wire, and cut it with a rotary tool.
Step 5: Try This First -- Argh! It's Terrible.
At first, I thought perfectly vertical would be just fine. So, I measured, cut, and screwed into the bottom of the case two 2x4s.
The resulting keyboard position was terrible, as you can see by the bent wrists required to use it. So, I knew that I needed it to be adjustable.
Step 6: Substitute Ball Joint
What I really wanted was a ball-joint, like the one the Gold Touch comes with. Unfortunately, I couldn't make that one work, and industrial ball-joints from places like McMaster-Carr are too expensive. So, I made my own 3-degree-of-freedom joint from outdoor lightbulb fixtures.
Take two light fixtures, remove the internal light bulb mount, and cut off the housing around that mount. I used a hacksaw, cut the housing off, and then filed any remaining material leaving a flat surface. Drill holes and bolt two of these together with the adjusters 90 degrees out of phase. Their screw mounts give you freedom of movement in the roll direction on both sides of the keyboard, one toothed adjuster gives pitch, and the other gives jaw freedom of movement.
Since I already had the 2x4's mounted to my keyboard, I cut them apart and screwed on pieces of plywood to attach the light fixture's screw mounts.
I held my hands at neutral, had someone measure their position, and then adjusted the keyboard into that position.
Step 7: Type!
Have fun typing in a neutral position. Watch your friends marvel at your keyboard, and then puzzle over how to use it.
I've been typing on this thing for a few months, and I'm pretty happy with it. My hands feel fine after a reasonable work session. Sometimes, I do still have trouble finding the square bracket keys. However, as with any piece of computer interface hardware, I think it's just a new and different way to damage yourself, so I'm careful to maintain stretch breaks and limits on use.
Fission_Chips (author)2015-10-29
Looks awesome!
xrothgarx (author)2013-02-20
I just got a gold touch keyboard at work and am curious if you have found any way to let your wrists rest while at the keyboard. I find my wrists hurt because I have to hold them flat while I'm typing instead of resting them on a pad of some sort. I'm thinking about hacking together a wrist rest but was curious if you have discovered anything that helped.
ilpug (author)2012-03-22
Well, Now I again curse myself for not learning how to type hands free. Bummer. Great build.
tlockney (author)2007-09-14
Hmm, I'd say you could just about perfectly rest a book in between the two halves. Would be great for reference material or working through tutorials. ;~)
ewilhelm (author)tlockney2007-09-14
You can, and I do! I wouldn't transcribe something long from that position though; looking down like that for long periods of time tends to strain your back.
Punkguyta (author)ewilhelm2007-12-18
I can actually map an entire keyboard in my head as I type, when I take my laptop to school, when I'm copying notes, I can type the entire thing without ever looking at the screen, pages, I know in my head what I'm typing in my head, as I type it, and when I look down at the screen, it's exactly what was in my head, maybe one or two spelling errors, but nothing you probably wouldn't screw up once in a while anyways. I don't know of anyone else that can do this (am I born with it??) But I know that it is very useful, that on top of the fact that I can type very quickly, and if I get into it, there seems to be a high speed mode I can get into where I can do paragraphs a second.
tinker234 (author)Punkguyta2011-06-03
me too when i go to my school i just type i acutally sleep cause i know evrythihng to teach
ac7ss (author)Punkguyta2009-10-30
It is called "Touch Typing." Most people who need to can learn to do it. Unless you are managing to do this without touching the keyboard. (do you jack in? )
Punkguyta (author)ac7ss2009-10-31
 lmao no. I wish. But yeah, I'm a good touch typer.
narnboy1 (author)2010-12-02
To really reinforce the touch typing, Tape or paint the keys.
Recommend a flat keyboard first.....
Somewhat funny, I look @ my keyboard half the time in lighted areas, but touch type while driving with my laptop or in dark areas. - Homemade pedestal in my work van.
Just like texting and driving, don't drive and type
bluegillfly (author)2010-04-21
I have a Goldtouch with a broken U-joint cluttering my cubicle (among other junk, of course <g>). I've been thinking of getting a Safetype but wow, the price!
This gives me a perfect proof of concept project before I lay out any serious cash. Thanks! :-)
umursengul (author)2010-02-18
 That is gonna be perfect for my garage! Thanks!
mettaurlover (author)2009-08-26
I would've epoxied the brackets to the keyboard. easier(for me) and doesn't require screws.
frankly1970 (author)2007-09-21
i would recommend using bent plexliglas if possible in keeping with the contemporary look. brazing yields great results for that matter. i love a good 2x4 but when the ladies come over i'd hate to have to explain the sawdust on my desktop. nice idea. this also prevents crumbs from collectig in between the keys.
ewilhelm (author)frankly19702007-09-21
I vacuumed up all the sawdust, and ladies love my 2x4s!
marcocen (author)ewilhelm2009-05-14
yeah, totally, best comment I've ever seen
Lithium Rain (author)ewilhelm2008-05-25
Best. Comment. EVER.
zachninme (author)ewilhelm2007-09-21
I'm afraid... Although, you do have a computer setup with bunches of wires in what looks to be the middle of the room... lucky... Then again, people can peek over your shoulder... I think I like my dark corner of the basement!
ewilhelm (author)zachninme2007-09-21
Not only in the middle of the room, it's in the kitchen!
Thats... so... AWESOME!!!
If you flip the keyboard over, can you use it as a plate? Or do you hide trash under there?
budsiskos (author)2008-03-31
oh great, another torturous technic to get kids to learn how to type without looking at the keyboard :)
diN0bot (author)2008-02-04
on mine the ball joint screws require an allen wrench.
diN0bot (author)diN0bot2008-02-04
i decided on mine to lay them against my legs. I use loops on my pants to hold in place. Maybe I'll post a sewing follow-up instructable. My main problem with the goldtouch is that the pinky keys are still pretty far away (delete, return, ctrl<--mapped to caps lock). wish there were thumb/forefinger keys for these instead, but oh well. will see how this works out. foot pedals might be a solution for that problem. wrt hand position i hope this helps.
diN0bot (author)diN0bot2008-03-08
yeah!
foot pedal added
thanks for the inspiration with the goldtouch.
(i'd tried cutting a keyboard in half and soldering longer wires between the halves, but i didn't make it, and without copper wire the soldering messed up the plastic pretty bad.)
bedbugg2 (author)2007-12-01
tie fighter! awesomness, id use this but i have a laptop and im still learning to touch type :)
zorro3355 (author)2007-11-06
i don't find it useful in anyway....
ewilhelm (author)zorro33552007-11-07
So why did you comment?
zorro3355 (author)ewilhelm2007-11-07
it looks lkind of cool, but can you explain to me how it helps?thanks
ewilhelm (author)zorro33552007-11-08
Make sure you've read step 1.
IamTheCreator (author)2007-10-06
Ha nice, really cool/futuristic looking. I feel like it would take me some getting used to though.
marc92 (author)2007-09-22
is standing while working at that setup uncomfortable for long periods rrof time. I would think a chair would be more comfortable, even though we have not adapted to picking berries while seated. (lol)
ewilhelm (author)marc922007-09-24
I sit all day at work, so when I go home, and work some more, I like to stand just to change up the position. For me, standing is comfortable for a couple of hours.
lofgren (author)2007-09-18
Nice work on the ergonomic posts.
As an I.T. guy sitting at my desk for 6-9 hours a day and then going home for more, I am always interested in ergonomic ideas.
Sadly the "freaky" and "alternative" (and often very home-made looking) desks and solutions scare a lot of people who just want things to be the same, flat and shiny. Got to do what feels right for your spine and tendons though!
I am lucky enough to have been afforded one of these in my workplace (had to go through an OH and S process/hassle to get one though).
http://www.therapod.com.au/
It has certainly helped my issues. Probably not as much as keeping active and regular stretches though.
In Australia we're looking at $250 - $290 (after taxes and shipping) for many of the ergonomic keyboards and mice available out there. Makes it a little tough to source.
I have to get around to posting my desk setup - basically a solid pull out drawer with a curved edge, that contours to your desk interaction. It is at the right height for my feet to be flat on the floor and maintain those 90% ergonomic angles. Also good because it slides out to the right distance from the screen and packs away nicely when done.
keep up the good work! ;)
ewilhelm (author)lofgren2007-09-19
I look forward to seeing your setup!
davem (author)2007-09-16
briliant!
I want one!
geekdude (author)2007-09-15
i think you should embed the keyboard into the arms of a recliner. i thought about doing that once. then you could build the computer into the recliner, and have a lcd monitor on a swivel arm. just make sure the computer doesn't get crunched by the recline action
i make shooting things (author)2007-09-14
did you have to changed your "typing technique" or is it the same except its vertical
It's the same.
zachninme (author)2007-09-14
Cool! I saw this in another ible, glad to see it documented. I can't tell from the pictures, but are there any "overlap" keys, keys on both keyboards? For me, I sometimes hit a key with the "wrong" finger if the other one was in another far away key, and this is a big reason why I can't use split keyboards.
ewilhelm (author)zachninme2007-09-14
The Goldtouch does not have overlap keys. To be honest, when I started typing on split keyboards, it didn't even occur to me that this could be a problem.
ningo (author)zachninme2007-09-14
Counting keys on the step one picture suggests that there are no overlap keys...but what a good idea! When I first saw the picture, I assumed that this was a standard keyboard that had been chopped in two and a new top casing vacuum-formed or something similar-with wire cross links between the two halves of the membrane. If you did that trick with two identical keyboards, you could implement crossover keys, and you also would not require an expensive board to start with (at the expense of more time spent manufacturing).
Whaleman (author)2007-09-14
Cool! But, I don't know if I know how to type well enough to type vertically. And It wouldn't fit on my sliding keyboard thing.
About This Instructable
43,777views
59favorites
License:
Bio: Eric J. Wilhelm is the founder of Instructables. He has a Ph.D. from MIT in Mechanical Engineering. Eric believes in making technology accessible through ... More »
More by ewilhelm:LEGO table with integrated parts binCustom Wooden Train Track X-crossingMad Max and War Boy Nux father son costume
Add instructable to:
