3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a vibrating motor.
Sometimes you need a vibrating motor but just don't have a spare massager on hand to take apart. This usually leaves you with three options:
1. You can buy one online from your favorite electronics site (but this will cost you an arm and a leg).
2. You can take your chances with a massager from the Goodwill Store (but who knows where that has been).
3. Or if you have five minutes to spare, you can build your own.
Not liking to spend great deals of money or break out in strange rashes, I prefer option number 3.
Step 1Go get stuff.
Go get stuff.
You will need:
- DC motor with a plastic gear attached to the shaft (easily found in tape players, VCRs, printers, etc.)
- An alligator clip
- Soldering iron
- Some solder
44 comments
1-40 of 44next »
Nov 12, 2008. 2:22 PMknoxarama says:
i stuck a piece of clay on the gear head and it worked just fine
Apr 6, 2012. 8:26 AMmohtaprashantrocks says:
although it could fly off and stick on the mirror like mine did (the clay ) lol
Dec 9, 2011. 10:28 PMethiran says:
is this can be used for tamiya motors?
Jul 15, 2011. 10:27 AMvishalapr says:
This is soooo useful!
I was making a vibro bot and I needed a vibrating motor but couldn't get any in hand so I was wondering what to do and then I notice this instructable and then think! I had lots of spare motors so I made this and it works perfectly!
Thanks for sharing such and awesome tip!
Feb 22, 2011. 3:02 AMheadlessknight says:
don't you mean "roach" clip sorry for the spelling no sleep for 2 days
trying to be funny there but i would have never tthink that up
Nov 30, 2010. 11:18 AMDrasa says:
lol, melting the clip. Great 'ible!
Jul 26, 2010. 10:47 AMprodo123 says:
Or you could hot-glue it.
Oct 8, 2010. 1:42 PMJodex says:
I know - from experience - hot glue won't hold it well enough. Or at least with my motors, but that may depend on the motor's power.
Oct 8, 2010. 2:17 PMprodo123 says:
Overkill...but epoxy it on? :V or melt the gearhead with a hot glue gun and mold the clip in place?
Nov 20, 2006. 2:23 PMWade Tarzia says:
How about an adjustable vibrating motor? Attach a large gear on the motor with holes drilled radially (make them balance on either side of course), then use a screw set into the holes -- the farther from the edge, the more vibration. You know, Instructables really makes me think -- before today, I never ever thought about how to make an adjustable vibrating motor; I don't know why this will be important to me someday, but I think it will; I have that confidence in The Ways The World Works, and to hell with the despair of Cold Chaos! (though I believe in that too).
Jul 20, 2007. 2:56 AMPR22 says:
just adjust the voltage with a variable resistor
Aug 15, 2008. 10:38 PMSaint_Awesome says:
That would work but would waste a lot of energy via heat, which won't happen with Pulse Width Modulation and such.
Jul 22, 2010. 6:59 PMredneckjaybyrd says:
A potentiometer would work.
Jan 24, 2010. 10:22 AMonlylooklikepackrat says:
I am looking at the PWM circuits floating around. In the meantime, Sir Fix a Lot sent along an idea...old train transformers!
Mar 23, 2010. 9:29 AMFlyinseamnky says:
Now if someone could write an instructable on how to turn your bed into a vibrating bed like in cheap motels. LOL Pay timer optional. LOL I am sure you would need 4 of these one for each bed leg, or one for the center post running sycncronized with a standard 120 wall plug, and a switch of some kind. Is anyone up for the challange? LOL Probably better (no jail time required) and cheaper than stealing on from a motel as my friend wanted to. LOL Thanks.
Dec 15, 2009. 5:44 PMjosh1001 says:
 u could have also shaved of some of the teeth form one side of the gear, it would look better.
Oct 31, 2007. 11:04 PMwildgorilla says:
Help. Need instructions. Read that rats can lose weight by standing on a plate vibrating at 90 times/minute. Need to build a vibrating platform for my overweight daughter who has cerebral Buzz Platepalsy. Should have ability to vary vibrations. Thanks.
Dec 3, 2009. 3:23 AMSir-fix-a-lot says:
Hello Wildgorilla!
There's more than 2 years between your post and mine, but I hope this is still usefull:
Scientists have proven that the vibration plates that are used in gyms and sold commercially have no effect, or even are counter productive. You can read about that here: http://www.ergo-log.com/vibplate2.html
I understand you are talking about another frequency, I'm curious about how effective this is in humans.
Good luck!
Nov 1, 2007. 8:17 AMwildgorilla says:
Thanks randofo.
Sep 10, 2009. 12:12 AMbeetn_chan says:
is it possible to fix the vibrating motor in cuff to make a massager? Does the motor produces large amount of heat?
Mar 19, 2009. 10:51 PMjesse99 says:
how do you power this?
Apr 16, 2009. 3:30 PMcoatesy900 says:
with a battery...
Nov 28, 2008. 7:46 PMTh3Snip3r says:
You could also take one of the motors from a PS2 controller. But just for this, its not really necessary especially at the controllers being $25 bucks. But I have a bunch of broken ones my buddies give me to hold onto for parts and things.
Nov 25, 2006. 7:14 PMbf5man says:
Or a cork, here's how i did it:
Apr 26, 2008. 7:32 PMmcdonn123 says:
With a cork you can adjust the vibration. Sweet!
Dec 3, 2009. 2:50 AMSir-fix-a-lot says:
Here's another simple method:
use the metal part of a screw terminal as shown in the picture. There are different sizes, so you can choose different weights or you can remove one screw for lighter vibrations. It works really well! I use these in adult toys I make for friends.
Mar 31, 2010. 2:44 PMpagosapig says:
I usually use the spinner from a CPU disk reader. They have the middle whole and three symmetrical holes about a half centimeter out. It works very well for vibrating beam robots.
Nov 15, 2006. 5:22 PMCanDo says:
Neat, what times have you needed a vibrating motor?
Jul 20, 2007. 2:48 AMPR22 says:
sex toys
Mar 31, 2007. 10:40 PMlucianoabcd says:
I will try one for making a smooth bzzzz on the snare drum. I think it should work, however in my case the shaft should be small (ie shorter than the radius of the motor, so it doesn't touch the head of the snare) yet powerful. Any ideas?
Dec 9, 2007. 10:35 AMmasterochicken says:
I would use an old xbox controller's motor
Nov 15, 2006. 5:27 PMtrebuchet03 says:
All sorts of uses -- sifting materials of dissimilar density, leveling your cake batter, getting bubbles out of resin-concrete-glue-etc. and more. Simple drawing circuits (there was a project on Make: that did this).
Nov 20, 2006. 2:18 PMWade Tarzia says:
Yes! Your neighborhood archaeologist can use that! Fill screen, turn on motor, eat lunch, come back, and your glass beads, clovis points, and diamond-eyed idols are jingle-jangling there at the bottom of the screen.
Nov 16, 2006. 9:07 PMCanDo says:
Cool, I see... something to keep in mind then.
Nov 15, 2006. 6:18 PMrarcke says:
Give one in a case to your girlfriend, she'll know what to do with it.
Nov 16, 2006. 8:47 AMJack Daniels says:
by the looks of it somone already knew what to do with it...
Nov 15, 2006. 8:16 PMTheCheese9921 says:
lol
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2351
Author:randofo(Randy Sarafan loves you!)
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
