3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a wooden ring
A ring that I had from Vietnam recently broke, leaving an emptiness on my finger and soul, so I decided to fill that emptiness with a lil bit of craftiness.
Step 1Materials and tools
A piece of wood preferably with an interesting grain pattern (I used wenge)
Some sort of finish
Hole saw
Forstner bit
Drum sander
Belt Sander
53 comments
1-40 of 53next »
Dec 17, 2011. 4:19 PMInstructable04 says:
Ow dam!! Dad and I have tried EVERY POSSIBLE ON-HAND WOOD!!! I am still wondering if pine would be alright?? See, the prob is that the wood keeps on splitting...We also tried using hickory wood, split split split SPLIT!
Dec 24, 2011. 12:52 AMsmurfsahoy says:
Well you just need to do a lot more research on wood properties then...
Pine is a terrible choice for a ring, because it A) has a huge, loose grain and is full of things like knots, so getting a detailed shape out of it is going to be difficult without splitting, and B) it's really soft and inappropriate for being on your finger where it will get dented immediately, even if you could make it.
Hickory is pretty much the most difficult wood in the world to work with (with the possible exception of ebony). It splits like crazy and will jam router bits and break tools and all kinds of things.
You want a tight grained hardwood that is durable but easy to work. Like maple, cherry, or walnut. There's a reason finely detailed furniture is always made out of those woods, and never pine or hickory.
Dec 19, 2011. 3:50 PMhatschel says:
The ring will be broken befor or after.
Beliv it or not.
It´s importent to make the wood´n peace in te right direction vertikal like the tree grows
Or the better way glue 4 peaces of wood together and then make the ring.
I make mine on a lathe.
sry about my bad english
Dec 17, 2011. 1:41 PMInstructable04 says:
Hey,
Two questions. One is can you use like ANY wood with a grain pattern? and would this be suitable for my girlfriend if done properly?? I love the look of them!
Dec 18, 2011. 11:10 PMInstructable04 says:
Thanks quomaya2.
Jul 12, 2011. 2:14 AMshadow wave rider says:
what does wengelicious mean?
Nov 7, 2011. 2:40 PMsquiggy2 says:
It's when your wenge is too delicious to be expressed with multiple words.
Read: http://en.wikipedia.org/wiki/Portmanteau
Jul 3, 2011. 9:40 PMddbear says:
http://www.instructables.com/id/Mens-5-Cent-Ring/step4/Mount-The-Ring/
I found this Instructable helpful when sanding my rings! It works on the wooden and metal ones! This is my picture of it which may be a bit more simple!
Jun 26, 2011. 8:40 PMdaemonfist says:
Just made one of these this weekend using pretty much the exact same methods here (hadn't even looked online for instructions...LOL)...anyways, I found that a Rotary tool with a drum sander attachment will work nicely as well!
Apr 19, 2011. 10:21 AMJon316 says:
Thanks man this really helped, although i didnt have a hole saw, I still made an awesome ring.
Jul 16, 2010. 12:25 AMtinstructable says:
Sorry, i'm kinda new to woodworking... what is a forstner bit? I'm sure we have one, i just don't know what it is...
Feb 18, 2010. 11:16 AMForgetMyProfile says:
respectfully, I think that you have steps 3 and 4 backwards.
Most hole saws have a pilot drill bit for keeping the hole cutting saw in one place while cutting. If you drill the inner hole first, there is no place to put the pilot bit in one place to do the outer diameter of the ring. Ever tried it with a hand drill? I'm not sure it can be done.
Yes, I do see the drill press. While I'm certain you have a vice of some kind to hold the work steady while the outer ring is done secondly,  those who DON'T have a drill press are going to have a rough time if they have to use a whole saw without the help of the pilot drill.
Doing it my way makes more sense . . . at least to me.
Good, interesting instructable.
Robb
Lush, tropical Grand Rapids, Michigan.
Feb 19, 2010. 7:21 PMsimplebeep says:
Here's the way I see it:
- If you drill the outer ring first, then it becomes much harder to hold the inner disc of wood while drilling the inner ring.
- If you drill the inner ring first, you can't see just where you're placing the bit for the outer hole, and you won't be able to center it precisely.
- As this instructable suggests, you can center the rings by "marking" the outer one first, then help hold everything in place by drilling inside then outside. It's really a compromise between the two methods.
Feb 19, 2010. 9:13 AMseamountie says:
That is why you do step 2.  You partially drill the outer "ring".  This is then your guide after removing the core.  This can be done easily even with a hand drill.
Feb 18, 2010. 8:08 PManfractuosities says:
I made a bunch of rings just like this with some scrap cocoboro that I had lying around. I made a bunch, b/c they kept splitting. They looked great though
Feb 18, 2010. 1:31 PMzaniac77 says:
This is cool. You know, I would think over time that your own body oils would shine it right up if you just put a light wax on it at first to get it going. :)
Feb 18, 2010. 2:52 PMac-dc says:
That's what you might want to avoid, as perspiration could make it swell, sweat isn't considered neutral in ph, and you can get fungus growing in/on the wood.
I don't know what the best treatment is, but I would lean towards an initial treatment with light oil to penetrate it, then liberally apply silicone grease rather than wax or oil because it is more resistant to detergent, if you got any soap or dishwater/etc on your hands it is less likely to strip the grease off.
Feb 18, 2010. 4:40 PMzaniac77 says:
Yep, that's probably true. My brain is on pause today, apparently. ^_^
Feb 18, 2010. 9:57 AMhydrnium.h2 says:
Lol, "This wooden o", totally misinterpreted, could apply to this
Feb 18, 2010. 7:22 AMwortmanb says:
I do this by laminating together 5 2x2 or 2.5x2.5 squares of wood into a sandwich; usually with a dark wood like wenge for the middle layer (and I'll take a piece that's 1/8" thick and sand or plane it down a bit), then two layers of maple or walnut veneer to set that piece off, then outer pieces of a wood to contrast with the wenge, like padauk.  Each layer switches the direction of the grain by 90 degrees, like in plywood, so that there's less chance of a stress crack along the grain carrying through the piece.  I use Gorilla glue for maximum water resistance, though TiteBond III should work as well.
I drill a 1/2" hole in the center using a forstner bit and then, after trimming off the corners to make the whole thing octagonal, mount it on a sanding sleeve and stick it in my dremel (since I don't have a lathe).  I then use files & sandpaper to shape the outside and end up carefully shaping the inside with a smaller sanding sleeve on the dremel.  Arm-R-Seal to finish.
Gave one to my wife for our anniversary last year and she absolutely loved it.  This method isn't necessarily better (though I think the lamination gives additional strength) but it's an alternate way to approach shaping the rings.
Feb 18, 2010. 8:30 AMProp says:
I laminate 3, 1/8th pieces... drill with a forstner or spade bit.... then I use a knife and size the ring to whatever the requested size is (if you do this pay attention to grain direction while carving)... I then use a flush cut saw and guide block to cut the out side of the ring to mostly round and sad from there.... My process can be done entirely by had once the wood is planed to the right thikness
Feb 15, 2010. 9:45 AMunseen wombat says:
it's a cool idea, but won't the part where the grain is perpendicular to the ring split?
If I were doing it, I'd go for bending very thin veneers of some flexible wood like ash or white oak to the diameter of your finger and gluing together. Then the grain direction goes around the hoop at all points. Sand it properly and you probably won't even see the glue joint.
Feb 18, 2010. 8:26 AMProp says:
You can make the ring quomaya2 made in then add bent veneer on top of it and it will make a very strong ring... Make the ring then put it on a lath... use a parting tool to make a groove then inset veneer into it.
Feb 17, 2010. 4:44 PMthepelton says:
Elm has a very interlocked grain, making it very difficult to split.
Feb 15, 2010. 5:29 PMTheDevilsRubberDucky says:
 y not laquer or poly?
btw laquer and poly are totally different finishes so poly is not "laquerish"
Feb 18, 2010. 8:21 AMProp says:
I have tried several different finishes for wood rings and have watched them as there used by people... poly and lacquer tend to chip and wear in not so good ways..... lint seed oil wears too fast unless its a mix of lint seed oil and varnish. This is a very good finish if you want a dull finish and it lasts.... Cyanoacrylate (CA glue / Superglue) gives the most durable high gloss finish but is really hard to get on properly. If you do it do it on a lath or in a drill and make sure you dont touch it with skin for at least 24 hours.... My favorite finish for rings right now is shellac... it dries very fast and still looks great even after is worn.
May 21, 2012. 2:46 PMBard says:
If its too thick couldn't you just re sand it down then try again?
Feb 16, 2010. 3:50 PMbigmark says:
So cool!!!  You could use the"mangled piece of crap"as a napkin ring.
Feb 16, 2010. 8:54 AMguatsamosa says:
I happened to make one as a christmas present for my dad but I used some driftwood which was super dry and kinda brittle, but it helped to soak it for a little while in some lemon oil.
Also if you want it to be shiny you can spray a coating or two of Polyurethane stuff on it and it works pretty well and makes it harder. Nice Instructable btw!!
Feb 16, 2010. 5:50 AMbowmaster says:
Sweet, I just got some new hole saws, now I know what I'll use them for.
Feb 15, 2010. 7:40 PMsssssbooom says:
I always turn my rings on my lathe. I have made a couple out of cherry and some out of purple heart.
Feb 14, 2010. 4:29 PMWeissensteinburg says:
 This is great. I tried to make a wooden cryptex once, but didn't know this method to cutting rings. What type of lumber is that?
Feb 14, 2010. 8:03 PMVespa O says:
Just a safety note on Wenge, WEAR A DUST MASK! The dust can be real nasty! It is a respiratory irritant and then there is what is known as the "Wenge trip" yep... it can cause mild sensory distortion...
1-40 of 53next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:quomaya2
