3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a wooden ring
Step 7Final sanding and finishing
I suggest hand sanding after you've got it down to the size you want. You also might want to round out the edges. I used paste wax to finish it. Some type of oil would probably also work well. I'd be careful using anything like lacquer or polyurethane because the coat might go on too thick and then it wouldn't fit your finger. Now, you should either have a beautiful ring or a useless, mangled piece of crap. If you should have a useless, mangled piece of crap, repeat steps 1-6.
6 comments
Jul 12, 2011. 2:14 AMshadow wave rider says:
what does wengelicious mean?
Nov 7, 2011. 2:40 PMsquiggy2 says:
It's when your wenge is too delicious to be expressed with multiple words.
Read: http://en.wikipedia.org/wiki/Portmanteau
Feb 18, 2010. 1:31 PMzaniac77 says:
This is cool. You know, I would think over time that your own body oils would shine it right up if you just put a light wax on it at first to get it going. :)
Feb 18, 2010. 2:52 PMac-dc says:
That's what you might want to avoid, as perspiration could make it swell, sweat isn't considered neutral in ph, and you can get fungus growing in/on the wood.
I don't know what the best treatment is, but I would lean towards an initial treatment with light oil to penetrate it, then liberally apply silicone grease rather than wax or oil because it is more resistant to detergent, if you got any soap or dishwater/etc on your hands it is less likely to strip the grease off.
Feb 18, 2010. 4:40 PMzaniac77 says:
Yep, that's probably true. My brain is on pause today, apparently. ^_^
Feb 15, 2010. 5:29 PMTheDevilsRubberDucky says:
 y not laquer or poly?
btw laquer and poly are totally different finishes so poly is not "laquerish"
Feb 18, 2010. 8:21 AMProp says:
I have tried several different finishes for wood rings and have watched them as there used by people... poly and lacquer tend to chip and wear in not so good ways..... lint seed oil wears too fast unless its a mix of lint seed oil and varnish. This is a very good finish if you want a dull finish and it lasts.... Cyanoacrylate (CA glue / Superglue) gives the most durable high gloss finish but is really hard to get on properly. If you do it do it on a lath or in a drill and make sure you dont touch it with skin for at least 24 hours.... My favorite finish for rings right now is shellac... it dries very fast and still looks great even after is worn.
May 21, 2012. 2:46 PMBard says:
If its too thick couldn't you just re sand it down then try again?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:quomaya2
