3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a wood "tobacco" pipe the easy way
This Instructable will go the through the process of making a tobacco pipe ;-). Making a pipe is a simple process that takes an average time of 2 to 3 hours (assuming no major mistakes).
Materials you will need :
A good hardwood stick 1" in diameter - I used peach wood because of availability
A drill and selection of bits - I used a 1/8th inch bit and the largest bit (maybe 1/2 inch)
Propane torch or other source of high temp fire - for fire hardening / charring
Sand Paper in varying grades
Knife - Preferably a good carving knife
Wood Saw - (guess what this is for)
Mineral Oil or similar - For waterproofing and making it shiny :-)
Optional but suggested
Grinding block or similar - Rough shape adjustments
Dremel tool - Bowl shape adjustments
Thin steel rod - 3 mm square on the end
Steel wool - For making it even more shiny
Honey - For coating inside of bowl
Ashes - Used with honey bowl to fireproof
Step 1Get a good stick
Get a good stick
For my pipe I chose peach wood because it is easy to work with and already lying in my back yard.
Look for a reasonably fresh stick just over an inch in diameter and without any knots. Your pipe's length is limited by your drill bit's length however while wood can be trimmed down it can't be trimmed up. As such I suggest you cut your stick around an inch longer than you plan for it to be.
31 comments
Feb 7, 2012. 4:47 PMTraxis55 says:
Do i put the ashes inside the bowl? i got that you put the honey in the bowl, but then do you put the ashes in the bowl so they stick to the honey? and then do i knock out the ashes?
Oct 19, 2011. 2:12 PMdscore says:
Have you tried this pipe with herbal mixes like mullein or rosemary? Would a carb be used in such a situation?
Mar 20, 2011. 2:47 PMDWordDtour says:
is this step necessary or can we leave it plain color?
Sep 11, 2011. 3:26 PMtsvoboda says:
I really don't think this is necessary. I'm fairly sure it's just to help make the pipe harder/ more fire resistant.
Aug 13, 2011. 12:24 AMHex1408 says:
could you please answer that question because i am also wondering if it is necessary
Jul 20, 2011. 10:29 AMHobo_Thoreau says:
Thank you so much for this instructable! I now have the perfect anniversary gift for my girlfriend. She's going to love it!
Nov 29, 2010. 4:37 PMbrandman5678 says:
do you need to keep adding honey in the bowl after useing it alot
Jun 27, 2010. 3:55 AMFlash Gordon says:
This is very interesting. I made a "tobacco" pipe too. Mine was made out of an old chair leg haha and i didnt really take time to shape it at all as i am very lazy.
Nov 12, 2009. 7:28 PMGibStud says:
what kind of ashes? How tiny a piece of paper towel? Does this step have to "cure" at all or do you want to fireproof   periodically? Thanks!
May 27, 2010. 11:56 AMmistahmaxi says:
It doesn't really matter what kind of ashes you use. There is really no other type of ash than ashes. And you should probaply measure the piece of paper using your bowl. The one this guy made would probaply need about a 1,5 squareinch piece. You dont have to do it several times to complete the fireproof. Allthough you should do the fireproofing more than one time, since its "shield" will not stay on forever.
Dec 29, 2009. 8:13 PMcartman says:
 Very nice!! I have been searching for how to make a pipe for a while. This is great!!
Oct 4, 2009. 4:20 PMNyastorm says:
Hi, You say to drill the holes at the right angle but what is the angle? And what size drillbit did you use?
Oct 12, 2009. 11:56 PMSpint180 says:
Lol at timing.
Jul 23, 2009. 7:22 PMbiofueljunke says:
thats not a tobacco pipe (but lets call it one) thats awsum and green its made of local materials but you could use veg rather than mineral oil because mineral oil is petrolium. but its great it will not get to hot and no energy is used to ship it from who knows where
Aug 7, 2009. 7:47 AMlil jon168 says:
looks like a cigar
Jul 4, 2009. 12:07 AMChiana_Rei says:
Another thing you can do is to just "Burn-In" the bowl. Basically you place a small amount of actual tobbacco in the bowl because this is cheaper just make sure to use a nice flavor you will enjoy. Then light it and puff the pipe getting lots of smoke and heat and stop when you have good carbon coverage. When the bowl is black you are done and you will never burn thru the bowl as long as you don't scrape the black off. During normal smoking of "any" type you will build up carbon over time. Just use a ferrule or pocket knife to scrape it down to a nice thin layer.
Jun 27, 2009. 2:53 AMyoung_bucc says:
also added to my comment below i would like to put my name on it like engraven/burnt is the best way i can explain it and i dont have fancy tools or nothin so how would i go about doing that?
Jun 24, 2009. 7:36 PMericlin81 says:
Hi, i am searching for a pipe made from peachwood which is 40cm long. Can you make it for me? ericlin81@yahoo.com.sg
Jun 22, 2009. 3:21 PMsurtuo3 says:
I have been using this pipe for a long while now. I love it. Great Instructable
Jun 8, 2009. 1:05 PMlemonie says:
Great build. (Tobacco pipes don't have carb-holes though.)
L
Jun 8, 2009. 2:48 PMpsychostick says:
I think he knows that. That is why there are quotations around the word tobacco. By the way if this comes off as being harsh I do apologize.
Jun 8, 2009. 2:53 PMlemonie says:
I didn't notice that first time around, perhaps it's been amended? Still it's a good pipe. L
Jun 8, 2009. 11:33 PMnachosyumm says:
haha, nice pipe, the carb holes confused me for awhile though, then i noticed the quotes. did you torch it for asthetics or to dry the wood?
Jun 8, 2009. 2:49 PMFocker says:
Rofl @ lemonie's comment I liked the ible, and what really blew me away was the fireproofing method using honey. How often do you need to "rehoney" the bowl? Is it a one time thing and presto?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:greenengineer
