3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a wooden hammer
This is a great idea to make a wooden hammer that would be very effective in combat. It has a sturdy head, a sharp back for a stab attack, and spikes on both ends of the handle.
Step 1Materials
Materials
You will need gorilla tape, a half inch thick wooden dowel(length to your liking), a wooden shim(found a home depot), and any multi-tool that has a saw and a knife.
9 comments
Nov 1, 2011. 6:05 AMcurvy77 says:
i understand how this would be effective and its a good design. but i dont think any specific dowel is needed for i just grabbed a random branch from my yard and used that.
Mar 27, 2010. 9:20 AMnvxcmz says:
cool instructable,  but you might as well just hit the guy with a base ball bat.
Jan 2, 2010. 2:07 AMLokisgodhi says:
If your going to be hitting any(thing/one) with this you need to make some changes.
First, don't use anything less than a 1" oak dowel.  A standard 3 foot dowel, as a minimum, should be used to have enough leverage.
Second, you want to get four to six 1" ID metal conduit couplings.
http://www.grainger.com/Grainger/items/2CLP4?Pid=search
Slide them over the dowel to reinforce it and keep it from splitting from the impact. If they're too tight, sand the dowel slightly until they fit. If they're too loose, place the coupling where you want it. Then apply a little CA adhesive and let wick under the coupling.
Third, when you have the head on the shaft, drill a pair of holes about 1/4" diameter through the head and the shaft. Then pin it to the shaft with metal pins driven into the holes..
Oct 9, 2009. 1:22 PMConfederate1956 says:
If I may suggest, a half-inch dowel is too thin for any serious use as a weapon, and would not give a good grip in any case.  A tool handle (such as that for an eye hoe, for example) would give much better results.  As for the head, may I suggest laminating a head out of red oak or possibly one of the heavy tropical hardwoods?  Yes, this would make it more expensive, and the work would require heavier-duty tools, but the results would be worth it, IMHO.  Thanks!
Aug 22, 2009. 11:18 AMBaddi says:
cool
Jul 29, 2009. 1:11 PMKiteman says:
This is a neat idea, but the instructable would be much better with actual photographs of what you did.
Instead of tape, you might consider twine or leather thonging, to give the mallet a more "stone age" (wood age?) feel.
Jul 29, 2009. 4:03 PMWolf Seril says:
I'm guessing he doesn't have pictures because he hasn't done it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ltk1144
I live in Phoenix, Arizona. I am very outdoorsy and like to go and bike in the dessert near my house.I enjoy Halo series games and love camping. I like to carve wood with my knife and make cool stuff ...
more »
