A wort chiller is a device that cools down wort (unfermented beer) after boiling. Cooling down wort rapidly is important because it helps to reduce the chances of bacteria from growing before you pitch the yeast. Yeast needs a certain temperature to live - too hot and you will kill the yeast, too cold and it may not ferment properly. Rapidly cooling wort is also important because it will help to discourage certain off-flavors in the finished brew.
There are mainly four methods of cooling wort rapidly. Immersion chillers are put into the wort and cold water is passed through to cool the wort. Counter-flow chillers are the opposite. They pass hot wort through cold water. Immersing the hot pot of wort in an ice bath is another way. You can also pour hot wort into cold water. The goal is to cool it as quickly as possible. Home brewers using partial-mash and all grain recipes typically find that wort chillers produce the best results.
My wort chiller passes hot wort through a copper coil submerged in a cooler filled with ice water and out through a ball valve on the side. The wort will drain out into a primary fermenting bucket where I can pitch the yeast and ferment the beer.
Remove these ads by
Signing UpStep 1Installing the ball valve on a cooler
http://www.instructables.com/id/Installing-a-ball-valve-on-a-Coleman-cooler/
- A similar coil is constructed to run cold water through the coil which is immersed into the wort at the last part of the boil.
- Wort is on the outside, so sterilization comes instantly when the heat shock hits the copper. Also very easy to clean.
- 15 minutes to cool wort
- manual whirlpool puts hot trub into a cone, and not into your fermenter
- Easier to make as you don't need a separate unit like an insulated cooler.
- Cold all the way through the chilling process, and not a gradual change to warmer coolant, which reduces efficiency. Yeast like cool wort.
I actually started with something similar to this project but with a 5 gallon bucket instead of a cooler but made the mistake of using smaller tubing and got a thick stout almost stuck in it. So i converted it to an immersion for a while but then decided to go with a whole new counterflow chiller. I'll have to put an instructable on it up some time. It was a royal pain in the rear to make, but with some small changes to procedure, wouldn't be that bad.
Let's not forget the goal.
I suspect that after you're finished with the mashing process, you can use a part called a "Quick Disconnect" to switch out whatever you're using as a filter and replace it with the chiller coil. Stainless QD's are often expensive.
YMMV, I've never tried it before.
ok im a novice to homebrew but looking at making the leap from basic kits to extract brewing. So ive been doing some research and planning on making my own immersion wort chiller and i had a few ideas i thought id share with you.
IDEA 1. the countercurrent system is very effective as dp69 said and shows up all over in nature, usually with respiration (fish gills, bird lungs) or thermoregulation which is what we want a chiller to do.
Cold liquids fall like cold air does (untill it gets colder than 4oC when it starts rising, for a complicated reason Im not gonna go into). this means that to get a counter current its best to make the cold water go into the pipe that goes right to the bottom where the wort is coolest and this will give a very basic countercurrent. cold water going up the coil and cold wort falling down over it.
IDEA 2. the colder the water going in the pipe the better. so how about making 2 seperate copper coils attached by plastic hose. the water come from a cold tap into the 1st coil which is immersed in a bucket of ice water. the water then flows out of that coil super cold and into the immersion cooler.
what do u guys think? if/when i get into more advanced brewing ill make one of these and post an ible. it will hopefully be pretty effcient even if not as good as this one.
Way too complicated. In terms of efficiency, if you were going to use gravity to pre-cool water that will be flowing through an immersion chiller, it seems like you might be wasting a little effort. Perhaps try looking at electronic or drill-driven pumps that will take ice cold water from a cooler or bucket and circulate it through your immersion chiller. You'd still get the effect of shooting the ice cold water through the hot wort, but with less piping involved. What you are describing is almost like a jockey-box for water.
Idea 1:
The same electronic or drill-driven pump system would work with a counter-flow chiller much like what you are describing. You would have a reservoir of ice-cold water and would pump it over the hot wort within the inner copper coil. You can learn how to make a counter-flow chiller here:
www.homebrewtalk.com/wiki/index.php/How_to_make_a_Counter_Flow_Chiller
Of course, I'm not shooting down your idea - I'd love to be proven wrong. That way, I'd have an excuse to make more beer paraphernalia!
Since you obviously use 3/8" transfer tubing, you could have cut costs down by skipping at least the top hose barb adapter and related fittings. The 3/8" ID hose fits snugly over the 3/8" OD copper tubing, and it also eliminates the lip at the joint in the fitting that could harbor bacteria, which makes cleaning and sanitizing easier.
