Air muscles (also known as a McKibben artificial muscle or braided pneumatic actuators) were originally developed by J.L. McKibben in the 1950's as an orthotic appliance for polio patients.
Here's how they work:
The muscle consists of a rubber tube (bladder or core) that is surrounded by a tubular braided fiber mesh sleeve. When the bladder is inflated the mesh expands radially and contracts axially (since the mesh fibers are inextensible), shortening the overall length of the muscle and subsequently producing a pulling force.
Air muscles have performance characteristics very similar to human muscles- the force exerted decreases as the muscle contracts. This is due to the change in the interweave angle of the braided mesh as the muscle contracts- as the mesh expands radially in a scissors like motion it exerts less force due to the weave angle becoming increasingly shallow as the muscle contracts (see the diagram below- figure A shows that the muscle will contract to a greater degree than figure C given an equal increase in bladder pressure).The videos show this effect as well. Air muscles can contract up to 40% of their length, depending on the method and materials of their construction.
Gas law states that if you increase pressure you also increase the volume of an expandable cylinder (provided temperature is constant.) The expanding volume of the bladder is ultimately constrained by the physical properties of the braided mesh sleeve so in order to create a greater pulling force you need to be able to increase the effective volume of the bladder- the pulling force of the muscle is a function of the length and diameter of the muscle as well as its ability to contract due to the properties of the mesh sleeve (construction material, number of fibers, interweave angle) and bladder material.
I constructed two different sized muscles using similar materials to demonstrate this principle- they both were operated at the same air pressure (60psi) but had different diameters and lengths. The small muscle really starts to struggle when some weight is put on it while the larger muscle has no problems at all.
Here are a couple of videos showing both of the constructed air muscles in action.
Now let's go make some muscles!
Remove these ads by
Signing UpStep 1: Materials
Amazon
You'll need an air source:
I used a small air tank with a pressure regulator but you can also use a bicycle air pump (you will have to make an adapter to make it work with the 1/4" poly hose.
Air tank- Amazon
Pressure regulator (will require a 1/8" NPT female to 1/4" NPT male adapter)- Amazon
1/4" high pressure poly tubing- Amazon
multitool (screwdriver, scissors, pliers, wire cutters)- Amazon
lighter
for the small muscle:
1/4" silicone or latex tubing- Amazon
3/8" braided nylon mesh sleeve (see above)
1/8" small hose barb (brass or nylon)- Amazon
small bolt (10-24 thread by 3/8 in length works well)- Amazon
steel safety wire- Amazon
for the large muscle:
3/8" silicone or latex tubing- Amazon
1/2" braided nylon mesh sleeve- Amazon
1/8" or similar sized drill bit- Amazon
21/64" drill bit- Amazon
1/8" x 27 NPT tap- Amazon
1/8" hose barb x 1/8" pipe thread adapter- Amazon
small hose clamps- Amazon
3/4" aluminum or plastic rod to construct the muscle ends- Amazon
Safety note- make sure you wear safety glasses when testing your air muscles! A high pressure hose that pops off a loose fitting could cause a serious injury!
Visit Our Store »
Go Pro Today »
If this works out, do you plan to extend the exoskeleton to more body parts? I just read Wearable Robots: Biomechatronic Exoskeletons and I suppose I'm interested in working on the same sort of thing. Also, I just found this website, are other people here working on exoskeletons?
I made a couple of the muscles that chewee threw up here that worked well but it just seems like an awful lot of wasted air that could be recycled and make any reserve tank last longer.
Just throwing that out there.
I come back along from year to year to see if anyone else has pooped another gem of amazing. First time I've ever posted. Good luck!
How exactly the pressure regulator works with the air muscle?
I presume that when i turn the regulator for one side, the muscle contracts, when i turn to the oderside, releases the air inside it and relaxes.
It's correct?
http://www.mcmaster.com/#air-solenoid-control-valves/=dpt784
http://www.clippard.com/store/byo_electronic/byo_mouse_valves.asp
There's tons of companies out there but you have to do a Google search and do some serious digging to get all the info/pricing.
If someone achive sucess in building a cheap and simple substitute to the solenois valves in this kind of project i hope that he posts the tutorial here...
=D
I've built de muscle, but if i put pressure on unloaded muscle, it does not contract alot at 30psi. Instead of other eamples where you say 60psi is allready enough to get the maximum displacement.
There is air flow, although i think not enough pressure. Or the tube is to strong ?
It is a tube of 2mm wall thickness, in stead of your 1/16 inch or 1,5mm.
I'm asking cuz i took a scare when the previous air muscle (without sleave) bulged out the end of the muscle untill it exploded there. And the muscle did not blow up homogenously.
Any thoughts ?
All tubes are made of sillicone tubing and i've got 3 sizes:
8mm ID 12mm OD
10mm ID 14mm OD
6mm ID 10mm OD
(every wall is thus about 2mm thick)
IIf I may ask, about what maximum pressure have you put on the muscles ?
My muscle is about 30cm long made with the 8x12mm for the moment.
I don't have a weight on the muscle, so maybe that's the problem I't doesn't contract that much ( as you stated in your instructable)
thanks
They used it for natural rotational movements by coiling it around the section they wished to rotate after attaching one end to it and the other to a fixed point on the structure of the puppet.
They told me at the time they had a few nasty accidents developing this, mainly getting whipped or hit by high pressure hoses.
They also said that hydraulic systems were "a pain in the a**! " But they could be wrong....
Thank you all for such wonderful info :)
I am just a kid so i dont think i can get my hands on those things...yet.
My second thought is what would happen if this was switched to hydraulic versus pneumatic?
Thoughts anyone?
Both have their benefits: pneumatic is light, compressible and may be cheaper to manufacture, hydraulic offers power, silence, and wider operating parameters.
In a 'powered' suit, I think pneumatic might be a better option due to cost and weight.
The book was more involved, but the movie was a smart adaptation I thought. The movie was definitely better after reading the book though.
Hydraulic would prob be best for both. While fingers don’t require much strength they would need the precise controllability of a hydraulic actuator. Air is compressible so it would be difficult to control how much the 'muscle' contracts.
There are simply too many applications to mention (and pursue) here.
This gets my vote for a "best instructable" 2010.
I would love to see more applications of this and also if there are other alternatives to emulate the human muscles.
http://www.youtube.com/watch?v=jMHvziAikok&feature=related
This has so much potential.
As for braided mesh, how about the braided copper wire shielding on some coaxial cable. The copper mesh can be soldered to a fastener at each end to make attachment easy. Granted it is not very big around but several smaller muscles in tandem can exert a lot of power. Also, how about liquid rather than air. Liquid does not compress and you may end up with a stronger, more responsive muscle. A mechanically driven syringe would work as a source of pressure.
Ah well. This is very cool as well :-)
Flex-eriffic, Honus.
They're a local electronics surplus supplier that I use.
The braided nylon sleeve reminds me of thoes chinese finger trap things where you put a finger in each end and cant get them out.
woops sry for the spoiler
*insert evil laugh here*
I will try a larger bladder because i build they to full contract and put a large pressure on the but they don't full contract...(low weigh loaded)
ah, i wrote wrong... not air leaks but air gaps between the mesh and bladder when the muscle is contracted..if you know how to solve plz tell me
ah have you plans to a homemade solenoid valve? because they are very expensive....and i need some of these..... if you have plans plz send-me tanks
I found a pressure sensor but it does not support 60PSI and does not do totally what I wanted.
http://www.trossenrobotics.com/store/p/3226-Pressure-Sensor.aspx
For the controller I plan on using several InterfaceKit 0/16/16 from Trossen Robotics connected to an AMD quad core with 8GB RAM. I plan on writing the controller code in Java using the drools rule engine.
http://www.trossenrobotics.com/store/p/3201-InterfaceKit-0-16-16.aspx
They have all kinds of valves and controllers and they built a really incredible pneumatic arm.
http://www.cycling74.com/products/maxoverview
http://processing.org/
http://www.arduino.cc
http://www.makingthings.com
http://www.onlinemetals.com/merchant.cfm?id=195&step=2&top_cat=60
Have a look here:
http://www.vexrobotics.com/vex-robotics-pneumatic-parts.shtml#vex-pneumatics-kit-1a
Just scroll down- the one you want is the AV5-01 and it sells for $35.
I saw this and nearly fell out of my chair... freakin' insane.
As for the bend sensors and microcontroller have a look here: http://www.instructables.com/id/EH2BKVEF1U9XT76/
I'm currently working on a three way servo operated air valve that will be simple to construct.
A two inch long cricket powered by air muscles with its own tiny on board air compressor!
http://www.umich.edu/news/index.html?Releases/2007/Feb07/exoskeleton-vids
And here:
http://www-personal.umich.edu/~ferrisdp/pneumatics.html
This is also pretty cool:
http://news.com.com/2300-11394_3-6120170-1.html
shadow robot
how to make
http://www.merlinrobotics.co.uk
