In other words, this circuit allows you to quickly reverse the direction a motor is spinning by using a switch or controller chip to change its direction.
I'm going to show you how to make the simplest and most reliable form of H-bridge that I know how to make. I must warn you that this is by no means the best H-bridge design and, in fact, it has a couple shortcoming which I will explain later.
Although, should you never have made an H-bridge before or simply need a circuit that can reverse the direction of a motor's spin, then this circuit is a quick and easy solution.
(You will notice the motor freaks out when I flip the switch. That is the motor changing directions!)
This H-Bridge was made with the love and support of Eyebeam
Remove these ads by
Signing UpStep 1Go get stuff.
4 - SPST 5VDC Reed Relays (Radioshack Model: 275-232 Catalog #: 275-232)
1 - SPDT 5VDC Reed Relay (Radioshack Model: 275-240 Catalog #: 275-240)
1 - package of 9V battery clips (Radioshack Model: 270-324 Catalog #: 270-324)
1 - 9V battery
1 - Toggle or slide switch (SPST)
1 - 7805 Voltage Regulator (Radioshack Model: 7805 Catalog #: 276-1770)
1 - PC Board (Radioshack Model: 276-150 Catalog #: 276-150)
1 - reversible DC motor
(You can find a reversible DC motor inside a broken Walkman or Discman. For those of you in NYC, you can get a motor and/or broken Walkman at Argo Electronics - 393 Canal Street)
I've posted a little instructable with it here.
