Step 4About our circuit.
Okay.... so this is how it works...
Power from the battery is going to the 7805 voltage regulator where is converted to 5V. Power from the battery is also going to "Relay 1" and "Relay 2" where it goes to the motor (but we're getting ahead of ourselves).
The 5V power is both going to the coil of the SPDT relay and it is also passing through the the SPDT relay. So, when the switch is closed, 5V flows through the coil of the SPDT relay and 5V also is routed through the SPDT relay to the coils of "Relay 1" and "Relay 4" forcing them to close. This allows 9V to flow through "Relay 1" and "Relay 4" in a way in which the motor can spin in a clockwise direction.
In other words, when we close the switch connected to the coil on the SPDT relay, we are triggering the H-bridge to allow the motor to spin clockwise.
Therefore, if we want the motor to spin counter-clockwise all we would need to do is flick the switch in the opposite direction. This will change the path through which the electricity passes through the SPDT relay and in turn close "Relay 2" and "Relay 3" (and by extension open "Relay 1" and "Relay 4").
4
comments
Add Comment
Deviantgeek
says:
Add Comment
