Recently I acquired some samples of IR LED's, and a matching IR Phototransistor.
I was bored, and decided to make something with it!
In order to make the transmitter, you will need
1 IR LED
2 AA Batteries + case
150 ohm resistor (1 watt, or two 1/2 watt 75 ohms)
To make the receiver, you will need:
1 IR Phototransistor, (needs to be the compliment of the IR LED)
1 Darlington transistor Or MOSFET (I used a TIP31, for the MOSFET version I used a IRFP510)
Low ohm resistor (1-10 ohms, I used 2.2 ohms)
And a small heatsink!
1 10k resistor
Diode (optional)
10k Potentiometer (also optional, allows to adjust sensitivity)
If you have a soldering iron it helps a LOT to have. It makes putting everything together 10x easier. I just made mine on a breadboard.
Remove these ads by
Signing UpStep 1Assemble the transmitter!
The IR Phototransistor looks exactly like an LED, though it might be darker (daylight filter, so the sun doesn't turn it on though mine still had issues with it)
The transistor needs a heatsink depending on how heavy your load is, or how long you plan on running it.
I'm going to eventually try and change the transmitter to transmit audio signals, so I can have a wireless audio system! ^^
The issue with this though is that solid objects tend to block the IR.
The diode is used to prevent silly people from hooking everything up backwards (+ to negative, etc)
This circuit is pretty universal, and depending on what type of transistor you use you can make a lot of stuff remote controlled!
The Potentiometer is there to adjust sensitivity to the IR LED.
Hopefully I'll get it done in a few days, and we'll see how well it works. It's going to be slightly more complicated though.
