How to Make an Indestructible Money Box
16,897
51
19
Posted
Introduction: How to Make an Indestructible Money Box
Money boxes are a great way for kids to save money for a special purpose.
Unfortunately we can get tempted to spend the money on other things before we have reached our goal. That's when this money box is useful.
Most money boxes have an opening that allows us to simply take out the money whenever we want. The sad thing about this is that it usually means then box never gets full.
Made from chequer-plate steel, this money box is easy to put coins into, but it's really really hard to make withdrawals.
Please note that you might need to use a grinder or oxy to get the money out, so perhaps it's only for coins, not banknotes.
Step 1: What You Will Need
Steel plate. Whatever you can lay your hands on. It should be light enough to work on, but heavy enough to weld easily.
Measuring and marking gear. Tape and chalk.
Something to cut with. I used an angle grinder.
An angle grinder for grinding.
A welder. I'm lucky enough to have a MIG. It's fantastic.
A hammer also might come in handy.
Step 2: What to Do
To make a cube you only need six square sides. If you have enough steel you can cut out a single shape that can be folded to make a cube. That will save some cutting and welding.
  • Mark out the shapes you need on the steel.
  • Cut the steel.
  • Grind the edges so they weld nicely.
  • Assemble the cube and tack it together.
  • Weld all joints.
  • Clean up the welds with a grinder.
  • Cut a slot to drop coins through. Position it where coins won't easily come out.
  • My steel was a bit rusty so I cleaned it a bit wit a wire brush.
Check out this video to see how I did it...
Step 3: Other Possibilities
As you can see I've made a few different shapes.
The smaller cube has been opened twice. You can see where I have patched it.
I hope you have enjoyed this Instructable.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    19 Comments
    Nice! I like your examples, especially the heart-shaped box! Have you ever been asked to cut one open to retrieve the money inside?
    I just used the angle grinder to open the money boxes. Then weld a patch over the hole. The patches actually look quite cool.
    We did learn that heat isn't good for plastic bank notes though.
    If you were making a money box out of a milo tin and wanted to use it upside down so that the lid could be used to get the money out of, how would you make the slot in the top (the bottom of the tin) to drop the money in?
    I am trying to get some ideas on a money drop box safe for a business, the door has got me allittle an really cant find a decent lock
    I know how you feel. You will notice I did not include any door at all on mine. Very secure, but not very convenient.
    I might have missed it, but how does one open the box?
    I want to buy one right now, if anybody makes these and let me know. I seriously seriously want this.
    jnearing144@gmail.com
    also, it must be large, like a milk crate.
    That's pretty big! Enough to hold about a million bucks. I'll make one for you if you are in Australia, but if you are elsewhere, freight would be excessive.
