3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make an Iron Man Mask
Step 2Outlining the mask
Outlining the mask
This was perhaps the most challenging part of the mask. I knew I wanted it to be smooth all over and that means making the mask from a single piece of cardboard (or as few joins as possible). To avoid the whole thing getting totally out of hand I decided to only make the gold parts of the mask, I'll let someone else work out how to do the whole suit.
I took my time to draw a template for the mask, knowing that I would need multiple copies of it to complete the mask. I ended up with 5/6 parts for a complete mask (5/6 will be explained shortly).
I headed off to the photocopier to save myself some effort and get some perfect copies. These would be better copied onto card so feel free to scale and print this template to your hearts content.
There are two main parts, the forehead and the faceplate. To get the curvature of the forehead I had to seperate the edges and attach them seperately. This adds strength to the design and because the seams are right on the corners they are barely noticable.
The faceplate has some nice curves which help to shape the face but ultimately do nothing in the way of strengthing it. The jaw on the faceplate will be seperated for the top layers of the mask but left on for the bottom layers (hence 5 or 6 pieces)
The images show the mask cut and assembled although this is discussed more in the next step.
12 comments
Nov 9, 2010. 12:27 PMjesusfreak14 says:
dude i am working on mine right now
Feb 18, 2010. 6:08 PMMr. Shaggy135 says:
This was so worth it, I made and added the rest of the helmet, it took me over 12 hours because I made it with metal. Thanks for your help and your templates!
Aug 19, 2009. 1:18 AMeli241 says:
could you post the template on a link that would work easy so we can print it
Oct 5, 2009. 8:00 AMironmask says:
Sep 13, 2009. 5:56 AMironfan says:
i can spend 100$-150$ on the mask and im makeing it out of aluminum with a larger power sorce (car battery ect.) but great layout please make a actual size one so i can print.
Aug 16, 2009. 4:19 PMIron man freak says:
Definetly email me the template, I'm not a pro member so cant download the pdf i you could post it on my page that'd be great
Aug 5, 2008. 8:52 AMiron boy on the look out says:
i found your instructions realy good and helpful as an iron man fan having a mask like that is a dream come true ur gr8 ps can i use yellow funky foam to finish mytop layer
Jun 24, 2009. 7:11 AMdombeef says:
Yeah
Oct 30, 2008. 7:27 PMmrcampliftl2005 says:
Could you send or post the template...
Jun 13, 2008. 6:05 AMdavis396 says:
can you make a template for us to download so we can print it off can you use "paint"
Sep 25, 2008. 6:10 PMslimguy379 says:
yes agreed please post a template...... where did you get yours even a link.... would work
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
125
Author:msraynsford
