3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make an LED ready to install into a car!
In this instructable, you will learn how to prep an LED to be ready to install into a car! This means adding a resistor and soldering on some leads. When you are finished, you can do so many things with them and save a few bux too.
If you enjoyed that video, don't forget to subscribe to my channel as I produce quick DIY videos usually once a week or so.
Step 1Get your supplies
Get your supplies
You will need wire, an LED and a 560 ohm 1/4 watt resistor.
50 comments
1-40 of 50next »
Apr 4, 2011. 10:17 PMSOAD92 says:
I was trying to do this but I have no idea on how to hook up it to give the LEDs power. Although I did do a simple circuit with a switch, but it was no big deal, and the connections I made to the 12v lighter jack would not hold to the little clips(soldered). If you can help me out on this I would GREATLY appreciate this!
Feb 2, 2008. 2:36 PMSWV1787 says:
My best friend did a similar install but hid a few green LEDs in his air vents it made a nice eerie glow when turned on.
Nov 18, 2010. 10:37 AMtwighahn says:
green is good for holloween decor so is orange
May 24, 2009. 3:12 PMpdlbooboo says:
i have a cig jack and i'm trying to put some leds in parallel but as i add more leds the further out ones get dimmer. how can i get around this. also i am putting a resistor on each led and am only trying to use 5 leds
May 26, 2009. 8:34 AMpdlbooboo says:
there is no wire going in between each led. they r soldered directly to each other. i tried doing the same process accept with only one resistor on the first led. this worked ok but i don't know if this would shorten the life of the led or not. i dont know if i made this clear or not but theleds as a whole r not getting dimmer but instead it kinda goes like this.
Nov 18, 2010. 10:31 AMtwighahn says:
skip some of the resistors
Dec 6, 2009. 9:34 PMVic Rattlehead says:
nice, but i was wondering if its possible to wire it up to the interior overhead light wires, and put it up in the headliner, so it only comes on when a door is opened....and maybe in otherplaces as well, but ONLY when the door opens
Nov 18, 2010. 10:29 AMtwighahn says:
i could wire them to my head lights for clearance lights on my motorhome.which in my state have no regulation on them.
Dec 7, 2009. 2:51 PMVic Rattlehead says:
could i possibly take out the main overhead light and use the wire ends from there? all i have for an interior is a single bench seat and no more room, so bright leds will be enough......
Jan 2, 2010. 8:26 PMkrazy2727 says:
if you are doing a string of about 20, does each LED need a resistor on it?
Aug 11, 2009. 7:37 PMacer359 says:
did you connect all the LEDs to the same power source? Where did you get your LEDs?And one more more how would I make one blink?
May 6, 2009. 3:21 AMronnie94 says:
Hi guys. For many times, I installed blue led in my car door handles using 560 ohms. After 3 or 4 days, all my blue led were busted. I tried a lot of times by connecting my resistors to th negative or positive or using 1 k but to no avail. What could have gone wrong?
May 25, 2009. 8:56 AMronnie94 says:
According to the salesgirl, the value of the blue led is 1.5 ohm and she recommended resistor 1k. After a week all leds burned out. I tried resistor 560 ohms 1/2 watt or 1/4 watt but they all burned out. I tried 1.5k at 1/2 watt but the same thing happened. So I gave up.I tried yellow or green led at 1k and up to now they are perfect. But i prefer the blue light. What should I do?
Apr 29, 2009. 9:57 AMHawkeye9009 says:
I know this is really old, but how could you build a dimmer switch for these?
Jun 29, 2008. 8:13 PMscientus says:
This is a short and sweet instructable. I'm thinking of using this to convert an in-car light bulb for the dome light into one that has a few LEDs instead :)
Aug 9, 2008. 11:54 PMantennas says:
Good idea, I already did it. Use 4 then you won't even need a resistor as the voltage divides across all 4 to give perfect amount to each LED. Plus you get to make your light any colour you want now! Mine are blue.
Feb 3, 2009. 10:10 PMgwolff says:
they would need to be wired parallel then, correct? or in series?
May 8, 2009. 9:54 PMDragonMaster0019 says:
They would need to be in series for the voltage to be split. If they were in parallel each LED would need a resistor, and they would draw more power. Parallel lets you run more LEDs off of a smaller power source but you drain it faster.
Jan 12, 2009. 7:03 PMRob K says:
Nice cup holder.
Nov 10, 2008. 7:13 PMThe Lone Hoot says:
excellent instructable!!!
Aug 5, 2008. 7:20 AMgsmaur says:
Cool! which LEDs are you using? there are bunch of with different light intensity (300mcd - 26000mcd).
Mar 18, 2008. 6:28 PMBrianjohn16 says:
great job, but if i want to install them into my car, how do i wire them to power?
May 31, 2008. 4:37 PMbenthekahn says:
you can also use switches. Put them in the "blank panels" that come in most cars.
Jul 10, 2008. 12:15 AMYerboogieman says:
i can turn on m stereo without the key......what about that?
Mar 19, 2008. 4:58 PMBrianjohn16 says:
did you use resistors or just the right amount of leds so the voltage matched
Aug 10, 2008. 12:06 AMantennas says:
Not sure why you don't recommend using the right amount of LED's it works great. LED's are current operated and will only draw what they need to operate. If you over drive the voltage it will still work but you shorten it's life since the junction doesn't like it and eventually fails. If you really over do it the junctions just blows and no more LED.
May 4, 2008. 2:02 PMMoomooco1 says:
Can the resistor be more ohms than it needs to be? My led calls for a 390 ohm resistor when i don't have one!
May 7, 2008. 4:28 PMMoomooco1 says:
Ok! thanks!
Nov 18, 2010. 10:35 AMtwighahn says:
you can also put in more than one resistor.if u have two 50's they would equal about the same as a 100 or put in enough wire to add up to the correct resistance
Feb 15, 2008. 10:05 PMteatimest says:
Nice instructable! Does the resistor have to be on the + side? Does the resistor itself have orientation (color bands)?
1-40 of 50next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
44
Author:computerwiz_222
