Introduction: How to Make an Origami Flower
This tutorial will teach you how to make an origami flower from one piece of paper.
The things you will need:
One piece of paper, colored paper is preferred to give your flower more pazazz
Scissors
WARNING:
When working with scissors, be very careful not to cut yourself. If an accident occurs, wash out the cut with warm water and apply a bandage.
When working with close paper, be careful as to not cut yourself (paper cuts sting!)
Step 1: Square It Up
Start by folding one corner of the paper so that the short side lines up on top of the long side. Be sure to make the crease as tight as possible.
Step 2: Cutting of the Access
Now take your scissors and cut of the thin line of paper that does not overlap the soon-to-be square.
Step 3: Corner to Corner
Fold each corner to its opposite counter corner, then unfold.
Step 4: Halves
Then unfold your paper and fold it in half 'hot dog' style both horizontally and vertically.
Step 5: Balloon Base
Apply pressure to the corners so that your square becomes a star shaped 3-D figure.
Step 6: Make a Kite Shape Fold
Fold one of the small triangles from tip to table creating a kite shaped section.
Step 7: Repeat
Repeat the last step 3 more times to create a kite shape.
Step 8: More Folds...
Fold the lower edges of the kite to the center line as shown, then unfold
Step 9: Continuing
Fold the top point down to the bottom, then unfold
Step 10:
Place your finger inside the kite, just under the folds you just made and fold the top piece up.
Step 11:
Repeat the last step 3 more times to get a diamond.
Step 12:
Now fold the top point downwards. Repeat this 3 times.You should get a diamond shape.
Step 13:
Fold the upper edges into the center line of the diamond. Do this on all 4 sides.
Step 14: Finish the Job
Turn the 'kite' upside down and fold the top points down to get your flower!
you're cool
