Step 5Next step ...
Her is also a 2nd-next (unfortunately not sharp) photo of the Netgear-WG111T Key I used for this antenna with some remarks (chip antenna is this side facing with hot tip up) with proper orientation for vertically polarized signals. Thats why is good to know the inside Key construction, for this type of antenna. So I needed to open it to give you proper info; chip antenna is located 7mm inside back from front plastic cover tip ...
Ps.: if using a plain Netgear-WG111 instead of my recommended T version, it has to be fliped axially for 180deg to mach the same signal polarization as the T version ; so with cheaper one the Netgear logo will be seen facing instead - 2nd slide ...
Add Comment
