Step 6.. & Final look ...
Inner side view of the mounted Key, clearly shows its offset position, if carefully checked. The front tip of a plastic Key enclosure is pushed/situated 37mm (for this particular Key) from inner bottom of a tetrapak, which is practically antenna back "metal" reflector; so the Keys chip antenna hot tip is situated right in the middle & 30-31mm (wifi 1/4-WL) away from the bottom of the finished enhancer, which represents a WaveGuide 1,5-WL long at higher wifi channels ...
The antenna is quite directional & extends Keys range for about 4 times or a bit more in open non-obstacled distance/view ! The range of this basic setup can be extended even further ... but about that in a maybe new Instructable some day later ! ...
Add Comment
