Introduction: How to Make an Easy Elevator Without Redstone in Minecraft
Here is an elevator I made by myself that uses no Redstone and is easy to make.
Step 1:
Make a 3x3 square with a hole in the middle.
Step 2:
Next to the square, make a stack of blocks as high as you want your elevator to be.
Step 3:
At the top of the stack, put another 3x3 square. It should be hovering above the other 3x3.
Step 4:
Stack ice in the hole of the square from the first 3x3 to the other 3x3 hovering above.
Step 5:
Break every other ice block in the stack.
Step 6:
Do the same to the stack of blocks to the side of the 3x3.
Step 7:
Put torches between the blocks in the stack.
Step 8:
Wait until ice melts, but don’t take out the torches. You can break the first ice block in your 3x3 on the ground and replace it with a solid block.
Step 9:
Walk into the floating water blobs and hold down your jump key. Your elevator will start to carry you up.
Step 10:
Enjoy your transportation system :D
Step 11:
Step 12:
Minecraft Challenge
