How to make an electronic piano with a 555 IC by sholtob
Step 15: Adding a led
Adding an led that shows when it is on is useful as this circuit gives of no sound when i not being played, a led will stop you forgetting to turn it off. Solder the resistr to the positive terminal and the other end to the positive lead of the led (the longer one). Then take the other lead and solder it onto the ground. the led should come on when the device is powered
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
