How to Make an End Grain Chessboard
9,452
251
12
Published
Introduction: How to Make an End Grain Chessboard
I make end grain cutting boards. Once I made a "Chess" end grain cutting board
I used mineral oil and beeswax for finishing, so it was impossible to use it as a chessboard. Mineral oil and beeswax never become dry. Also I made a mistake and made A1 square white.:) I am not a chess player.
Then I got an order for the real chessboard. The making process is the same with the exception of finishing. I used varnish for finishing.
I will show the stages of the making process.
Thank you!
Andrei Muntian,
http://mtmwood.com/en/
FREE tutorial "THE BASICS OF MAKING END GRAIN CUTTING BOARDS" - http://eepurl.com/brMc_5
Step 1: Drawings, Wooden Panels
I made the drawings. The customer wanted 50 mm (about 2") squares, so I made 400x400 mm playing surface and 458x458 mm overall size. The border was lower than playing surface. I decided to use walnut and maple for the playing surface and walnut and cherry for the border.
I made two panels (walnut and maple) 52 mm thick.
Next day I sawed off four maple strips and four walnut strips. The thickness of all strips after planing was 50 mm.
Then I made another one wooden panel of these maple and walnut strips.
Step 2: Playing Surface
When the panel dried up I sawed off eight 38 mm wide strips.
I rotated each strip 90 degrees so that the end grain was up and assembled a board.
Then I glued it.
Step 3: Chess Notation
I used CNC machine to make letters/numbers at the border.
I used V-inlay technique. First I made pockets for letters and numbers, then mirror inlays. 30 degree V-bit was used.
I inserted inlays into pockets and glued them.
Step 4: Gluing a Chessboard
I planed the playing surface and sawed of the edges.
I sand the strips with letters/numbers at the drum sander.
Then I glued the border to the playing surface. I made double border. First I glued 4 mm cherry strips, then 25 mm walnut strips. The height of the playing surface was 36 mm, the border - 24 mm.
Step 5: Sanding
There was a lot of sanding. It is very difficult to make an end grain surface flat and smooth. I used dual drum sander with 80 and 120 sandpaper, then a rotary sander with 150 and 220 sandpaper.
Also I engraved my logo at the CNC machine.
Step 6: Finishing
I used a nitrovarnish (20% gloss) for finishing.
A lot of sanding again. I used random orbital sander with 400 sandpaper. I sanded every coat of varnish. There were five coatings.
Step 7: The Result
Thanks for watching!
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    12 Comments
    very beautiful, l like it sooo much...thnks for this good idea
    brilliant!
    عالی بود
    Once again...beautiful job.
    This is beautiful
    What is the model of you CNC Mill? Beautiful piece by the way!
    That chessboard is beautiful! Reminds me of the one I made back in high school! Thanks for sharing!
