Here's what I did:
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Also I've had limited success using the parting tool to cut a straight line longer than an inch or so. The tool always seems to deflect a bit and give me a domed surface.
John
The bolt is just threaded in to the wood, since you're only pushing down and the handle touches the metal it only needs to be strong enough to not fall apart. Epoxy is a better idea.
I made the handle on a wood lathe in my garage.
The top edge is rounded on the metal lathe, just turning both cranks trying to get a nice curve.
Congrats on the wood lathe! Turning wood is really satisfying.
If it is, nice work on it.
I bought a spare for my Pavoni and used a hole saw to re-work it, not pretty, but what a difference!
I even dug out my old Saeco Via Veneto and worked it over, now it’s almost as good as the Pavoni!
For those who have never tapped a thread intop copper, it will SO easily bind and lock your thread cutter in the block...
It will so easily lock yourthread cutter, that it will snap off, rather than screw out a turn or two, too far.
1/3rd of a turn cutting, 1 or 2 turns backwards, 1/3rd of a turn cutting, 1 or 2 turns backwards - etc.,
I do know how to remove broken thread cutting tools from copper bars though......
Might post an instructable on it.
I'm particularly envious not only of your tamper, but of your GS3 in the last photo. My girlfriend and I hand carved a new handle for our Gaggia portafilter a few weeks ago. Have to post the Instructable asap. Perhaps a carved wooden tamper handle could be the next step? Thank you for the inspiration.
That's a nice handle! I make my tamper handles on my wood lathe, spalted maple for this one, rosewood for another, and mahogany for my third tamper. I've slowly been replacing all the plastic pieces on my espresso machine - the portafilter handle, group head, paddle, and steam lever have all been replaced with rosewood. The only thing left to do is replace the plastic ring around the group head.
And yeah, that is funny that the focus in the picture gives that floating effect.
I went with copper because I prefer a heavy tamper - that handle on a stainless steel base is 11oz, with the shiny new copper one it's 17oz. I don't love the color but I'm hopeful that it will get a bit darker over time.
